Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Golf MKVII - dealership coded extra key and modules lost
    Sep 2014
    Guatemala
    hello everybody,
    Client went to the dealership to have a 2nd key programmed as the car didn't bring any as it was imported used from USA, after they programmed it EPC light present on the dash, bluetooth connection lost from MIB and selectable driver modes (eco, comfort, sport) lost. Client is now so no chance to have any prior information.
    Wednesday,09,October,2019,15:08:23:22246
    VIN:   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 47 52 55 5F 75 A9
    VIN:    Mileage: 70615km-43878miles
    Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00124424002F1000
       Shop #: WSC 20318 002 1048576
       ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
       ROD: EV_ECM20TFS0205G0906259D.rod
       VCID: 2F3B105AA798221F60D-807A
    17169 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [175] - -
                        Fault Frequency: 13
                        Mileage: 70577 km
                        Date: 2019.10.08
                        Time: 09:40:06
                        Coolant temperature: 100 °C
                        Intake air temperature: 82 °C
                        Ambient air pressure: 850 mbar
                        Voltage terminal 30: 12.343 V
                        ACC variants (coding): ACC with braking until at standstill/Stop & Go
                        CCS Switch: CCS operating unit
                        Cruise control switch actuation-Main switch hardware: not activated
                        Cruise control switch actuation-Main switch CAN: not activated
                        ACC variants: ACC
                        Engine: operating status: ES
    22008 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [040] - -
                        Mileage: 70577 km
                        Date: 2019.10.08
                        Time: 09:40:06
                        Unlearning counter according OBD: 36
                        ECU_STATE: ENG_STOP
                        Engine oil temperature: 101.0 °C
                        Time since engine start: 0.0 s
                        T_ES: 0 min
                        STATE_ERR_ABC_PRED: 18
    Readiness: 0010 0001
       Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
       Component: DQ250-6V MQB  H53 4902
       Revision: 06253104    Serial number: TFK01511021387
       Shop #: WSC 00066 790 00218
       ROD: EV_TCMDQ250021.rod
       VCID: 1C61D796C62EA98735F-8048
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 50266000000046
       Coding: 01FA6BA15425096D007C020141C66880D62A9000408216B600430051C009
       Shop #: WSC 01383 790 50316
       VCID: 4BC364CA33407E3F6C5-801E
       Revision: 00021000    Serial number: 0388615095
       Coding: 030C0C
       VCID: 3A2D310E6CDAF7B7C73-806E
       Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
       Revision: 00001K01
       Coding: 00020014200100000005000012111402
       VCID: 42DD49EE040ABF779F3-8016
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 86581712151008
       Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AADF10E2C5A37B7873-802E
       Component: WWS    150814  043 0581
       Serial number:         160217215211
       Component: RLHS  037 0059
       Serial number: S3Y15M12D21H16M25S02
       Coding: 90A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
       Component: J245 PS60.036  H06 0150
       Serial number: 03691620731508151551
       Coding: 181803
    12307 - License Plate Light
              B12CA 01 [009] - Electrical Failure
                        Reset counter: 76
                        Mileage: 70577 km
                        Date: 2019.10.08
                        Time: 09:24:59
       Serial number: 003GCR03Z3U0
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB58FA2F289A5F48D-8012
       Occupant Detection:
       Component: BF-Gewichtss.  H12 0021
       Serial number: IBH0000000000046A06T
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 000 212 15
       Serial number: 35700000000DD361681N
       Subsystem 3 - Part No SW: -----------    HW: 480 000 112 15
       Serial number: 35800000000F3DD8A710
       Subsystem 4 - Part No SW: -----------    HW: 480 403 011 15
       Serial number: 35100029B1E3EA92F24J
       Subsystem 5 - Part No SW: -----------    HW: 480 400 412 15
       Serial number: 3520002B91E3EA9541DK
       Subsystem 6 - Part No SW: -----------    HW: 480 400 611 15
       Serial number: 3550002C31DCBE12826E
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 611 15
       Serial number: 35600029B1D3F980D33I
       Revision: FF033033    Serial number: 20151118500838
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 04518FF65E9E7147EDF-8050
       Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
       Component: KOMBI         342 6420
       Coding: 0BAD091AA980CF0502086A001000000000000000
       Shop #: WSC 00066 790 00225
       VCID: 2C010756968E590745F-8078
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 10121510801821
       Coding: 0101000830085900FB00022B1C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07025
       ROD: EV_GatewConti_013.rod
       VCID: 79AFEE02295C3CAF8E9-802C
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29150002294390025473
       Coding: 31FFFF
       Revision: 00000000    Serial number: 15000236126006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311F364EBE01C71DF-8060
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8042
       Serial number: HA1-00028.09.15
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       Serial number: 260116060500V2
       Coding: 003E13200000020000000000
       VCID: 43D34CEA1B10B67F945-8016
       Serial number: 00000000000011189404
       Coding: 011000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 8102
       VCID: 392F2E0269DCFCAFCE9-806C
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA01A0P%
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
       VCID: 6D87CA526D14900F121-8038
    0532 - Rear Right Bass Speaker
              B1067 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
                        Reset counter: 80
                        Mileage: 70615 km
                        Date: 2019.10.09
                        Time: 15:00:26
                        Voltage terminal 30: 12.5 V
    0565 - Loudspeaker 1 in Double-Subwoofer
              B130C 13 [009] - Open Circuit
                        Reset counter: 80
                        Mileage: 70615 km
                        Date: 2019.10.09
                        Time: 15:00:26
    0570 - Loudspeaker 2 in Double-Subwoofer
              B130D 13 [009] - Open Circuit
                        Reset counter: 80
                        Mileage: 70615 km
                        Date: 2019.10.09
                        Time: 15:00:26
       Serial number: 250116060507BJ
       Coding: 003E13200C00020000000000
       Shop #: WSC 12345 123 61029
       Serial number: 00000000000011433967
       Coding: 091000
       Coding: 021A01010B000400
       VCID: 40D943E60A06AD67897-8014
       Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 0004
       Coding: 2E0000
       Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 0004
       Coding: 2E0000
       Part No SW: 3Q0 035 876     HW: 3Q0 035 876
       Component: MU-S-NS-US    820 0613
       Coding: 027300020000000051220002001808001F0207F401200105C6
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 71BFD622712C74EF369-8024
       Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
       Component: ABT_Std-2_Nav  H53 1031
       Serial number: VWZ8Z9RJX001N3
       Subsystem 2 - Part No SW: 3G0 919 866 R    HW: -----------
       Component: NAR 2016  --- 0321
              B11CF 53 [009] - Deactivated
                        Reset counter: 76
                        Mileage: 70577 km
                        Date: 2019.10.08
                        Time: 09:25:50
                        Voltage terminal 30: 14.0 V
                        SDARS_tuner_status_2-Antenna current: 131 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 76
                        Mileage: 70577 km
                        Date: 2019.10.08
                        Time: 09:25:17
                        BAP-BAP_Function_ID: 02
       Component: OCULowMQBUS   007 0568
       Coding: 02730002C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       Serial number: 151204200460
       VCID: 6B83C44A53009E3F0C5-803E
    End----------(Elapsed Time: 01:40, VBatt start/end: 12.5V/12.5V)-----------
    Scratching head. ECU is not coded for ACC, so not clear to me why it has a U0235 fault.
    ^^^ hmm...... scratching too - do you have the following channels in hex19 module and what's their setting (2nd channel probably doesn't matter)?
    IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control
    ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control
    Sep 2014
    Guatemala
    I will check tomorrow and post, it doesn't make sense what they did to disable stuff on the car it doesn't make sense if it is just a key programming and they said, hey that is normal it will work in a couple of days oh and EPC will shut off by itself.
    sam: it's a very long shot because the auto-scan doesn't show an error when the Gateway tried to unsuccessfully poll a fictitious ACC module.
    Dallas (McKinney) ,TX ,USA
    Try recode ECU with some different option , then recode it back to original coding .It may work.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  7. Likes Uwe, Jack@European_Parts liked this post
    Sep 2014
    Guatemala
    I am never able to get the images right so here it goes
    https://imgur.com/XoRUhqY
    https://imgur.com/2NQMDji
  9. #8
    Sep 2014
    Guatemala
    Quote Originally Posted by Jetta ,97 View Post
    The problem is the original coding seems to be tampered, or you say use the same string after changing some bits.
  10. #9
    Quote Originally Posted by sama13 View Post
    OT but I have to ask....
    Who at Ross-Tech is going to hold up their hand and admit to spelling Braking incorrectly as "Breaking"
  11. Likes Uwe, Dana, DrPeter, Jack@European_Parts, Bwant liked this post
  12. #10
    Jun 2014
    Newcastle, England
    Careful Dave, it may have been Niels who wrote the English data for that; and English is not his first language.
  13. Likes PetrolDave liked this post
