Results 1 to 10 of 13
Thread: Active Lane Assist "bouncing" After ABS Update
    Sep 2017
    Australia
    During the last Audi service there was a software/firmware update performed on the ABS for my model MY17 FL S3. Not sure how it’s connected but as a consequence of this update the ALA now doesn’t keep the car in the marked lane if I let go of the steering wheel. The car now “bounces” between the lane markings. Prior this update the car stayed perfectly between the lane markings. I have the Active Lane Assist set to “Early” in the MMI. I think I've seen somewhere that there is a VCDS tweak to help with the "bouncing" but alas I can't find it. Anyone up to speed on ALA?
    Tango Red S3 MY17 | Mirror Pkg | Black Pkg | Roof Rails Black | SPP 1 | Asst Pkg | Design Selection 2 | Privacy | Panoramic Sun Roof |
    ^^ I note from a previous auto-scan HERE that the value of Byte 14 on the hex A5 module (Frnt_Sens_Drv_Assist) was hexA9 - which means that the upper nibble for this Byte had a value of hexA0 in Long Coding Helper Screen speak. So (like my A3) your car was factory set for 'late" point-of-intervention - which does tend to give the driver a type-of ping-pong affect
    Anyhow, perhaps change to early point-of-intervention (i.e. hex80 )-see below, much better IMO
  3. Likes Uwe liked this post
    Dec 2016
    Amsterdam
    Check the car settings in the MMI, there should be an additional option to enable ‘adaptive’ lane assist which keeps the car a set distance between the lines instead of only correcting when you reach a marking, and that option could have been reset to factory settings.
    Current:
  5. Likes Uwe liked this post
  6. #4
    Sep 2017
    Australia
    Quote Originally Posted by MasterTommy View Post
    Thanks but I don't have that option (adaptive) in the MMI.
    Sep 2017
    Australia
    Thanks Don. Setting to "80 Point of Intervention, early (setting via menu)" appears to have fixed it. I wonder what option "00 Point of Intervention, Early) is compared to the via menu option?
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by larsmate View Post
    The cluster or infotainment menus are optional, and may not be present on some cars or some regions. Think branding and packaging, country-of-import regulatory requirements, etc. A better way to phrase those config options might be:
    • Always early
    • Always late
    • Driver configurable, factory default to early
    • Driver configurable, factory default to late
    Silence gives consent.
  9. Likes Uwe, DV52 liked this post
  10. #7
    Sep 2017
    Australia
    • Always early
    • Always late
    That makes sense!
  11. #8
    Dec 2019
    Canada
    • Always early
    • Always late
    Which one is the adaptive lane assist? I have mine set to configurable/default early but the Adaptive is unchecked. Does that mean late intervention = adaptive?
  12. #9
    findcoop: Hi,
    If Mr Young will forgive me for stealing his thunder - I suspect that there is a misunderstanding of terms: the driver assist systems are Adaptive Cruise Control and separately Lane Assist. The former uses conventional CC technology plus it can maintain a driver-selectable distance (time gap) from the vehicle in front. The latter uses the front camera on the windscreen to identify the lane boundary lines. If the vehicle seems likely to leave the lane without an active steering manoeuvre by the driver, then the system automatically counteracts this. So, Lane Assist (different to Lane Change Assist) is not "adaptive" in the true sense of the term - and if it is "adaptive (by definition), the term isn't normally applied to the function (IMO).
    MasterTommy (who introduced "adaptive" to the discussion) added quote-marks in his post to indicate that his use of the term "adaptive" was not standard when referring to the lane assist - at least. that's how I read his post.
  13. Likes jyoung8607 liked this post
  14. #10
    Dec 2019
    Canada
    findcoop: Hi,
    If you do the VCDS tweak, adaptive lane tracking becomes an option under lane assist. In this mode, the car tries to stay centred instead of only taking action when the vehicle approaches the lane boundary. I'm seeking the setting that makes the adaptive mode default, whereas now it is exposed in the menu, but I have to click it again after each vehicle start.
