Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: VW Caddy 2013, Lane Assist Install from 2018, issue with fault code
    Tartu, Estonia
    Finally cleared.
    I was suspecting the issue was with too old ABS. Bought newer abs, but didn't get to point of changing it. It's PITA with DPF in the way.
    But as my cold idle was getting even worse i decided to investigate and was hoping not the worst with these engines. - But it was, 3rd conrod was bent.
    After lowering the engine, it was the most convenient way to replace ABS on this car. But, the line thought some effort needs to be put into job. They were stuck..... But nothing little patience doesn't solve.
    Many hours later, car with new conrod, ton of gaskets and new thermostat, engine is back in and now every fault is cleared. With MK60EC1 coding-magic I have also HHC and XDS now.
    I might also update ABS SW due to those TPMS issues that I think were described in Dana's car thread.
    Thursday,16,January,2020,22:33:48:39429
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    Dealer/Shop Name: Tarfor OÜ
    VIN: WV2ZZZ2KZDX   License Plate: MINU CADDY HILLHOLD TPMS XDS
    Mileage: 181170km-112573mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 4C 4F 52 5F 69 A5
    VIN: WV2ZZZ2KZDX   Mileage: 181170km-112573miles
    Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 8013
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114016032400080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023PC 003009
       ROD: EV_ECM16TDI02103L906023PA.rod
       VCID: F6A09EF2495DB8FF0D-80A2
    Readiness: 0110 0000
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 423C400D092703FA420B02E6901EC041A10C0032
       Shop #: WSC 00020 790 12345
       VCID: FEB086D2696DF0BF55-80AA
       Part No SW: 5K0 907 044 GL    HW: 5K0 907 044 GL
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004002
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: FBB68FC6727FE59772-80AE
       Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
       Component: BCM PQ35 B+   021 2068
       Revision: BB021001
       Coding: 411A0A3A80251A6B0888008A910000E407F172885223A960648020000040
       Shop #: WSC 63672 002 1048576
       VCID: C2C832225D15545F71-8096
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 12091  26  0512
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 080515 03  37  0059
       Coding: 0228DD
       Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
       Component: VW10Airbag01P H07 0013
       Revision: --------    Serial number: 003HN009XDCO
       Coding: 000000000000000000000000000000003150
       VCID: B32667E61AAFEDD7EA-80E6
       Serial number: 3495RRB405P1BBHA79ES
       Serial number: 3505RRB405N1BBHALGI0
       Part No SW: 5K0 953 501 CS    HW: 5K0 953 569 AL
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20141113201093
       Coding: 308A240000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: FDB281DE6C6BEBA74C-80A8
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0255998
       Coding: 820000
       Part No SW: 2K5 920 886 E    HW: 2K5 920 886 E
       Component: KOMBI         H04 2010
       Coding: 110A010000
       Shop #: WSC 65498 595 77785
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
       VCID: B83C50CA03C90E8FDF-80EC
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 C
       Component: Standheizer     044 4840
       Revision: 00044000    Serial number: 09024302000000
       Coding: 0031012
       Shop #: WSC 00999 444 64523
       VCID: B52259FEDCDBF3E7C4-80E0
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AJ
       Component: J533  Gateway H51 1682
       Revision:   H51       Serial number: 18011400F15339
       Coding: 357400
       Shop #: WSC 00015 115 00050
       VCID: FBB68FC67A7FE59772-80AE
       Component: IMMO          H04 2010
       VCID: EA98BA820DE56C1F99-80BE
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2109
       Coding: 0000048
       Shop #: WSC 35110 377 08192
       VCID: C8DC200ABB297E0FAF-809C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       Shop #: WSC 00046 000 00000
       VCID: B93A55CEF0C3178720-80EC
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
       Component: EZE_2         H51 1682
       Coding: 00000000
       VCID: EFAEAB963E078937CE-80BA
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000048
       VCID: C7DE2336B6377177A6-8092
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0472
       Serial number: VWZAZ2U1626823
       Coding: 06330701BE0000001111000100090A001F010004002001008E
       ROD: EV_MUStd4CTSAT_SK26.rod
       VCID: A50289BEA47B836774-80F0
       Subsystem 1 - Part No SW: 5NA 919 866 AG    HW: -----------
       Component: ECE AS 2020  --- 1310
       Revision: 3A001001    Serial number: 00008030287892
       Coding: 410D000100000000
       VCID: B02C68EAE3B9D6CF97-80E4
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H06 0610
       Serial number: 14091711P12027
       Coding: 0103040201000401002213018080880090000E00002000
       ASAM Dataset: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB_002_VW36.rod
       VCID: C0CC382A5B19464F67-8094
    End----------(Elapsed Time: 01:03, VBatt start/end: 13.9V/13.9V)-----------
    The world is my oyster...
  2. #12
    May 2017
    Looks good! Good to hear that now everything works as it should.
  3. Likes Dana liked this post
