Hi everyone,
i have upgraded my 8K ops sensor to 12k PLA3.0.
i have coded module 10(PLA), module 44(steering assist), module 17( instruments).
however im still having this error in my PLA module.
[Bremsensteuergerät - ESP_33 - kein Signal/keine Kommunikation]
OPS 360 works fine. but auto park is not functioning.
if i'm not mistaken i have to change ABS pump coding as well, but i'm not sure which bit and bytes i have to change.
Thank you in advance
Wednesday,09,October,2019,20:07:04:55008
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZEW259316 License Plate: GOLF GTI
Mileage: 6607km-4105mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 65
A5 A9
VIN: WVWZZZAUZEW259316 Mileage: 6607km-4105miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l TVS ST3 H13 0099
Revision: --H13---
Coding: 091D00324464050B3000
ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
ROD: EV_ECM20TFS0205G0906259C.rod
VCID: 2E100CF671C1A53F05-807A
Readiness: 1110 0001
Part No SW: 0D9 300 043 T HW: 02E 927 770 AQ
Component: DQ250-6F TVS H52 9699
Revision: 05852204 Serial number: TFK01312100544
Coding: 0018
ROD: EV_TCMDQ250021.rod
VCID: 2B1605E242D3D01722-807E
P1734 00 [002] - -
Part No SW: 5Q0 907 379 AB HW: 5Q0 907 379 H
Component: ESC H31 0557
Revision: 00000000 Serial number: 635330000000C9
Coding: 01FA93A134252975037A060181C9A980C92C94C0608195F7F84250884006
VCID: 7CB4F6BEF73D87AFFB-8028
Revision: 00021000 Serial number: 0322827289
Coding: 030C0C
VCID: 3A3830A6BD89799FA9-806E
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120004100100001105004011101800
VCID: 383C2AAE83856B8F5F-806C
Air quality sensor:
Part No SW: 5Q0 937 085 T HW: 5Q0 937 085 T
Component: BCM MQBAB HNA H16 0124
Serial number: 00011400700350
Coding: 03011B42424122FB49E44080B10C07281800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_012.rod
VCID: 4AD86066ED69E91F39-801E
Component: WWS 131215 042 0551
Serial number: 131218213128
Component: RLFS 024 0042
Serial number: Y14M01D10H14M24S33S9
Coding: 37E8DD
264452 - No Communications with Anti-Theft Sensor
U10F4 00 [009] - -
[Sensor-DWA->kein Signal/ Kommunikation]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:46
267012 - No Communications with Anti-Theft Siren / Alarm Horn
U10F3 00 [009] - -
[Sirene-DWA->kein Signal/Kommunikation]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:46
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417618093
Coding: 0371161851
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51EA770A003FDAC778-8004
12656926 - Databus
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 20:02:08
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 B HW: 5Q0 907 572 B
Component: ACC Bosch MQB H04 0200
Serial number: 27121376510845
Coding: 021C1700FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001014
VCID: 3620249689919DFF4D-8062
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 09121341350245
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76A0E496C911DDFF8D-8022
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR02PY9E
Coding: 98FCC0C0000000005C5400CF00C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F4E01B2E62B9CB7DE-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B10011471324
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B07011470241
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 201 14
Serial number: 35767000000804957E0W
Subsystem 4 - Part No SW: ----------- HW: 480 000 201 14
Serial number: 35867000000182817E0R
Subsystem 5 - Part No SW: ----------- HW: 480 400 201 14
Serial number: 3516502A912FAE31706E
Subsystem 6 - Part No SW: ----------- HW: 480 402 012 13
Serial number: 3526502A311FBE92228F
Subsystem 7 - Part No SW: ----------- HW: 480 401 912 13
Serial number: 3556502AD11FBE95310N
Part No SW: 5Q0 953 507 EC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 02011404400818
Coding: 0C10
ROD: EV_SMLSKLOMQB_010_VW37.rod
VCID: 7BB6F5A2F2338097F2-802E
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 403 4191
Coding: 27BD11987E94000E02887E070400000000000000
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 14051910003292
Coding: 030100042B085900FF00027E9C0F00010001000100000000000000000000
Shop #: WSC 00046 000 00000
ROD: EV_GatewConti_013.rod
VCID: 79BAEFAAF80FB287E0-802C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0038
Serial number: 27130001973530053492
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 7873132203
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 13000294093004
Coding: DD00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34241E9E9FED8FEF73-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 21121302090982
Coding: 003F1320D001048000001000
Shop #: WSC 39426 001 1048576
VCID: 40CC424EDB55234FE7-8014
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001490259
Coding: 1D0000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 9303
ROD: EV_SteerAssisMQB_010.rod
VCID: 3522239A949796E744-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 20121301100624
Coding: 003F1120DE01048000801000
VCID: 3FCE41B2A6AB5CB79E-806A
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001412506
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029603000B010200
VCID: 3D323BBAACA74EA78C-8068
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 3Q0 035 866 C HW: 3Q0 035 866 C
Component: MU-S-N-CN 852 0870
Coding: 02731012FF00000041150001001028001F0703D601200500C6
Shop #: WSC 00078 790 00051
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 33261D829AE388D76A-8066
Subsystem 1 - Part No SW: 5G6 919 605 F HW: 5G6 919 605 F
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZJV3122165
Subsystem 2 - Part No SW: 3G0 919 866 Q HW: -----------
Component: CHN 2015 --- 0630
B201A 00 [009] - -
[Check software version management]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:47
Voltage terminal 30: 11.6 V
Status_Software_Version_Management-module_name: C
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:47
Voltage terminal 30: 11.8 V
7170 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:50
BAP-BAP_Function_ID: 02
U1111 00 [008] - -
Reset counter: 207
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:50
1637 - Interface for External Media
U11B8 00 [009] - No Communications
[USB - communication error]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 19:50:47
Interface for external media: status-Status: Open circuit
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000214041
ROD: EV_RDKBERU30_006_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 E HW: 5Q0 980 653
Component: MQB_MFK H05 0051
Serial number: 10000026169
Coding: 0101010000020303000400000101010100
ROD: EV_MFKBoschAU370.rod
2555904 - Databus
[PSD_01_TO_FAILURE]
Reset counter: 167
Mileage: 6607 km
Date: 2019.10.09
Time: 20:03:34
Control Module temperature: 56 °C
Outside air temperature: 26.5 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 11.7 V
Terminal 15 on: 108.9 s
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 131128200368
VCID: 6B96C5E28253101762-803E
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
