Hi
I have factory auxiliary heating for Audi. When pushing off button on air conditioner button heater will shutdown. Is it possible make coding so that when push aircon off button only ventilation closes not aux heater. Aux heater continues heating until timer runs out.
Thursday,08,August,2019,10:31:27:48855
VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4508.4
VIN: License Plate:
Mileage: Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 28 34 36 3B 42 44 46
47 52 53 55 56 5F 62 69 6C 6D 72 A9 C0
VIN: Mileage:
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 C HW: 4G0 907 589
Component: 3.0BTD EDC17 H23 0001
Revision: 57H23---
Coding: 322A403A25360B020000
ASAM Dataset: EV_ECM30BTD0114G0907589C 001001
ROD: EV_ECM30BTD_AU57.rod
VCID: 34311D7ABEB082D71E1-8060
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4G0 927 158 AA HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1003
Revision: --H16---
Coding: 000001
ASAM Dataset: EV_TCMAL551211 002018
VCID: 6D87C81E9D1A131F11F-8038
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 49A7C70592E5E3A0EB00
VCID: 36352772A8CC90C7205-8062
Part No SW: 4H0 907 064 CP HW: 4H0 907 064 CP
Component: BCM2 2.0 H32 0421
Coding: 05A92F46000000000000
VCID: 79AFEC4ED9D2BFBF8D7-802C
Serial number: 2312000183867004
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 23091200040379
Coding: 3692007821
VCID: 629DAB2254C45C67BCD-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001619406
Coding: 0907E01009749FE0098100C380001800CF9CE7082E080201000108546F00
VCID: 6FBBD2169796E10F233-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120807 H36 0080
Serial number: 120907192453
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20588658
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 19 09 2012 00001663
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000014091200010008
Coding: 110000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000019091200010521
Coding: 110000
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: C0A80B46000000000001
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4H0 919 475 AF HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0050
Revision: -------- Serial number: 56261225503537
Coding: B9030C
ASAM Dataset: EV_EPHVA2CAU57X0000 002011
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 76B5E772E84CD0C7E05-8022
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00AARA9
Coding: 30323436313330303431554A304C34473053
Serial number: 3575HRB405T1HGMQE1C7
Serial number: 3585HRB40671HA3IB85.
Serial number: 3515JRB40551GLOM98V2
Serial number: 3525JRB405B1GLOMPH36
Serial number: 3554VRB40084ULPIBPGX
Serial number: 3564VRB400U4ULPII21P
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372LIK000JQ
Coding: 000435
VCID: 3829294AA25866B7329-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 08 09 2012 D0113610
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G9 920 950 E HW: 4G9 920 950 E
Component: TDieRdw Nv H78 0515
Revision: 28131207 Serial number: 658170912596047
Coding: 13A621081B410008010600
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 323D1B6244A48CE70CD-8066
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20120822233553
Coding: 5D3F01
VCID: 2411ED3A0ED012578E1-8070
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000692370
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001016
VCID: 71BFD46E8122F7FF357-8024
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790211336
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 12071600000000000191
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
VCID: 7CA1F55AD6E08A97961-8028
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0076
Serial number: 24091200040676
Coding: 21
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008001
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050F12509CA807685-807A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000039835090
VCID: 77ABEA76EFC6A9CFFB3-8022
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA8201C5DZ
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Component: TSG FA H03 0506
Coding: 011F16005E00620002080002
VCID: 47CB5AB6DFA6194F4B3-8012
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0025910425
Coding: 101100010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0184550374
Coding: 013A0E2020B93081832009042001040F0000000000000000000000000000
Component: DWA-Sensor H01 0010
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000006197
Coding: 030000
VCID: 1D67D8DE2DBA239FC1F-8048
Component: TSG BF H03 0506
VCID: 46D557B2D8AC0047B05-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000483495
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B030606638EDD2F4FB-807E
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 120924-0002-039
Coding: 11226F601002A300
ROD: EV_HeadlRegulBasic.rod
VCID: 2D07081E5D9AD31F51F-8078
Part No SW: 4G1 035 053 E HW: 4G1 035 053
Component: Radio U Basic H41 0093
Revision: AB001007 Serial number: 227I 0C7638015
Coding: 010003010000000001
VCID: 211FE42E11C2077FE57-8074
Part No SW: 4G0 035 666 H HW: 4G0 035 666 H
Component: H-BN-EU H49 0526
Revision: -------- Serial number: 189I10C7521572
Coding: 080100050003F3EF4580AB1E00000003E00001020200000000
VCID: 2D07081E5D1AD31F51F-8078
Subsystem 1 - Part No: 8R0 060 884 AH
Component: EUR 2012 1308
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC9402LDW9
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Component: E380 BDT C7 H11 0204
Serial number: 90349LIJ0007V
Component: CD-Database 3638
Component: TSG HL H03 0506
Coding: 010F14004000620002080002
VCID: 49CF5C8EC9B2EF3F5D7-801C
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000184211264
Coding: 0109080000000000
VCID: 71BFD46E81A2F7FF357-8024
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J28G6X7
Coding: 1090005
VCID: 2615F73274ECE047905-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 235200428
Coding: 097205C011
ROD: EV_HDSGAu571.rod
VCID: 3537207EB5CA9BDF29F-8060
Component: TSG HR H03 0506
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120831201177
ASAM Dataset: EV_SoundActuaGen2AU64X 002005
ROD: EV_SoundActuaGen2AU64X_002.rod
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0004
Serial number: 120902200078
VCID: 2411ED3A0E5012578E1-8070
0006 - Actuator 1 for Engine Noise Simulation
C113C 13 [008] - Open Circuit
Fault Frequency: 54
Reset counter: 217
Mileage: 119404 km
Date: 2019.08.07
Time: 08:22:11
End----(Elapsed Time: 02:26, VBatt start/end: 11.8V/12.0V. VIgn 12.0V)-----
