2011 A6 C6 4F0 [09 Central Electric] issue
Fat
USA, E Coast
C?ID=381732
After receiving my VCDS i made an attempt to correct an (newly discovered after springs/struts) issue with my steering wheel not moving up / down (telescope is fine).
Steering Column Adjustment Prerequisites:
1.Steering Column or Central Electronics Control Module (J519) have been replaced or,
2.Approach and adjust all 4 end positions (up, down, forward, back).
[09 Central Electronics]
[04 Basic Settings] Group 001 [Go!]
Activate the Basic Setting. [ON/OFF/Next]
The adjustment should now be learned. adjust all 4 end positions (up, down, forward, back).
[Done, Go Back]
[Close Controller, Go Back - 06]
** HAVE NOW DISABLED POWER Steering Column Basic Setting - Group
** 001 – Disabled Voltage Supply (Terminal 30 left)
I have the following coding in [09] and am looking for help to get rid of the DIS warn.
all bulbs are tested and sockets are fresh.
I am wondering how to ENABLE voltage back to the Terminal 30 Left and confirm.
*hope this is the fix.
 Saturday,28,September,2019,15:25:00:43223
Mileage: 164640km-102302mi   Repair Order:
   Part No SW: 4F0 910 279 AE    HW: 4F0 907 279 A
   Component: ILM Fahrer      H30 0390
   Coding: 0133122
   Shop #: WSC 02335 785 00200
   VCID: 6C81C4456A817A17061-8038
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
                    Fault Status: 01111011
                    Fault Frequency: 15
                    Reset counter: 110
                    Mileage: 163256 km
                    Date: 2019.07.11
                    Time: 19:40:00
                    Reset counter: 110
                    Mileage: 164620 km
                    Date: 2019.09.27
                    Time: 09:18:00
Fat
USA, E Coast
C?ID=381732
sure,
so this is the first error log i recorded immediately after trying the above reset.
 Saturday,28,September,2019,10:39:33:43223
                Address 09: Cent. Elect.  (4F0 910 279 AE)
10:39:25 Group 001: Steering Column Basic Setting
  N/A  Voltage Supply (Terminal 30 right)
  N/A  Rotary Light Switch
  N/A  Emergency Flasher Button
First full code (unfortunately key in acc, NOT on)
Chassis Type: 4F0
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 72 76
   Mileage: 164640km-102302miles
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603001628256
   Coding: 0000007
   Shop #: WSC 02323 785 00200
   VCID: 2517F161C9EB8B5F99F-8070
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01110010
                    Reset counter: 117
                    Mileage: 151342 km
                    Date: 2018.07.28
                    Time: 19:41:04
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000030574263
   Coding: 0524326
   Shop #: WSC 02325 785 00200
   VCID: 1D67D981E1BB439FC1F-8048
   Coding: 0133122
                    Fault Frequency: 15
                    Reset counter: 110
                    Mileage: 163256 km
                    Date: 2019.07.11
                    Time: 19:40:00
                    Reset counter: 110
                    Mileage: 164620 km
                    Date: 2019.09.27
                    Time: 09:18:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1577C1A1158B1BDF09F-8040
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H09 0209
   Revision: 00000000    Serial number: FKX40JX7A
   Coding: 83DF0A050B00CF05010201
   Shop #: WSC 02391 823 56573
   VCID: 313F15318123D7FF757-8064
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L10807002A
   Coding: 000303
   VCID: 392F2D1159531FBFCD7-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790360108
02076 - Media Player Position 1 (R118)
                    Reset counter: 142
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 14:36:02
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 12
                    Bin. Bits:    10011
01304 - Radio
                    Reset counter: 142
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 15:48:44
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 7
                    Bin. Bits:    10011
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00001002044805
   Coding: 00581B00004011110000
   VCID: 323D1A3D8425ECE70CD-8066
Address 46: Central Conv.
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000103255
   Coding: 05000000
   VCID: 290FFD51A9F3AF3FBD7-807C
Address 4C: Tire Pressure II
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000737459
   Coding: 0002014
   VCID: 5EE59E8DAC3D1887985-800A
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 471H 0A7522656
   Coding: 020007010000000000
   VCID: 2411EC65CED172578E1-8070
   Part No SW: 4E0 035 664 E    HW: 4E0 035 664 A
   Component: H-BN-NA       H49 0189
   Revision: --------    Serial number: 488H40A7537327
   Coding: 010200000202E3EF41000F05EF6300030000
   VCID: 2615F66DB8ED8047905-8072
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466H/0A0079843
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001661693
   Component: CD-Database  1886
                    Reset counter: 102
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 13:40:38
                    Voltage: 12.10 V
Address 62: Door, Rear Left
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Serial number: 12391020308021
   Coding: 0021206
   VCID: 290FFD51A5F3AF3FBD7-807C
End----(Elapsed Time: 01:15, VBatt start/end: 11.7V/11.6V. VIgn 0.0V)------
Adaptation Channel 062:
Stored value
  ERROR:
  Security
  access
  required
Address 09,4F0 910 279 AE,channel 3,adapted from,24,to,50,
Address 46,4F0 910 289 N,channel 62,adapted from,7,to,11,
Address 52,4F0 959 792 T,recoded (Long Coding),from,011F57204E40410001,to,011F57205E40410001,(02391/823/56573),
Address 76,4L0 910 283 B,recoded (Short coding),from,0021206,to,0221206,(02323/785/00200),
Fat
USA, E Coast
C?ID=381732
todays diagnostics and additional data:
Friday,04,October,2019,16:11:10:43223
Dealer/Shop Name: TPC
VIN: WAUKGAFB0BN024708   License Plate:
16:11:04
  13.300 V   Voltage Supply (Terminal 30 left)
Address 09,4F0 910 279 AE,channel 28,adapted from,1,to,1,
Address 6C,4F0 910 441 D,channel 13,adapted from,50,to,60,
Address 17,4F0 920 983 H,recoded (Long Coding),from,83DF0A050B00CF05010201,to,83570A050B00CF05010201,(02391/823/56573),Thursday,10,October,2019,14:49:24:43223
14:49:20 Group 001: Steering Column Basic Setting
Thursday,10,October,2019,14:48:55:43223-VCID:6C81C4456A817A1705F-8038,VCDS Version: Release 19.6.2 (x64),Data version: 20190930 DS308.0
4F0 910 279 AE,,ILM Fahrer      H30 0390,
,Group A:,'001,,,,Group B:, Not Running,,,,Group C:, Not Running
,,Voltage Supply,Voltage Supply,Rotary,Emergency,,,,,,,,,,
,TIME,(Terminal 30 left),(Terminal 30 right),Light Switch,Flasher Button,TIME,,,,,TIME,,,,
Marker,STAMP,,,,,STAMP,,,,,STAMP,,,,
,0.04,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.12,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.25,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.37,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.50,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.62,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.76,Disabled,N/A,N/A,N/A,,,,,,,,,,
,0.89,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.01,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.15,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.26,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.39,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.52,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.64,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.77,Disabled,N/A,N/A,N/A,,,,,,,,,,
,1.90,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.02,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.14,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.27,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.39,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.52,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.64,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.77,Disabled,N/A,N/A,N/A,,,,,,,,,,
,2.89,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.00,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.13,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.28,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.39,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.52,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.66,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.79,Disabled,N/A,N/A,N/A,,,,,,,,,,
,3.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.17,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.43,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,4.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.16,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,5.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.16,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.30,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.56,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.66,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.81,Disabled,N/A,N/A,N/A,,,,,,,,,,
,6.93,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.17,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.43,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.54,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.66,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.81,Disabled,N/A,N/A,N/A,,,,,,,,,,
,7.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.16,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.30,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,8.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.16,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,9.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.17,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,10.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.17,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.30,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.81,Disabled,N/A,N/A,N/A,,,,,,,,,,
,11.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.06,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.16,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
1,12.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.67,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,12.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.05,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.16,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.31,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.43,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.56,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.68,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.80,Disabled,N/A,N/A,N/A,,,,,,,,,,
,13.92,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.06,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.17,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.30,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.42,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.55,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.68,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.81,Disabled,N/A,N/A,N/A,,,,,,,,,,
,14.94,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.07,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.19,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.33,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.45,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.59,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.71,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.83,Disabled,N/A,N/A,N/A,,,,,,,,,,
,15.95,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.09,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.20,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.33,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.46,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.58,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.70,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.83,Disabled,N/A,N/A,N/A,,,,,,,,,,
,16.95,Disabled,N/A,N/A,N/A,,,,,,,,,,
Dana
Western PA, USA
The full scan above is missing communication to most of the critical modules in the vehicle. Please scan it again, with the ignition on or better yet engine running at idle, and post those results.
Doing so should allow us to determine if you truly have a Terminal 30 left issue (such as a blown or missing fuse).
Fat
USA, E Coast
C?ID=381732
Thanks, I'm more interested in learning where one needs to look in the scan to make this determination.
Scan from yester:
Wednesday,09,October,2019,15:27:33:43223
Mileage: 164930km-102482mi   Repair Order:
Chassis Type: FB-AU56 (4F0)
          56 5F 62 6C 72 76
VIN: WAUKGAFB0BN024708   Mileage: 164930km-102482miles
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H07---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 66565 257 00032
   VCID: 2411EC65C2D172578DF-8070
               U1017 - 000 -  - Intermittent
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:00:35
                    RPM: 1312 /min
                    Mass Air / Rev.: 212.6 mg/str
                    Temperature: 21.0°C
                    Bin. Bits: 00000010
                    Load: 16.5 %
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Mileage: 163935 km
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 27.0°C
                    Bin. Bits: 00000000
                    Voltage: 11.42 V
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0020
   Revision: --H05---    Serial number:        4584852
   VCID: 2A0D025DA0F5A427B73-807E
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E85CE4D5C9D88072BB-803A
   Coding: 0000007
   VCID: 2517F161C9EB8B5F9A1-8070
   Coding: 0524326
   VCID: 1D67D981E1BB439FC21-8048
   Coding: 0113122
   VCID: 6C81C4456A817A1705F-8038
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00053523
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 122
                    Mileage: 164792 km
                    Date: 2019.10.07
                    Time: 18:04:00
                    Reset counter: 122
                    Mileage: 164792 km
                    Date: 2019.10.07
                    Time: 18:04:00
   Revision: AA001001
   VCID: 1577C1A1158B1BDF0A1-8040
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FA001D324
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 3635262D68CDF0C723B-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000004VJ6
   Serial number: 3574SRB40000C50CA96E
   Serial number: 3584SRB40000C3D0E126
   Serial number: 3516HRB402HDKJMQS3HQ
   Serial number: 3526HRB402JDKJMR3BA6
   Serial number: 3554NRB400005C59640.
   Serial number: 3564NRB400005C597A79
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90025101990043
   Coding: 0012141
   VCID: 270BFB69B3E7994FA8D-8072
   Component: E0221           H02 0100
   Coding: 83570A050B00CF05010201
   VCID: 313F15318123D7FF769-8064
   Coding: 000303
   VCID: 392F2D1159531FBFCE9-806C
   VCID: 323D1A3D8425ECE70F3-8066
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0004000149728
   Coding: 011F57204E40410001
   VCID: 48C958D512B97637417-801C
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01344885370000
   Coding: 4618269
   VCID: 35372121794BFBDF2A1-8060
   Coding: 05000000
   VCID: 290FFD51A9F3AF3FBE9-807C
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H03 0110
   Revision: 00000276    Serial number: 00002760031930
   Coding: 0623301
   VCID: 2313EF79C7DF756FF45-8076
   Coding: 0002014
   VCID: 5EE59E8DAC3D18879BB-800A
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0004000150519
   Coding: 011F57205E40410001
   VCID: 47CB5BE91FA7794F48D-8012
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211FE571DDC3677FE69-8074
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Component: AFS 1           H01 0010
   Coding: 0000026
   VCID: 2B030759AF0FBD2F4C5-807E
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   VCID: 2411EC65CED172578DF-8070
   Coding: 010200000002C3EF51000F05EF6300030000
   VCID: 2615F66DB8ED804793B-8072
                    Reset counter: 119
                    Mileage: 164792 km
                    Date: 2019.10.07
                    Time: 18:02:02
                    Voltage: 14.10 V
                    Reset counter: 119
                    Mileage: 164792 km
                    Date: 2019.10.07
                    Time: 18:02:02
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000100 00000000
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0004000151900
   Coding: 010E57204040220001
   VCID: 46D556ED18AD6047B3B-8012
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H04---    Serial number: 525PA8-J0721H3
   Coding: 1000304
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0004000151903
   Coding: 0221206
   VCID: 290FFD51A5F3AF3FBE9-807C
End----(Elapsed Time: 01:51, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
Wednesday,09,October,2019,15:39:47:43223
Adaptation Channel 006:
Stored value 1
Development Test Mode
  N/A
  N/A
  N/A
  N/A
Address 5F,4E0 035 664 E,channel 6,adapted from,1,to,0,
Address 5F,4E0 035 664 E,recoded (Long Coding),from,010200000002C3EF51000F05EF6300030000,to,01020000000243EF51000F05EF6300030000,(02391/823/56573),
          56 5F 62 6C 72 76
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:00:35
                    RPM: 1312 /min
                    Temperature: 21.0°C
                    Bin. Bits: 00000010
                    Load: 16.5 %
                    Mileage: 163935 km
                    Temperature: 27.0°C
                    Bin. Bits: 00000000
                    Voltage: 11.42 V
   Coding: 0020921
   Coding: 0000007
   Coding: 0524326
   Coding: 0113122
   Coding: 00053523
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Revision: AA001001
   Coding: 0012141
   Coding: 000303
   Coding: 4618269
   Coding: 05000000
   Coding: 0623301
   Coding: 0002014
   Revision: --H05---
   Coding: 0000222
   Coding: 0000026
   Coding: 01020000000243EF51000F05EF6300030000
                    Reset counter: 122
                    Mileage: 164935 km
                    Date: 2019.10.09
                    Time: 15:48:50
   Coding: 1000304
   Coding: 0221206
End----------(Elapsed Time: 01:50, VBatt start/end: 14.1V/14.2V)-----------
Fat
USA, E Coast
C?ID=381732
Dana's reply says it all :thumbs:
sure does.
last post included a full scan showing everything.
'if you teach me to hunt, i won't have to be feed'.
So, about the TERMINAL 30 L issue ?
Fat
USA, E Coast
C?ID=381732
term 30 left / steering column (lack of) movement
Any chance that these will help find an answer ?
Fat
USA, E Coast
C?ID=381732
Help with Terminal 30
I need help understanding a Terminal 30 Left issue that hit me after my steering column lost its up and down a few weeks ago.
I made an attempt at the Steering Column Adjustment, as documented at the bottom of this page:
http://wiki.ross-tech.com/wiki/index.php/Audi_A6_(4F)_Central_Electronics
Since this attempt, I have lost the telescope ability, and [Basic Settings] in [module 09] somehow turned off.
I have since searched for a resolve and without any luck, tried to work the issue
Having re-tried to cycle the Basic Settings [ON/OFF/NEXT] i have now somehow
created faults in
[03 abs] terminal 30
[19 can gateway] steering column
[4c tire pressure] abs & steering col
[6c bu cam] steering col
HELP
I just want to get this steering wheel out of "truck driver" mode, and clear these codes. It feels like Harley ape bars when driving.
16:11:04
Saturday,12,October,2019,17:08:08:43223
17:08:06 Group 001: Steering Column Basic Setting
Address 09: DTCs cleared
          56 5F 62 6C 72 76
VIN: WAUKGAFB0BN024708   Mileage: 164950km-102495miles
16-Steering wheel -- Status: Sporadic communication error 1000
4C-Tire Pressure II -- Status: Malfunction 0010
               U1017 - 000 -
                    Fault Frequency: 7
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:00:35
                    RPM: 1760 /min
                    Mass Air / Rev.: 174.4 mg/str
                    Temperature: 24.0°C
                    Bin. Bits: 00000010
                    Load: 15.7 %
                    Mileage: 163935 km
                    Temperature: 27.0°C
                    Bin. Bits: 00000000
                    Voltage: 11.42 V
   Coding: 0020921
                    Reset counter: 124
                    Mileage: 164958 km
                    Date: 2019.10.12
                    Time: 17:04:56
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x018D
                    Hex Value: 0x00FF
   Coding: 0000007
   Coding: 0524326
   Coding: 0113123
   Coding: 00053523
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Reset counter: 124
                    Mileage: 164956 km
                    Date: 2019.10.12
                    Time: 17:15:00
                    Reset counter: 124
                    Mileage: 164956 km
                    Date: 2019.10.12
                    Time: 17:15:00
   Revision: AA001001
   Coding: 0012141
   Coding: 000303
                    Reset counter: 164
                    Mileage: 164958 km
                    Date: 2019.10.12
                    Time: 16:31:18
                    Bin. Bits:    00000
                    Voltage: 11.70 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 3.70 s
   Coding: 4618269
   Coding: 05000000
   Coding: 0623301
                    Fault Status: 11101101
                    Reset counter: 124
                    Mileage: 164958 km
                    Date: 2019.10.12
                    Time: 17:04:57
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 11.30 V
                    Temperature: 24.0°C
                    (no units): 0.0
                    Reset counter: 124
                    Mileage: 164958 km
                    Date: 2019.10.12
                    Time: 17:04:55
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 11.30 V
                    Temperature: 24.0°C
                    (no units): 0.0
   Coding: 0002014
   Revision: --H05---
   Coding: 0000222
   Coding: 0000026
                    Reset counter: 123
                    Mileage: 164953 km
                    Date: 2019.10.11
                    Time: 16:34:37
   Coding: 1000304
                    Fault Status: 01101101
                    Reset counter: 124
                    Mileage: 164958 km
                    Date: 2019.10.12
                    Time: 17:18:13
                        Reverse OFF
                    Count: 3
   Coding: 0221206
End----------(Elapsed Time: 01:52, VBatt start/end: 13.3V/13.9V)-----------
Dana
Western PA, USA
With the exception of extremely low (11.1 V) voltage in measuring block group 001 your Terminal 30 readings appear to be perfectly fine. Both left and right are identical so I don't suspect a blown fuse or similar problem on the vehicle exists.
In regards to the voltage, I would recommend using a battery charger when the ignition is on without the engine running for an extended amount of time. Alternatively, you could start the engine but some operations should not be completed at idle so that method isn't ideal in all cases.​
I believe you may be using the label file based Measuring Block descriptions as a guide for Basic Settings. Those are two entirely different functions and Audi may not have documented the data under Basic Settings for this particular group. In those cases you can disregard the labeling entirely, because it does not pertain to Basic Settings, but using the [ON/OFF/Next] button should have flipped the status of Off to On at the top of the Basic Settings screen. Additionally most modules confirm calibrations buy showing Learned, Adp OK or similar after using [ON/OFF/Next] so it would be interesting to see a screen shot with it On to see if Basic Setting 001.1 still shows Disabled.
Either way, I'm not entirely sure if your original steering column concern is resolved. Let us know if the up/down function is OK or not.
Fat
USA, E Coast
C?ID=381732
Hi Dana,
Thanks for taking a look at the scans.
Agree on the fuses, I've checked everything and the connections are spotless and not-corroded.
Battery was low on power at time of scan, but that was a temporary event that has no effect on the issue.
So as to how to re-engage the column, after following the data here, and also below for reference: ross tech wiki index Audi A6 (4F) Central Electronics
Having followed this, with the exception of (Approach all 4 end positions (up, down,),
i am now without any movement in the steering column.
The [ON/OFF/Next] does activate the motors for a second or two and then all goes quiet on the eastern front.
Basic Setting
Prerequisites:
Steering Column or the Central Electronics Control Module (J519) have been replaced.
Approach all 4 end positions (up, down, forward, back).
[Select]
[09 - Central Electronics]
[Basic Settings - 04]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Thanks again Dana, and very interested in learning how to solve these issues.
Fat
USA, E Coast
C?ID=381732
So I wanted to follow up on the successful repair of this failure.
Taking the literal approach to this, I disconnected the steering column plugs (think there were four), and loosened the 4 bolts holding the column in place in an effort to un-bind any mechanicals.
After powering up the car, i processed the up / down to full range, as well as the telescopic full range., i.e.;
[Select]
Group 001
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Once I set the xolumn to a comfortable position, I torqued the mounts, and turned the memory OFF.
hope this may help someone else with stuk column.
