hi, i have in my garage Golf V 1.4 TSI blg engine with misfire code on 3 and 4 cylinder. Misfire cant "feel" at idle not even while driving. Ecu counts misfire on 4. and 3. cylinder while driving at constant speed, especially on a 4 cylinder, at idle and full throttle not. I try new coil, spark plug, injector swap position, carbon cleaning from intake valve but problem remain at cylinder 3 and 4. compression is same on all cylinder about 11,5bar.
in auto scan missing cylinder 3 code because i clear code earlier. Thanks for help
Thursday,10,October,2019,15:59:29:27545
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZ1KZ8W162858 License Plate:
Mileage: 158510km-98493mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
VIN: WVWZZZ1KZ8W162858 Mileage: 158510km-98493miles
Address 01: Engine Labels: 03C-906-032-BLG.lbl
Part No SW: 03C 906 032 N HW: 03C 906 032 C
Component: MED17.5.1 G 1327
Revision: 96H07--- Serial number: VWX7Z0G83N60XX
Coding: 0000072
Shop #: WSC 01279 785 00200
VCID: 285F25169B98820FCF-807C
2 Fault Found:
000772 - Cylinder 4
P0304 - 000 - Misfire Detected
Fault Status: 01110000
Mileage: 158512 km
Time: 01:42:36
RPM: 2351 /min
Load: 12.5 %
Speed: 33.0 km/h
Temperature: 64.0°C
Temperature: 20.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction
Mileage: 158027 km
Time: 12:42:31
RPM: 2299 /min
Load: 12.9 %
Speed: 44.0 km/h
Temperature: 43.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
Readiness: 0110 0001
Revision: 00H11001
Coding: 0019074
VCID: 73E5027A12DEB1D7AA-8026
Part No SW: 1K0 907 044 CQ HW: 1K0 907 044 CQ
Component: ClimatronicPQ35 130 1212
Revision: 00130022 Serial number: 00000000000000
VCID: 78FF35560BB8D28F9F-802C
00716 - Air recirculation Flap Positioning Motor (V113)
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000007716338
Coding: 018F8F2700041500471400001400000000097F075C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 71E9087268C283C758-8024
Component: Wischer 301007 021 0501
Coding: 00038805
Fault Status: 00101100
Fault Frequency: 46
Reset counter: 222
Mileage: 157048 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.40 V
Reset counter: 211
Mileage: 158295 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 9.40 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1K071Z
Coding: 0013111
Shop #: WSC 01269 785 00200
VCID: 3D71E442641A37A78C-8068
Subsystem 1 - Serial number: 6332MSME27156412%
Subsystem 2 - Serial number: 6342MSME30311318Z
Subsystem 3 - Serial number: 6352QSME3D6C4F3B1
Subsystem 4 - Serial number: 6362QSME3F7A095F%
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000042
VCID: 7F0DDE4A2E96E5B7DE-802A
00576 - Terminal 15
Part No SW: 1K0 920 864 G HW: 1K0 920 864 G
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0G83N60XX
Coding: 0007103
Shop #: WSC 00011 888 06946
VCID: 306FCD76A348CACF17-8064
Reset counter: 210
Mileage: 158295 km
Time: 09:58:40
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 251007F1000204
Coding: E9801F0E0002020000
Component: IMMO VDD 1212
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1207
Coding: 0000052
VCID: 3979F05270320B87A0-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3561FC625C2AEFE744-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 00C802087F2D840548CA03E010CC
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000308
VCID: 3A7BEF5E7534009FA9-806E
Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
Component: Radio BVX 035 0048
Revision: 00035000 Serial number: VWZ1Z2G6318816
Coding: 0040400
VCID: 68DF65165B18420F0F-803C
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D51D402B47AA7273C-8078
End-------------------------(Elapsed Time: 01:39)--------------------------
