Results 1 to 3 of 3
Thread: Golf mk7 retrofit PLA 3.0
    Nov 2018
    Malaysia
    Hi everyone,
    i have upgraded my 8K ops sensor to 12k PLA3.0.
    i have coded module 10(PLA), module 44(steering assist), module 17( instruments).
    however im still having this error in my PLA module.
    [Bremsensteuergerät - ESP_33 - kein Signal/keine Kommunikation]
    OPS 360 works fine. but auto park is not functioning.
    if i'm not mistaken i have to change ABS pump coding as well, but i'm not sure which bit and bytes i have to change.
    Thank you in advance
    Wednesday,09,October,2019,20:07:04:55008
    VIN: WVWZZZAUZEW259316   License Plate: GOLF GTI
    Mileage: 6607km-4105mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 65
              A5 A9
    VIN: WVWZZZAUZEW259316   Mileage: 6607km-4105miles
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
       Component: 2.0l TVS ST3  H13 0099
       Revision: --H13---
       Coding: 091D00324464050B3000
       ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
       ROD: EV_ECM20TFS0205G0906259C.rod
       VCID: 2E100CF671C1A53F05-807A
    Readiness: 1110 0001
       Part No SW: 0D9 300 043 T    HW: 02E 927 770 AQ
       Component: DQ250-6F TVS  H52 9699
       Revision: 05852204    Serial number: TFK01312100544
       Coding: 0018
       ROD: EV_TCMDQ250021.rod
       VCID: 2B1605E242D3D01722-807E
              P1734 00 [002] - -
       Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
       Component: ESC           H31 0557
       Revision: 00000000    Serial number: 635330000000C9
       Coding: 01FA93A134252975037A060181C9A980C92C94C0608195F7F84250884006
       VCID: 7CB4F6BEF73D87AFFB-8028
       Revision: 00021000    Serial number: 0322827289
       Coding: 030C0C
       VCID: 3A3830A6BD89799FA9-806E
       Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00120004100100001105004011101800
       VCID: 383C2AAE83856B8F5F-806C
       Air quality sensor:
       Part No SW: 5Q0 937 085 T    HW: 5Q0 937 085 T
       Component: BCM MQBAB HNA H16 0124
       Serial number: 00011400700350
       Coding: 03011B42424122FB49E44080B10C07281800000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 012001
       ROD: EV_BCMBOSCH_012.rod
       VCID: 4AD86066ED69E91F39-801E
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    131215  042 0551
       Serial number:         131218213128
       Component: RLFS  024 0042
       Serial number: Y14M01D10H14M24S33S9
       Coding: 37E8DD
    264452 - No Communications with Anti-Theft Sensor
              U10F4 00 [009] - -
              [Sensor-DWA->kein Signal/ Kommunikation]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:46
    267012 - No Communications with Anti-Theft Siren / Alarm Horn
              U10F3 00 [009] - -
              [Sirene-DWA->kein Signal/Kommunikation]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:46
       Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0050
       Serial number: 000308417618093
       Coding: 0371161851
       Shop #: WSC 00046 123 12345
       ASAM Dataset: EV_EPHVA2CAU3700000 009041
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 51EA770A003FDAC778-8004
    12656926 - Databus
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 20:02:08
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
       Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
       Component: ACC Bosch MQB H04 0200
       Serial number: 27121376510845
       Coding: 021C1700FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001014
       VCID: 3620249689919DFF4D-8062
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H15 0115
       Serial number: 09121341350245
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76A0E496C911DDFF8D-8022
       Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
       Component: AirbagVW20    014 0386
       Serial number: 003MLR02PY9E
       Coding: 98FCC0C0000000005C5400CF00C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F4E01B2E62B9CB7DE-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169677B10011471324
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169676B07011470241
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 201 14
       Serial number: 35767000000804957E0W
       Subsystem 4 - Part No SW: -----------    HW: 480 000 201 14
       Serial number: 35867000000182817E0R
       Subsystem 5 - Part No SW: -----------    HW: 480 400 201 14
       Serial number: 3516502A912FAE31706E
       Subsystem 6 - Part No SW: -----------    HW: 480 402 012 13
       Serial number: 3526502A311FBE92228F
       Subsystem 7 - Part No SW: -----------    HW: 480 401 912 13
       Serial number: 3556502AD11FBE95310N
       Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 02011404400818
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 7BB6F5A2F2338097F2-802E
       Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
       Component: KOMBI         403 4191
       Coding: 27BD11987E94000E02887E070400000000000000
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 14051910003292
       Coding: 030100042B085900FF00027E9C0F00010001000100000000000000000000
       Shop #: WSC 00046 000 00000
       ROD: EV_GatewConti_013.rod
       VCID: 79BAEFAAF80FB287E0-802C
       Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H06 0038
       Serial number: 27130001973530053492
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 7873132203
       Revision: 00000000    Serial number: 13000294093004
       Coding: DD00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34241E9E9FED8FEF73-8060
       Serial number: 21121302090982
       Coding: 003F1320D001048000001000
       Shop #: WSC 39426 001 1048576
       VCID: 40CC424EDB55234FE7-8014
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001490259
       Coding: 1D0000
       Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
       Component: EPS_MQB_ZFLS  503 5043
       Coding: 9303
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3522239A949796E744-8060
       Serial number: 20121301100624
       Coding: 003F1120DE01048000801000
       VCID: 3FCE41B2A6AB5CB79E-806A
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000001412506
       Coding: 050000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Component: AFS-ECU       H07 0080
       Coding: 029603000B010200
       VCID: 3D323BBAACA74EA78C-8068
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
       Part No SW: 3Q0 035 866 C    HW: 3Q0 035 866 C
       Component: MU-S-N-CN     852 0870
       Coding: 02731012FF00000041150001001028001F0703D601200500C6
       Shop #: WSC 00078 790 00051
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 33261D829AE388D76A-8066
       Subsystem 1 - Part No SW: 5G6 919 605 F    HW: 5G6 919 605 F
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZJV3122165
       Subsystem 2 - Part No SW: 3G0 919 866 Q    HW: -----------
       Component: CHN 2015  --- 0630
              B201A 00 [009] - -
              [Check software version management]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:47
                        Voltage terminal 30: 11.6 V
                        Status_Software_Version_Management-module_name: C
              U1101 00 [009] - Active
              [Anti-theft protection - component protection active (0xEA6300)]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:47
                        Voltage terminal 30: 11.8 V
    7170 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:50
                        BAP-BAP_Function_ID: 02
              U1111 00 [008] - -
                        Reset counter: 207
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:50
    1637 - Interface for External Media
              U11B8 00 [009] - No Communications
              [USB - communication error]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 19:50:47
                        Interface for external media: status-Status: Open circuit
       Serial number: 40000000214041
       ROD: EV_RDKBERU30_006_VW37.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0051
       Serial number: 10000026169
       Coding: 0101010000020303000400000101010100
       ROD: EV_MFKBoschAU370.rod
    2555904 - Databus
              [PSD_01_TO_FAILURE]
                        Reset counter: 167
                        Mileage: 6607 km
                        Date: 2019.10.09
                        Time: 20:03:34
                        Control Module temperature: 56 °C
                        Outside air temperature: 26.5 °C
                        Vehicle speed: 0.00 km/h
                        Voltage terminal 15: 11.7 V
                        Terminal 15 on: 108.9 s
       Part No SW: 5G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0013
       Serial number: 131128200368
       VCID: 6B96C5E28253101762-803E
    End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
    Oct 2017
    Northwest UK
    Hi
    You need to activate 01 Engine byte3 bit 5, 03 ABS byte 26 to either 50 or F0.
    May 2017
    Try this as your ABS coding :
    01FA93A134252975037A060181C9A980C92C94C0608195F7B84250884006
    Your byte 26 should be fine as you have ACC already. Byte 24 bit 5 & 6 have PLA coding.
  4. Likes Uwe liked this post
