ACC and Front Assist are not available on 2016 TDI Lux?
deadl0ck
Los Angeles, USA
C?ID=383256
Hey! First time post in here as I just received my HEX-V2 yesterday to troubleshoot an issue with ACC and Front Assist reporting as not available. Additionally, lane assist is not available and I suspect there's something causing a disconnect from the camera behind the rear view mirror. I posted this on Clubtouareg as well but I don't want to risk damaging my rear view mirror or the rain sensor/camera if I'm going down the wrong path.
The ACC previously would intermittently report this error and it would clear typically after I got back in my car and started it again in like 30 mins so I didn't troubleshoot anything but last Thursday it finally just failed and stayed off. I cleared out a few other codes yesterday that have not resurfaced (I can provide those scans if necessary though I don't think they're related). It's the fault code in 8E-Image Processing 0161 - Video Cable for Image Processing (C1107 02 [009] - Signal Failure) which to me sounds like somehow the cable has been disconnected from the lane departure camera? Prior to this error being on permanently, I had been driving on some slighly rough fire roads and perhaps some connection shook loose or it could just be from sitting in the sun here in LA but I really miss my ACC, I can totally live without Front Assist cuz it sucks but need to get this sorted out.
Any troubleshooting suggestions or things to check first? Or if anyone knows how to safely remove the rear view mirror to get the plastic trim covering the image processor control unit, that would also be helpful to check connections.
Any and all input welcomed and appreciated!!!
Thanks, Zach
Thursday,10,October,2019,12:29:47:51060
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VirtualBox)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVGEP9BPXGD003499   License Plate: TOPSECRET
Mileage: 72022km-44752mi   Repair Order: 420
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 52 53 55 56
          5F 62 65 69 6C 6D 72 85 8B 8E
VIN: WVGEP9BPXGD003499   Mileage: 72022km-44752miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 C    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    H21 0007
   Revision: 56H21---
   Coding: 292A4012237600050000
   Shop #: WSC 22503 444 00000
   ASAM Dataset: EV_ECM30TDI0117P1907401C 001008
   ROD: EV_ECM30TDI0117P1907401C.rod
   VCID: 303917DDAAAF24C7797-8065
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 R    HW: 0C8 927 755
   Component: AL1000 AISIN  130 3374
   Coding: 010200000C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 40D9471D1A0FB447897-8015
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 R    HW: 7P0 907 379 A
   Component: MK25A         H37 0521
   Revision: --------    Serial number: 41265439627697
   Coding: 5B7613C349246F56DAF8C89C92DBF6607301
   ASAM Dataset: EV_MK25AXT 010001
   ROD: EV_ESPMK25A01000.rod
   VCID: 4CC1632D2647602765F-8019
   Part No SW: 4H0 907 064 GK    HW: 4H0 907 064 GK
   Component: BCM2 2.0      H37 0572
   Coding: 0D860016000000000000
   VCID: 78A9EFFD02DF3C87F17-802D
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3215000122931004
   Part No SW: 7P6 907 040 CN    HW: 7P6 907 040 CN
   Component: Klima 2 Zonen H23 1507
   Coding: B686200A80
   VCID: 025D8D1554836657DF3-8057
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Revision: 22020001    Serial number: 00001124414101
   Coding: 26000096963C5D010020480000005D4C431C6608A2014265000000008040110000000000000000
   VCID: 6A8DC5B54C739E17773-803F
   Component: WWS    150702  033 0021
   Serial number: 90243400150716135457
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20613585
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AC    HW: 7P6 941 431 AC
   Component: E1 - LDS  H02 0040
   Serial number: 00000000002006150168
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01FA48CD
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0155891335
   Coding: 952F00
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28261519500762
   Coding: 310D04
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D14B0D0E17A867ADF-8011
   Part No SW: 7P6 907 561 C    HW: 7P6 907 561
   Component: ACC3          H21 0400
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContrVW526 002012
   ROD: EV_AdaptCruisContrVW526_002.rod
   VCID: 3C2133ED76E7D0A7D5F-8069
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 11
                    Reset counter: 56
                    Mileage: 72009 km
                    Date: 2019.10.09
                    Time: 17:53:40
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 13.612 V
                    Velocity_vehicle_reference: -0.01 m/s
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag02B H10 0044
   Revision: --------    Serial number: 003S8000L4CX
   Coding: 000000000000000000000000000000003242
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R153300Q26D
   Serial number: 3575LRB40513DV8QA1S.
   Serial number: 3585LRB405F3DV8QGHAD
   Serial number: 3517ARB40633C6BKD1M-
   Serial number: 3527ARB40573C6BKMGML
   Serial number: 3557BRB40693CGVCF89M
   Serial number: 3567BRB40693CGVCI0PY
   Part No SW: 4H0 953 568 M    HW: 7P6 953 507 AJ
   Revision: --------    Serial number: 01374OGM0001Z
   Coding: 000CDD
   VCID: 3D273EE96D7DD9AFE21-8069
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0095189 TRW 20150630
   Part No SW: 7P6 920 983 D    HW: 7P6 920 983 D
   Component: Kombi         H13 0515
   Revision: 13240302    Serial number: 658200715592029
   Coding: 8B5733026F08CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526.rod
   Part No SW: 7P6 907 530 N    HW: 7P6 907 530 G
   Component: GW-CAN-L-FR-M H13 6042
   Revision: --------    Serial number: 00000001929706
   Coding: 000103AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 43D348110B19AF5F945-8017
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 32188119315705512946
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000156834817
   Coding: C0581B0015004001000001010101202020202121202020
   VCID: 353726C9554D01EF2A1-8061
   Part No SW: 7P6 907 566 A    HW: 4H0 907 566 F
   Component: SWA Master    H06 0021
   Serial number: 0373425901
   Coding: 030221
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 3FDB44E167F1CBBFF0D-806B
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 7P6 907 568 A    HW: 4H0 907 568 F
   Component: SWA Slave  H06 0021
   Serial number: 0374232792
   Coding: 030221
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000159194529
   Coding: 011D17205E00453005080001
   VCID: 7AADF5F53CD32E97873-802F
   Revision: 00002001    Serial number: 0374303391
   Coding: 0187123A68B9509580A00620210A18000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719 A    HW: 7P6 959 719 A
   Component: GTO BT  H20 0059
   Serial number: 181155416
   Subsystem 3 - Part No SW: 7P0 959 591 D    HW: 6R0 959 591 D
   Component: J245 PS30.408  H03 0004
   Serial number: 0000FST000F0QZ400000
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 E    HW: 8V3 959 591 A
   Component: J394 PS30.408  H03 0004
   Serial number: 0000FST000FO7OY00000
   Coding: 191100
   Subsystem 5 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65024661
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000158924375
   Coding: 011D17205E00453005080000
   VCID: 48C95F3D32BF8C07417-801D
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1571600264
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 363521C548CB0AF723B-8063
   Slave 3:
   Coding: 012A02010B000400
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156G 0F8294140
   Coding: 020007020100000001
   VCID: 2411EB8DEED788678DF-8071
   Part No SW: 7P6 035 664 K    HW: 7P6 035 664 A
   Component: H-BN-NA       H41 0933
   Revision: --------    Serial number: 606G-0F7501652
   Coding: 010200050040E9EF79022B0E00000003F00001030000000000
   VCID: 40D9471D1A8FB447897-8015
   Subsystem 1 - Part No: 7P6 060 884 B
   Component: NAR 2015  1202
   Subsystem 2 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9RGG0028B
   Subsystem 3 - Part No SW: 7P6 919 603 L    HW: 7P6 919 603 L
   Component: CD-Database  6208
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000159357128
   Coding: 011817200000253005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 L    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0003
   Serial number: 40000000021821
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   VCID: 45D75609052D916FBA1-8011
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0374374190
   Coding: 0200000200000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
   VCID: 372B2CC14FC1F3FF38D-8063
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8JA61978
   Coding: 0130001
   VCID: 372B2CC14341F3FF38D-8063
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 194501447
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000159351675
   Part No SW: 7P6 907 217 B    HW: 7P6 907 217
   Component: DPC-SG        H26 0035
   Coding: 69020000
   ASAM Dataset: EV_OnBoardCamerDTR 001001
   ROD: EV_OnBoardCamerDTR.rod
   VCID: 392F2AF979D5E58FCE9-806D
   Slave 1:
   Subsystem 1 - Part No: 7P6 907 658
   Component: NICKRATENSENS  H02 0001
   Serial number: 000000007065951_3349
   Part No SW: 7P6 907 541 C    HW: 7P6 907 541
   Coding: 3701010101
   ASAM Dataset: EV_AdaptCruisContr2VW526 002011
   ROD: EV_AdaptCruisContr2VW526_002.rod
   VCID: 3A2D35F57CD3EE97C73-806F
Address 8E: Image Processing (J851)       Labels:| 7P6-907-107.clb
   Part No SW: 7P6 907 107 B    HW: 7P6 907 107
   Component: BV-SG         H33 0035
   Serial number: 005000011507157
   Coding: 0AA118040000
   ASAM Dataset: EV_BTR 002001
   ROD: EV_BTR_002.rod
          [No_camera_found_on_startup]
                    Reset counter: 56
                    Mileage: 72009 km
                    Date: 2019.10.09
                    Time: 17:56:04
                    Outside air temperature: 21.0 °C
                    Voltage terminal 15: 14.2 V
                    Control Module temperature: 40.0 °C
End----------(Elapsed Time: 02:20, VBatt start/end: 12.3V/12.3V)-----------
Jef
HQ
Thank you for posing a full Auto-Scan!!! :thumbs:
The J851 is located under the right front seat. The R242 camera is located behind the plastic cover at the top/middle of the windshield. I think you are on the right track with making sure the electrical connections are fully seated.
As for removing or taking things apart, please purchase access to the factory repair manual and spend an evening print-to-PDF everything you can get your hands on.
deadl0ck
Los Angeles, USA
C?ID=383256
Thanks Jeff! I'm not sure why the connections to the J851 would come loose under the seat however I did have one of my fuel pumps fail last year and my car sat at the dealer for 2 months, I vaguely recall someone saying they access part of that under the seats but at the time, the dealer said this was not true. But it makes me wonder if they had to pull some of this apart and loosened something up in the process?
So I previously looked at those service manuals and it seems expensive to just remove a rear view mirror, I guess breaking it is more expensive but if there's any tips on removing the rear view, it would be much appreciated. Buying the VCDS cable was a splurge for me as I suspect this would either be covered under the extended warranty or if I know what happened, I can argue it was done during the fuel pump replacement.
I'll look at these manuals but I don't think I can resolve this in a day for $35 so this is quickly turning into a larger expense than it might be worth. This car is bit more complicated than it needs to be.
Thanks, Zach
PetrolDave
Westbury, UK
C?ID=1423
Just buy a 1 hour subscription to erWin, download ALL the documents relevant to your car and then read them at your leisure - no need to spend $35 :thumbs:
deadl0ck
Los Angeles, USA
C?ID=383256
Hmm, I am not seeing a 1 hour subscription option but entirely possible I am looking in the wrong place. This is what I see from erWin, let me know if I'm missing it or maybe they got rid of the hourly option?
"Choose the subcription term you want:
One day -- $35.00
Three days -- $60.00
One month -- $250.00
One year -- $1,500.00"
Europe has one hour subscriptions. NAR does not.
But as Jef said, you can download (or print to PDF) everything about the vehicle with a 1-day subscription. Put that cost in context compared to buying a repair proper manual, which was always double, triple, or more than that $35 depending on the car.
deadl0ck
Los Angeles, USA
C?ID=383256
Well, that's disappointing about the manuals...
I was hoping there would be a bit more detail in the fault code, still seems as though the error could be with the image processor, the camera behind the rear view, or any of the wiring/connectors in between.
I was able to pull both connectors off the processor under the passenger seat and re-seated them, ACC is still disabled but I'm no longer getting the chime 10 seconds after starting so I'll try and go scan, clear it out and scan, maybe there was a loose connection on the easier side.
DV52
C?ID=194404
^^^ So, I haven't tried it - but riddle me this......... what happens if I grab a 1 hr subscription on the non US erwin site and I enter a NAR VIN ?
Does erwin tell me that I'm an illegal immigrant (like Trump and his Mexicans), or do I have access to the NAR database?
deadl0ck
Los Angeles, USA
C?ID=383256
I was wondering the same but since I'm not very familiar with erWin, I figured maybe they only had the right hand drive manuals or something... Maybe they'll redirect you back to the US site depending on your IP address but you can always just use a proxy in that case...
