Results 1 to 4 of 4
Thread: Mk6 Golf R XDS Question
    May 2019
    US/NH
    I have been looking through VCDS more to learn how things look and experiment with a few features. One thing I came across was this post https://www.golfmk6.com/forums/showthread.php?t=25039 showing some easy adjustments that can be done with the Mk6 Golf R. Specifically looking at the XDS adjustments that are mentioned, I went looking into my own settings and see this:
    I thought that was a bit weird, but if I go into the long coding section to see if I can get an explanation, I see this:
    So basically, I am wondering if this would seem expected (i.e. if that box is unchecked then it would make sense to not see the channel in group 36, which I guess means someone else has changed these settings before me), or am I actually missing something in the car but it isn't giving me any errors or codes that would trip anything? This is a used car and it was involved in a crash, but I can't imagine this was part of something that was missed when putting it back together...or essentially what else comprises the XDS system that I should check to make sure my car hasn't been messed with?
    Auto-scan just in case. I know there are some things in the 09 module, but I am not concerned about them and it's an entirely different module so I don't think there should be any effect on what I am trying to figure out.
    Thursday,10,October,2019,14:41:19:00174
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
              56 62 72
    VIN: WVWPF7AJ3DW048799   Mileage: 94660km-58818miles
    Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0030
       Revision: 5BH21---    Serial number:
       Coding: 0403010A180F0160
       VCID: 34311D5A023B65471DF-8060
       Revision: 00H31001
       Coding: 144BE00C49268002281207ED92220141B70000
       VCID: 7DA7F87E7DF1640FA21-8028
       Revision: 00085000    Serial number: 0179501623
       Coding: 03000C
       VCID: 34311D5A0EBB65471DF-8060
       Part No SW: 5K0 907 044 GP    HW: 5K0 907 044 GP
       Component: Climatronic   H19 1212
       Revision: 00001004
       Coding: 0018002002
       VCID: 7F5B0276777D761FB0D-802A
       Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
       Component: BCM PQ35  B   111 0709
       Revision: AB111709
       Coding: 6F180A3FF8232AC4108820C175000D0448FD2086777D8DB0E48400248040
       VCID: 3537205E05417C4F2A1-8060
       Component: Wischer 25061  26  0512
       Coding: 009795
                        Reset counter: 110
                        Mileage: 86422 km
                        Date: 2013.11.19
                        Time: 13:00:37
                        Voltage: 12.40 V
                            Term 50 Off
    00061 - Footwell Lights
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 47
                        Mileage: 86422 km
                        Date: 2013.11.19
                        Time: 13:02:36
                        Voltage: 14.10 V
                            Term 50 Off
    00955 - Key 1
                        Fault Status: 01100101
                        Reset counter: 163
                        Mileage: 89216 km
                        Date: 2013.12.17
                        Time: 12:45:37
                            Term 15 Off
                        Voltage: 12.75 V
                            Term 50 Off
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R006V4A
       Coding: 00004733
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C21357A26EBAD07D5F-8068
       Serial number: ---0000R--000049EX00
       Serial number: 3572MSME4828246FZZZ%
       Serial number: 3582MSME6E07426EZZZ4
       Serial number: 3512QSME64271808ZZZR
       Serial number: 3522QSME72571918ZZZW
       Serial number: 35527SME6A01132DZZZC
       Serial number: 35627SME5168572DZZZO
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Revision: FF010041    Serial number: 20120629301185
       Coding: 100A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DA7F87E7D71640FA21-8028
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
       Part No SW: 5K6 920 973 E    HW: 5K6 920 973 E
       Coding: 271F00
       VCID: 392F2C6E29D9982FCE9-806C
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 290612F2000650
       Coding: 350002
       VCID: 3FDB4276377DB61FF0D-806A
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 45D7509E59A1ECCFBA1-8010
       Coding: 000007
       VCID: 6A8DC3221CFFE3B7773-803E
       Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
       Component: ELV-PQ35      H20 0240
       Revision: 00000000    Serial number: 12000151108003
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2F3B1236E79D469F60D-807A
       Component: SG EXT.PLAYER H18 0530
       Revision: A1001003    Serial number: 7662968956
       Coding: 020100
       VCID: 2A0D0322DCFF23B7B73-807E
       Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
       Component: RNS315-NAR    H53 0319
       Serial number: VWZAZ2M4252898
       Coding: 04050001010005000000100A
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 2517F01EB5610CCF9A1-8070
    1048669 - Tuner for Satellite Radio
              B11CF 53 [009] - Deactivated
                        Reset counter: 110
                        Mileage: 86422 km
                        Date: 2019.06.29
                        Time: 13:00:39
       Coding: 0001204
       VCID: 313F144EFD29506F769-8064
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 251    3305
       Revision: 00H22000
       VCID: 372B2A56134D8E5F38D-8062
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0035332
       VCID: 290FFC2ED97928AFBE9-807C
       Coding: 0001204
       VCID: 323D1B42F82F6B770F3-8066
       Coding: 1479708
       Coding: 00000022
       Coding: 00000022
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 3537205E09417C4F2A1-8060
       Coding: 0001168
       VCID: 363527521447775723B-8062
    End----------(Elapsed Time: 01:22, VBatt start/end: 12.2V/12.2V)-----------
    Not sure whether your ABS doesn't support the XDS function or whether it has to be enabled in the Coding before the Adaptation channel becomes available.
    I don't think there's much harm in turning on that bit to see if the channel does become available. I think the worst case is the ABS will give you a Request Out of Range error if it doesn't support XDS.
    Oct 2014
    The 1K0 907 379 BL in my car certainly supports XDS and I'm sure that adaption channel is available once it's been enabled
  4. Likes Uwe liked this post
    May 2019
    US/NH
    Thanks for the quick replies. I think that makes sense what both of you are saying, and I was probably going to try checking the box at some point, just wanted to see if I could get some quick feedback before messing with it. As it turns out, I did a little more searching after posting this, and it seems that XDS is not actually enabled by default, which seems counter-intuitive to how most of these electronic systems work, especially considering it takes coding to fully disable ESC.
    So I think you actually have to go in to the long coding first, enable that byte/bit, and then you can adjust the strength in the adaptation. I plan on going with an LSD when its time to change the clutch, so I am actually going to keep it off. I just mainly wanted to try and figure out if the previous owners had been in there (so maybe I need to go dig for more changes) or if something was somehow wrong with the car (again, since I figured these electronic systems are usually enabled by default). For once, the car manufacturers and I agree on something!
    This also doesn't seem to be Mk6 Golf specific, and it seems most modern VWs (2010-ish +) have this ability in them, but they are disabled by default.
