I have an intermittent fault occurring on the oil thermal sensor in my Yeti. It's probably the sensor itself, but as a temporary measure is it possible to simply code out the sensor to stop the bloody warning light flashing up every few miles when it decided it wants to?
Wednesday,09,October,2019,18:45:44:61903
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4505.4
VIN: TMBMD75L2G******* License Plate: YETI
Mileage: 111980km-69581mi Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 22 25 2B 42 44 46 52 55 5F 61
62 72
VIN: TMBMD75L2G******* Mileage: 111980km-69581miles
Address 01: Engine (J623-CUUB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 J HW: 04L 907 309 K
Component: R4 2,0L EDC H20 1186
Revision: 8AH20---
Coding: 01190012042701091000
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_ECM20TDI01104L906016J 001003
ROD: EV_ECM20TDI01104L906016F_001.rod
VCID: 303A1AB3CAAC4F777A9-8064
Part No SW: 1K0 907 379 CB HW: 1K0 907 379 CB
Component: ESP MK60EC1 H46 0174
Revision: 00H46001
Coding: 933F400E09240103C90E02EB9020809AA1000021
VCID: 74B2D6A37EB43357DE1-8020
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0370993080
Coding: 030C0C
VCID: 372821AF2FC2984F3B3-8062
Part No SW: 3T0 907 044 CJ HW: 3T0 907 044 CJ
Component: Climatronic H19 0709
Revision: 00001009
Coding: 0010000003
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 7CA2FE8356647B17961-8028
9472881 - Motor for Fresh Air / Recirculated Air Flap
B108B 71 [008] - Actuator stuck
Reset counter: 155
Mileage: 105409 km
Date: 2019.07.22
Time: 10:11:48
9472882 - Motor for Fresh Air / Recirculated Air Flap
B108B 54 [009] - Missing Calibration / Basic Setting
Reset counter: 211
Mileage: 105310 km
Date: 2019.07.21
Time: 16:42:37
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
B109B 15 [008] - Open or Short to Plus
Reset counter: 142
Mileage: 110233 km
Date: 2019.09.24
Time: 14:42:43
Part No SW: 1K0 937 087 AR HW: 1K0 937 087 AR
Component: BCM PQ35 H 112 0903
Revision: AC112903
Coding: 4E000ABCE01BF1C0440800C0110089E44B7100AE666D87F08081C704A041
Shop #: WSC 73430 790 00063
VCID: 015C8F77310616FFC57-8054
Subsystem 1 - Part No: 5L2 955 119 B Labels: 1KX-955-119.CLB
Component: SK356 26 0610
Coding: 00F7B5
Component: RLS 150915 05 54 0403
Coding: 062BED
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 C HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0011
Revision: --H11--- Serial number: 32961525500848
Coding: 108007
ASAM Dataset: EV_EPHVA14SKxxx0000 002001
ROD: EV_EPHVA14SKxxx0000_002.rod
VCID: 35342BA735CE6A5F29F-8060
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 014 0613
Serial number: 003G5RAV523G
Coding: 00004E42
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 313C1FB7C1A6467F757-8064
Serial number: 3572MSME65011E53ZZZS
Serial number: 3582MSME4F642C54ZZZ3
Serial number: 3516KSME2C064939ZZZY
Serial number: 3526KSME6A094939ZZZ/
Part No SW: 5K0 953 521 DT HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20150904300396
Coding: 1002140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 015C8F77318616FFC57-8054
Subsystem 1 - Part No SW: 5E0 919 719 L HW: 5E0 919 719 L
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000B0968110915
Coding: 820000
Part No SW: 5L0 920 940 T HW: 5L0 920 940 T
Component: KOMBI H03 1007
Coding: 420E210100
ROD: EV_Kombi_UDS_VDD_RM09_005_SK26.rod
VCID: 3D2433870DFEB21FE1F-8068
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Reset counter: 115
Mileage: 111987 km
Date: 2019.10.09
Time: 18:41:23
Part No SW: 7N0 907 530 BE HW: 7N0 907 530 AL
Component: J533 Gateway H58 1673
Revision: H58 Serial number: 170915F1003184
Coding: 356323
Shop #: WSC 30504 002 1048576
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7531
Serial number: HA1-00029.07.15
Coding: 0301
Shop #: WSC 73430 790 00999
VCID: 52FE703BA4605D672CD-8006
Component: IMMO H03 1007
Coding: 000007
VCID: 6A8EC8DB2CF0F5A774D-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000193421008
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 J HW: 7N0 959 793 G
Component: TSG FA H04 0561
Revision: Serial number: 0000165582676
Coding: 01150220D001231003
VCID: 49CC575749B61EBF5D7-801C
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
VCID: 392C279715568E3FCD7-806C
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 J HW: 7N0 959 792 G
Component: TSG BF H04 0561
Revision: Serial number: 0000167133767
Coding: 01150020D001231003
VCID: 48CA525352BCE7B7429-801C
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 03DE00003F000000
Subsystem 1 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 B Labels: 3D0-941-329.CLB
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5L0 035 200 C HW: 5L0 035 200 C
Component: MU-S-D-ER H22 0245
Serial number: SKZAZ2R8856584
Coding: 03130600FF00000011111201008800002F0000C60120810000
ROD: EV_MUStd4CTSAT_SK35.rod
VCID: 1E66D40BA038C907D85-804A
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1673
Coding: 030F1873
VCID: 71BCDFB701A6067F357-8024
Component: J367-BDM H07 0180
Serial number: 42251412211491655569
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-795.clb
Part No SW: 7N0 959 795 F HW: 7N0 959 795 E
Component: TSG HL H04 0561
Revision: Serial number: 0000166784151
Coding: 010000200001531004
VCID: 47C8516F5FA2E8CF4B3-8012
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-795.clb
Component: TSG HR H04 0561
Revision: Serial number: 0000166784145
End----------(Elapsed Time: 01:20, VBatt start/end: 12.1V/12.1V)-----------
