Results 1 to 10 of 10
Thread: Adaptation map
    Adaptation map
    Trying to get a map from module 44 but first time doing this and I don't see and status bars as I do in say an auto scan. Entered address 44 and security code which highlights " do it" field which I enter. All I see is the rotating bar up top but no other status as to the progress. Do I just let this carry on until the bar stops or does a message pop up that the files has been exported? Unlike the autoscan I don't know how long it should take to generate and I don't want to be doing anything wrong.
    May 2014
    ^^^^ So - are you in the correct screen?
    First select Applications from here
    Then select Controller Channel Map from here:
    Then set-up the dialogue-box like this (type "44" instead of "09" and enter SA if you want):
  3. Likes Uwe, PetrolDave liked this post
    Hi Don, thanks for the reply. Yep I'm there and I have 44 in that box but unless I enter an SA the go button is grayed out. So I put in the number someone mentioned (maybe you?) and sure enough the go button is active. I press it and I am getting a map I just don't see anywhere what the progress of the export is. So the only thing I see is that line top left rotating. I am just buggin because I don't know how long I am supposed to wait for it to finish? I did it twice but cancelled as it was taking a while and got 2 partial maps in log folder. Is this a time intensive download? Any dialogue box complete when complete?
    No, the only requirement for the [Go] button to become enabled is to select a function (Measuring Values or Adaptations). That's literally the only thing you need to "light up" the [Go] button; you don't even have to enter an address, but of course if you fail to enter a controller address, and you click [Go], you'll get an error telling you that you need to enter an address.
    Sorry it was the number DV52 mentioned and it worked.
    I'll hook it up right now
    Out of curiosity, how long would the export take?
  9. #8
    Got it, its only 19 lines I was thinking it would be a massive file. If Im being honest I just put the dog down and probably shouldn't be fooling with anything. I will post it on the other thread.
    Thanks
  10. #9
    Got it Don, thanks
  11. #10
    Thanks Uwe
