Having potential trouble with fuel pressure regulator.
Also would like to know if I need to do anything with the Stock stereo that I kept but upgraded speakers and amp?
Thank You
Thank You
Friday,11,October,2019,20:41:37:19528
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWFD7AJ9CW285653 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
VIN: WVWFD7AJ9CW285653 Mileage: 91550km-56886miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0040
Revision: E3H26--- Serial number:
Coding: 040301081C070160
Shop #: WSC 51524 001 1048576
VCID: 78A9161BCED78F47F17-802C
P0087 - 000 - Too Low - MIL ON
Fault Status: 11100000
Mileage: 91557 km
Date: 2014.02.25
Time: 16:24:48
RPM: 813 /min
Load: 28.2 %
Temperature: 75.0°C
Temperature: 55.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.716 V
001343 - Fuel Pressure too Low during Cold Start
P053F - 000 - - MIL ON
Mileage: 91557 km
Date: 2014.02.26
Time: 20:53:44
RPM: 1113 /min
Load: 47.0 %
Speed: 3.0 km/h
Temperature: 30.0°C
Temperature: 36.0°C
Voltage: 13.716 V
Readiness: 1110 0101
Part No SW: 02E 300 057 R HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3115
Revision: 05551213 Serial number: 00001202222071
VCID: 2809065B5EF7DFC7A17-807C
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492A00FF881106E9921C0041B70800
VCID: 7BA30917F3E1A45F9C5-802E
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
VCID: 00597EFB9A87C787C97-8054
Part No SW: 1K0 937 086 P HW: 1K0 937 086 P
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 6F180A1A90272A04008800C17000054448010386434D8D60648020200040
VCID: 3D27C70FAD756A6FE21-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 27021 26 0512
Coding: 009795
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1MVKW
Coding: 00003131
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3FDBBD07A7F9787FF0D-806A
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000035EB00
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME7016216BZZZR
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME2E0F666AZZZA
Serial number: 3512QSME6E496D4BZZZF
Serial number: 3522QSME48366C32ZZZ-
Component: F.Sens.Fahr --- ----
Serial number: 35527SME6703632BZZZE
Component: F.Sens.Beif --- ----
Serial number: 35627SME6A1A6B29ZZZW
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LBS0000K
Coding: 189A140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B51823C843F937E3B-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Serial number: 0008837
Coding: 830000
Part No SW: 5K6 920 972 C HW: 5K6 920 972 C
Component: KOMBI H03 0607
Coding: 270D01
VCID: 3635D82388C3B93723B-8062
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 020312F1000867
Coding: 350000
VCID: 3A2DCC13BC5B5D57C73-806E
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RH3JY06
VCID: 7EA50003ECF3B177BBB-802A
Component: IMMO H03 0607
VCID: 6A8D3C538CFB2DD7773-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7662052266
VCID: 290F035F49FDE6CFBE9-807C
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2103
Coding: 0001076
VCID: 372BD5278349403F38D-8062
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 323DE433682BA5170F3-8066
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M1107210
Coding: 01000400040005
VCID: 639351776B517C9FB45-8036
9 Faults Found:
Fault Status: 00101011
Reset counter: 165
Mileage: 91557 km
Date: 2014.02.25
Time: 16:24:29
Reset counter: 165
Mileage: 91557 km
Date: 2014.02.25
Time: 16:24:29
Reset counter: 165
Mileage: 91557 km
Date: 2014.02.25
Time: 16:24:29
Reset counter: 165
Mileage: 91557 km
Date: 2014.02.25
Time: 16:24:29
Reset counter: 165
Mileage: 91557 km
Date: 2014.02.25
Time: 16:24:34
Reset counter: 165
Mileage: 91557 km
Date: 2014.03.03
Time: 18:05:56
Reset counter: 165
Mileage: 91557 km
Date: 2014.03.03
Time: 18:05:56
Reset counter: 165
Mileage: 91557 km
Date: 2014.03.03
Time: 18:05:56
Reset counter: 165
Mileage: 91557 km
Date: 2014.03.03
Time: 18:05:56
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661942247
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 270B05675F69D0BFA8D-8072
End----------(Elapsed Time: 01:01, VBatt start/end: 12.3V/12.3V)-----------
