Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: RETROFIT VIRTUAL COCKPIT NOW PROBLEMS HELP PLZ
    Aug 2019
    Manchester, UK
    Unhappy RETROFIT VIRTUAL COCKPIT NOW PROBLEMS HELP PLZ
    2013 audi a3 2.0 tdi hatchback 5 door
    HELLO
    i did a retrofit a VIRTUAL COCKPIT. calibrated and removed compoment protection but i have lost my drive select, and cruise control. the auto stop and start works sometimes only. i havd got mib2 works perfect. do not know what 4E is cant get rid of it
    new steering wheel lights and paddelswork but no butons are working. . Been going mad trying to sort it out, HELP NEEDED THANK YOU VERY MUCH IN ADVANCE.
    AUTO SCAN DONE
    Friday,11,October,2019,07:20:31:31689
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8V5EA002827   License Plate:
    Chassis Type  8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 47 4E 52 55 5F BB
              BC
    VIN: WAUZZZ8V5EA002827   Mileage: 13002km-8079miles
    47-Sound System -- Status: Not registered 0001
    4E-Ctrl Head RR -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5520
       Revision: 83H22---
       Coding: 021D0012032501083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
       ROD: EV_ECM20TDI01104L906021DT_002.rod
       VCID: 7AFC785BFDA4909FE9-802E
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [038] - -
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:24
                        Engine speed: 772.00 /min
                        Normed load value: 31.4 %
                        Coolant temperature: 31 °C
                        Intake air temperature: 19 °C
                        Voltage terminal 30: 14.420 V
                        ACC variants-Bits 0-7: 0
                        CCS Switch-Bits 0-7: 1
                        Cruise control switch actuation-Bits 0-7: 32
                        Cruise control switch actuation-Bits 0-7: 0
                        ACC variants (coding)-Bits 0-7: 1
                        Acceleration: 0.000 m/s²
       Part No SW: 0D9 300 040 K    HW: 02E 927 770 AN
       Component: DQ250-6F MQB  H52 4005
       Revision: 05652104    Serial number: TFK01304221308
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1F4A69CF06C615B7BE-804A
       Revision: 00000000    Serial number: 61323000000604
       Coding: 12F18AA224200A6E037F060241CA2948512450C0608294F3026100788508
       Shop #: WSC 27496 003 104857
       VCID: 7BF27D5FF29EA997F2-802E
    8299 - Databus
                        Reset counter: 13
                        Date: 2019.10.11
                        Time: 07:14:23
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [008] - -
                        Reset counter: 53
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:25
       Revision: 00021000    Serial number: 0207224423
       Coding: 030C0C
       VCID: 3A7CB85BBD24509FA9-806E
       Part No SW: 8V0 820 043     HW: 8V0 820 043
       Component: AC Automat    H12 0031
       Revision: 20020000    Serial number: 00000000086272
       Coding: 03100114002000011000000000001100
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
       VCID: 6FEA590FB6E6C5374E-803A
       Serial number: DB480CA6000000000001
       Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
       Component: BCM MQBAB H   H14 0112
       Serial number: 00011313501857
       Coding: 07111A42C24122FD03844004B31C07A80810000000000000000000000000
       ROD: EV_BCMBOSCH_011.rod
       VCID: 77FA616FCEB68DF796-8022
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 130509  041 0580
       Serial number:         130510235859
       Coding: 0AC7F7
       Serial number: 21318029
       Coding: 03006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 01 04 2013  00000599
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY1311427SE
       Serial number: 00000000000056755419
       Sun Roof:
       Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.009  H02 0007
       Serial number:     WOO21753350
       Coding: 901E00
       Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H09 0033
       Revision: --------    Serial number: 60831313901784
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14AU3700000 002018
       VCID: 3878A2538328428F5F-806C
       Serial number: 003M2R01LV1M
       Coding: 98FCC0000C0000005C5400CA00C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4B92ED9FE2BED91702-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 005 13
       Serial number: 35767000000A08904D0T
       Subsystem 2 - Part No SW: -----------    HW: 480 001 005 13
       Serial number: 35867000000CF7904D03
       Subsystem 3 - Part No SW: -----------    HW: 480 402 504 13
       Serial number: 3516502B51050652021H
       Subsystem 4 - Part No SW: -----------    HW: 480 401 704 13
       Serial number: 3526502BF0FBDE3303C.
       Subsystem 5 - Part No SW: -----------    HW: 480 401 503 13
       Serial number: 35565029B0FAE89452A.
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 605 13
       Serial number: 2286502C51050652027R
       Subsystem 7 - Part No SW: -----------    HW: 480 400 605 13
       Serial number: 2296502C51050653F0C4
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 605 13
       Serial number: 2306502C91050654419V
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 8V0 953 521 P    HW: 5Q0 953 549
       Revision: --------    Serial number: 14051308490504
       Coding: AC18
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 479AD1AFFED63D7726-8012
    No ASAM data for: "EV_SMLSKLOMQB" (AU37)
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
       Component: FBenRDW       H16 0066
       Coding: 24BD09122B8006000101E8000400000000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001027
       ROD: EV_DashBoardFPKAU37X.rod
              U1014 00 [009] - -
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:22
    16776994 - Databus
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:22
       Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1144
       Revision: --------    Serial number: 0000573341
       Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
       ASAM Dataset: EV_GatewLear 009013
       ROD: EV_GatewLear_009.rod
       VCID: 3B72BD5FB21E6997B2-806E
       Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 11 05 2013  B0191706
       Subsystem 3 - Part No SW: 5Q0 915 181 D    HW: 5Q0 915 181 D
       Component: J367-BDM  H08 0192
       Serial number: 00000000004051357328
       Part No SW: 5Q0 905 861     HW: 5Q0 905 861
       Component: ELV-MQBA      H06 0010
       Revision: 00000000    Serial number: 13000084091001
       Coding: 0900000000000000
       ASAM Dataset: EV_ELVMarquMQB 003008
       ROD: EV_ELVMarquMQB_003.rod
       VCID: 73E2557FDACEE1D7AA-8026
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 05051301100200
       Coding: 00559E205C01040000001003
       VCID: 3F8AC94FA60675B79E-806A
       Coding: 81
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D76B347AC0A67A78C-8068
       Part No SW: 8V0 035 465 A    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0370
       Serial number: AUZ8ZAD090098JE
       Coding: 01030300AAAA2AAA01
       ASAM Dataset: EV_AMPMst16C1ALPI 004024
       ROD: EV_AMPMst16C1ALPI_004_AU37.rod
       VCID: 3664AC6B893CB4FF4D-8062
    Address 4E: Ctrl Head RR
    Interface not compatible.
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 03051301100606
       Coding: 00559E205401040000001002
       VCID: 3E74B44BA10C7CBF95-806A
       Component: LWR-ECU       005 0070
       Coding: 019E000001000000
       VCID: 75E66B67D4BAFFE784-8020
       Part No SW: 8V1 035 035 B    HW: 8V1 035 035
       Component: MU-P-LND-EU   054 1106
       Serial number: A698I0H2530761
       Coding: 017350010000000011111102000A00332F0027E7017001009E
       Shop #: WSC 00046 123 12345
       VCID: 316E9F77605293C718-8064
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y05D3Y
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL124051600010009
       Component: Gracenote2  --- 1016
    9 Faults Found:
              B201A 00 [009] - -
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:31
                        Voltage terminal 30: 14.3 V
                        Status_Software_Version_Management-module_name: MDUA201/Front
    15360768 - Component Protection
              U1101 00 [009] - Active
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:25
                        Voltage terminal 30: 14.4 V
    1552 - Expanded Bus Activity Active
              U1104 00 [009] - -
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:24
                        Voltage terminal 30: 14.5 V
              U11B8 00 [009] - No Communications
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:25
                        Interface for external media: status-Status: Open circuit
    3073 - Cellular Antenna
              B1053 13 [009] - Open Circuit
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:25
    3084 - GSM antenna 2
              B1533 13 [009] - Open Circuit
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:25
    3077 - Telephone baseplate
              B1051 13 [009] - Open Circuit
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:24
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:27
                        BAP-BAP_Function_ID: 02
    7228 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 13
                        Mileage: 13002 km
                        Date: 2019.10.11
                        Time: 07:14:27
       Part No SW: 5Q0 959 595 A    HW: 5Q0 959 595
       Component: TSG HFS       010 0006
       Serial number: 27041301101166
       Coding: 004196204001040000001002
       VCID: 418ECFB7D0F20347E8-8014
       Component: TSG HBFS      010 0006
       Serial number: 27041304081175
    End-------------------------(Elapsed Time: 04:57)--------------------------
    Retrofits!
    Yep, moved.
    It looks like you are using an older Ross-Tech cable (e.g. HEX-USB) but your car has modules that use CAN messages that it cannot read (that's what is causing the Extended UDS and Interface not compatible messages) so to read the fault details and understand what the problem is with 4E you should consider upgrading to a HEX-V2 or HEX-NET.
    This is caused by VAG changing their CAN messages to ones that the older cables cannot read, not because of a decision by Ross-Tech.
    I'm kinda scratching my head, wondering what such a module is doing in a 2013 car.
    Oh wait, it's not a 2013. WAUZZZ8V5EA002827 is clearly a 2014. But I'm still surprised to see that.
  6. Likes PetrolDave liked this post
    Aug 2019
    Manchester, UK
    Thank you for moving it
    Aug 2019
    Manchester, UK
    I have purchased one and it should be coming tomorrow hex-v2. I do not know what the 4e is. Doing my head. Its not even ticked in can gateway installation list. After retrofit the instrument doesn't recognise the drivers door. It says shift to p. But does not show in auto scan.
  9. #8
    Mar 2015
    Australia
    You need to restore FEC to the gateway module.
    When CP is removed, it also clears the installed FEC. Drive select is a SWaP feature, so it needs to be restored to the gateway using ODIS online.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  10. Likes PetrolDave liked this post
  11. #9
    Aug 2019
    Manchester, UK
    Thank you for the info. I went to 2 people who Code and Retrofit not one mention of that. Is that why cruise control is not working?
  12. #10
    Mar 2015
    Australia
    Quote Originally Posted by Codeme View Post
    Yes.
    Restore fec to gateway and you will get cruise control back, drive select, and also fix the incorrect coding fault on powertrain
