hello, I'm new here.
Not working parking aid and parking asist.
Any help?
Any help?
VIN: WVGZZZ5NZBW002157 License Plate:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 1C 22 25 37 42 44 46 52 53 56 62
69 72
VIN: WVGZZZ5NZBW002157 Mileage: 233690km-145208miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 ET HW: 03L 907 309 R
Component: R4 2.0l TDI H21 9977
Revision: 42H21--- Serial number: 00000000000000
Coding: 00190012040700080000
Shop #: WSC 00014 210 12345
ASAM Dataset: EV_ECM20TDI01103L906018ET 003011
ROD: EV_ECM20TDI01103L906018ET_VW36.rod
VCID: 000837599B5CA54FA7-8054
4714 - Steering Column Control Module
U0212 00 [039] - No Communications
Mileage: 233698 km
Date: 2019.10.11
Time: 14:33:40
Coolant temperature: 70 °C
Intake air temperature: 26 °C
Voltage terminal 30: 11.840 V
Limitation: accelerator pedal: 126.6 Nm
Cruise Control System (CCS): status-Bits 0-7: 4
selected gear-Bits 0-7: 0
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
Component: J104 C4 450 V2D7 0006
Revision: --H28--- Serial number: 00000002842136
Coding: 0015660
Shop #: WSC 01324 020 00200
VCID: 397E9ABD70063487A0-806C
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0008000002
ROD: EV_ClimaBasis_VW36.rod
VCID: 6ED479E1B1C8A33F45-803A
Part No SW: 5K0 937 086 F HW: 5K0 937 086 F
Component: BCM PQ35 M 011 0035
Revision: BC011001
Coding: 40180A388073B5D8000800891500812443613088524D8563DC8020000040
VCID: 377A9C85861222F756-8062
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 14051 012 0203
Serial number: N2955119 °203!
Coding: 0097B5
Subsystem 2 - Part No: 1K8 951 171
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88591013486863
Coding: 011002
VCID: 4088F759D3DC654FE7-8014
Reset counter: 215
Mileage: 233698 km
Date: 2014.03.03
Time: 14:27:57
Temperature: 15.0°C
Part No SW: 5N0 959 655 N HW: 5N0 959 655 N
Component: J234__201 VW10 HI 1916
Revision: 21014000 Serial number: 003GHP9YEDRT
Coding: 0012337
VCID: 4898EF793BEC5D0F2F-801C
Subsystem 1 - Serial number: 6332MTS615391240
Subsystem 2 - Serial number: 6342MTS627371240
Subsystem 3 - Serial number: 6351HTS6S64G89KR
Subsystem 4 - Serial number: 6361HTS6EIPG89KR
Part No SW: 5K0 953 521 BM HW: 5K0 953 569 D
Component: LENKS.MODUL 009 0135
Revision: FF010036 Serial number: 20100427200197
Coding: 100A044000
ASAM Dataset: EV_SMLSNGVOLWS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 78F85FB9C38CED8F9F-802C
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 820000
Part No SW: 5N0 920 972 A HW: 5N0 920 972 A
Component: KOMBI H03 0406
Coding: 110F01
VCID: 316EA29D6076FCC718-8064
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 090510F2001463
Coding: F9A27F4640120200006003
VCID: 6DD67EED74CE58277C-8038
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R8Z0Y06
VCID: 7EF449A129A8D3BFD5-802A
Part No SW: 0AY 907 554 D HW: 0AY 907 554 D
Component: Haldex 4Motion 0042
Coding: 0000005
VCID: 4C90D3692F94B12F0B-8018
Component: IMMO H03 0406
VCID: 6ADC75F18D204F1F19-803E
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H50 5274
Revision: AB001001 Serial number: VWZ6Z7L5072817
Coding: 000504000000009F000C
Shop #: WSC 05314 123 12345
Component: EU West V15 8515
00856 - Radio Antenna
Fault Status: 01101011
Reset counter: 215
Mileage: 233696 km
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2102
Coding: 0000700
VCID: 366491814118DBFF4D-8062
Part No: 5N0 909 144 J
Component: EPS_ZFLS Kl. 202 3001
Revision: 00H17000
Shop #: WSC 01324 785 00200
VCID: 38789FB94B0C2D8F5F-806C
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0000700
VCID: 377A9C85461222F756-8062
Part No SW: 3AA 907 801 D HW: 3AA 907 801 D
Component: J540 EPB4 VW-53083 0006
Revision: H18 Serial number: 00000000005283
Coding: 0023057
VCID: 326CAD91AD70C7DF61-8066
Reset counter: 215
Mileage: 233696 km
Part No SW: 5N0 959 703 D HW: 5N0 959 703 D
Component: Tuer-SG 007 2102
Coding: 0000144
Shop #: WSC 01324 020 1012551
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H07 0070
Revision: 3A001001 Serial number: 00000129822254
Coding: 410D000100000000
VCID: 3068A799637CF5CF17-8064
Part No SW: 5N0 959 704 D HW: 5N0 959 704 D
Coding: 0000144
End-------------------------(Elapsed Time: 02:54)--------------------------
