Thursday,10,October,2019,10:51:15:51689
VCDS Version: 19.6.2.0 (x64)
VIN: TMBEB6NJ7GZ126270 License Plate: 98RD85
Mileage: 56509km-35113mi Repair Order:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: TMBEB6NJ7GZ126270 Mileage: 56509km-35113miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2707
Revision: 33H20000
Coding: 01110052020405080000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM10MPI01104C906057AB 001003
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 65C5E93764A82F6734-8030
4101 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
P0219 00 [096] - -)
4261 - System Voltage
P0562 00 [096] - Too Low
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08507584151222
Coding: 41F5247D492533C6091610700051822492CC9008000DCA098F00
Shop #: WSC 13765 031 00000
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: 3779737F8E846DF756-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6V0 820 045 A HW: 6V0 820 045 A
Component: AC Manuell H01 0202
Serial number: 1512041B-0540
Coding: 100000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 306B48636BEABACF17-8064
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 C HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0086
Serial number: 001588208904
Coding: 0C0008404215405B43804000400703080000D800510A3500000000000000
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005.rod
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6V1 959 801 B HW: 6V1 959 801 B
Component: FHSG DRV 007 0001
Serial number: 00000000000002800773
Coding: 011200
8714 - Bulb for Left Fog Lamp
B121F 15 [008] - Open or Short to Plus
Reset counter: 107
Mileage: 56509 km
Date: 2019.10.09
Time: 15:19:06
8970 - Bulb for Right Fog Lamp
B1220 15 [008] - Open or Short to Plus
Reset counter: 107
Mileage: 56509 km
Date: 2019.10.09
Time: 15:19:06
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 K HW: 6C0 959 655 K
Component: VW20Airbag743 002 0380
Revision: -------- Serial number: 003TJ000R9CD
Coding: 88CCC000000000005C5400CF000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3B716F4FB2AC4997B2-806E
Subsystem 1 - Part No SW: ----------- HW: 410 821 512 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00BB1DF141241BQ
Subsystem 2 - Part No SW: ----------- HW: 410 821 512 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A91DF1412435K
Subsystem 3 - Part No SW: ----------- HW: 442 151 912 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1E52A54F1CY
Subsystem 4 - Part No SW: ----------- HW: 442 151 512 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A000A294A82A667F
Part No SW: 6V0 920 740 A HW: 6V0 920 740 A
Component: KOMBI 205 1420
Coding: 072401002180000801082A001000000000000000
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 3361476F9AFC81D76A-8066
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H08 0086
Revision: -------- Serial number: 001588208904
Coding: 030100042F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
Subsystem 1 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000A1951081215
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 62348E55122821185237
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: CG1D0551
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6DD59117BC5817277C-8038
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-ENT2.clb
Part No SW: 6V0 035 871 B HW: 6V0 035 871 B
Component: MU-E--ER 852 6490
Serial number: 03121500012119
Coding: 03620000BE0000001111000401000A002F0000C40000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 36677E7B898E94FF4D-8062
End-------------------------(Elapsed Time: 02:11)--------------------------
