Results 1 to 6 of 6
Thread: VW Touran 2019 - unsupported vehicle
    Feb 2016
    EU-Slovenia
    we received new VW Touran 1.5 TSI (150 hp).
    I'm sending my full scan. Is this vehicle not compatible with HEX+CAN cable (upgraded to latest version)? Which interface is first one (cheapest) that would support this car? Can anything be done to use existing interface on this Tuaran?
    Can someone please lookup what 2 error codes are on modules 09 and 5F?
    Thank you.
    Saturday,12,October,2019,11:07:10:18194
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVGZZZ1TZLW007323   License Plate:
    Chassis Type  1T (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 6D 75 A5
              BB BC CF
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DPCA)       Labels: None
       Part No SW: 05E 906 018 BN    HW: 05E 907 309 H
       Component: R4 1.5l TFS   H20 9661
       Revision: 8AH20000
       Coding: 0125003223641D0830000000000000000000000000000000
       ASAM Dataset: EV_ECM15TFS01105E906018BN 003004
       ROD: N/A
       VCID: 72D2508EA5E833DFA1-8026
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "EV_ECM15TFS01105E906018BN" ()
    Address 02: Auto Trans (J743)       Labels: None
       Part No SW: 0CW 300 050 A    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1705
       Revision: 00005008    Serial number: CU501908316341
       ROD: N/A
       VCID: 335C958A9A727AD76A-8066
    No ASAM data for: "EV_TCMDQ200021" ()
       Part No SW: 5Q0 614 517 FB    HW: 5Q0 614 517 BS
       Component: ESC           H82 0190
       Revision: 00000000    Serial number: 61679000000970
       Coding: 0CEA6AA030202373477A060260C62930560CC4E2600694753822F078D2A24A0B0000040212121212B235351919323200
       ROD: N/A
       VCID: 76DA6C9EC9802FFF8D-8022
    No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
    Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0523826778
       Coding: 132C0C0723
       ROD: N/A
       VCID: 45B8DB52C4E6F467D4-8010
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11923301
    No ASAM data for: "EV_KessyHellaMQBAB" ()
    Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
       Part No SW: 5G0 907 044 EQ    HW: 5G0 907 044 EQ
       Component: Climatronic   H04 2202
       Revision: 00001K10
       Coding: 08020004200110011105100000101426
       ASAM Dataset: EV_ACClimaBHBVW37X 006150
       ROD: N/A
       VCID: 7AC278AEFD984B9FE9-802E
    No ASAM data for: "EV_ACClimaBHBVW37X" ()
       Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F17081900CV
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: N/A
       VCID: 7F3489BAE6BA6EB7DE-802A
       Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    190715  043  0608
       Serial number:         190805182605
       Component: RLHS  051  0206
       Serial number: S5Y19M08D26H18M22S42
       Coding: 0008DD
       Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03  0170
       Serial number: 0100170820190C102081
    No ASAM data for: "EV_BodyContrModul1UDSBosc" ()
    5642 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 49
                        Mileage: 44 km
                        Date: 2019.09.27
                        Time: 19:32:00
    Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058319241
       Coding: 0471155811
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       ROD: N/A
       VCID: 5096FA060BA421CF77-8004
    No ASAM data for: "EV_EPHVA18AU3700000" ()
    Address 13: Auto Dist. Reg (J428)       Labels:. 3Q0-907-572.clb
       Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
       Component: ACC BOSCH MQB H05 0196
       Coding: 3204675219FFC428949C804D
       ROD: N/A
       VCID: 3558AB92940664E744-8060
    No ASAM data for: "EV_ACCBOSCHVW48X" ()
    Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
       Component: AirbagVW21    008 0403
       Serial number: 003FNR5LRFLS
       Coding: 98CCC0C00C0000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: N/A
       VCID: 131C350AFA329AD70A-8046
       Subsystem 1 - Part No SW: -----------    HW: 480 000 209 19
       Serial number: 3570000000097C20DF3X
       Subsystem 2 - Part No SW: -----------    HW: 480 000 209 19
       Serial number: 35800000000D7C20DF3
       Subsystem 3 - Part No SW: -----------    HW: 480 410 209 19
       Component: SideSensor_Dr  003 0189
       Serial number: 351001A119A191F33F13
       Subsystem 4 - Part No SW: -----------    HW: 480 410 209 19
       Component: SideSensor_Pr  003 0189
       Serial number: 352001A119A1D544EC8H
       Subsystem 5 - Part No SW: -----------    HW: 480 402 708 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001BCF240023D831
       Subsystem 6 - Part No SW: -----------    HW: 480 403 008 19
       Component: PedP_Sensor_C  005 6149
       Serial number: 2300001BCF20D054BA03
       Subsystem 7 - Part No SW: -----------    HW: 480 001 708 19
       Serial number: I0M00000000D95146F3A
       Subsystem 8 - Part No SW: -----------    HW: 480 001 708 19
       Serial number: I0N000000002E015CE36
    No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
    Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
       Part No SW: 5TA 920 740 D    HW: 5TA 920 740 D
       Component: KOMBI         203 6700
       Coding: 07A401086F88000801882A0B1401000800000000
       ROD: N/A
       VCID: 44BEC656CFDCCD6FC3-8010
    No ASAM data for: "EV_DashBoardVDDMQBAB" ()
    Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
       Component: GW MQB High   521 5388
       Serial number: 18081910803356
       Coding: 030100047F0857002310025A180F00010001070000000000000000000000
       ROD: N/A
       VCID: 70D65A86ABE401CF57-8024
       Component: 5-00-14-00-04
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 1971901323100090FJ2B
       Coding: 2C0000
       Serial number: 9330432405
    No ASAM data for: "EV_GatewNF" ()
    Address 3C: Lane Change (J769)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
       Component: MRR1Rear      H25 0530
       Revision: --------
       Coding: 04C002
       ROD: N/A
       VCID: 3C4EBEB6B72CB5AFBB-8068
    No ASAM data for: "EV_RearRadarS1BoschVW48X" ()
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0320
       Serial number: YE007SH601452
       Coding: 00319320D000040000001000
       ROD: N/A
       VCID: 49A0D762E8FE100730-801C
    No ASAM data for: "EV_DCU2DriveSideMAXHKLO" ()
    Address 44: Steering Assist (J500)       Labels:. 5Q0-910-143.clb
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 956030 00
       Coding: 0100001100400010
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: N/A
       VCID: 2B6C8DEA4242221722-807E
    No ASAM data for: "EV_SteerAssisVWBSMQBGen2" ()
    Address 4B: Multifunc. Module
    Interface not compatible.
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0320
       Serial number: YE007SG315963
       Coding: 00319120DC00040000001000
       ROD: N/A
       VCID: 48A6D266F3F4E90F2F-801C
    No ASAM data for: "EV_DCU2PasseSideMAXHKLO" ()
    Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
       Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
       Component: MU-S--ER      724 0890
       Coding: 02730800FF0000004111000100080A001F0500D40120010002
       ROD: N/A
       VCID: 2D6883F27C562C273C-8078
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H61 8214
       Serial number: VWZ6ZJW2450061
    No ASAM data for: "EV_MUStd4CDELP" ()
    6720 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 72
                        Mileage: 312 km
                        Date: 2019.10.05
                        Time: 13:05:13
    Address 6D: Trunk Elect. (J605)       Labels:. 5Q0-959-107.clb
       Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0271
       Revision: --------    Serial number: A2-C737-6291-8
       Coding: 0308
       ROD: N/A
    No ASAM data for: "EV_DeckLidCONTIAU736" ()
    Address 75: Telematics (J949)       Labels:. 5QE-035-285.clb
       Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Component: OCULowMQBLGE  H19 0825
       Revision: --------
       Coding: 02730801EA16180D3F1CBE000045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004049
       ROD: N/A
       VCID: 3D48B3B2AC36BCA78C-8068
    No ASAM data for: "EV_OCULowMQBLGE" ()
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H12 0610
       Serial number: 23071915K11421
       Coding: 0003070800000401002200468140A90088000E30004000
       ROD: N/A
       VCID: 40B6CA46DBC4D14FE7-8014
    No ASAM data for: "EV_MFKBoschMQBB" ()
    Address BB: Door Rear Drv (J388)       Labels: None
       Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
       Component: TSG HFS004 0320
       Serial number: YE007SGN3745D
       Coding: 002091200000040000001000
       ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
       ROD: N/A
       VCID: 4BACED6AE282021702-801E
    No ASAM data for: "EV_DCU2RearDriveMAXHKLO" ()
    Address BC: Door Rear Pass (J389)       Labels: None
       Component: TSG HBFS004 0320
       Serial number: YE007SHC06807
       ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
       ROD: N/A
    No ASAM data for: "EV_DCU2RearPasseMAXHKLO" ()
    Address CF: Lane Chge Asst 2
    End-------------------------(Elapsed Time: 04:10)--------------------------
  2. Likes Boki Ar liked this post
  3. #2
    Jun 2014
    It was say hmm.......over about a year ago
    you need to use Hex NET or HEX V2
  4. Likes Uwe liked this post
  5. #3
    Feb 2016
    EU-Slovenia
    I'm not "heavy" user. From time to time to check status of modules, make some adaptation to non-critical modules (like infotainment, climat, etc...) and that it is all. And to have chance to do this also on new car.
    No need for bluetooth, wifi, etc... classic cable is ok.
    Quote Originally Posted by IgorDeLuxe View Post
    So for 2019 and later models you need a HEX-V2.
  7. Likes Uwe, Boki Ar liked this post
  8. #5
    Aug 2014
    Would it be possible for you to post a complete log of all the adaptions channels from 09?
    (I really need this for a small project )
  9. #6
    May 2014
    ^^^ hmm...... hex09 DTC (and hex5F) DTC is intermittent and hasn't occurred again in the 15 x days between first registration on the CAN bus and the date of the auto-scan. Kind-of suggests that it might be prudent to reset all DTCs and re-poll the car (and post-up a new auto scan) - perhaps?
    Doesn't solve the incompatibility problem with the VCDS cable - but might establish a more stable information base for further analysis -maybe?
