Results 1 to 10 of 10
Thread: VW Caddy 2013, Lane Assist Install from 2018, issue with fault code
    Tartu, Estonia
    Did another Lane assist, pretty used to this by now. New windshield, wiring, cover etc.... .
    Did also RLS, but that is another story.
    I was able to code everything and everything works as supposed to. Lane Assist is OK, HBA is also OK, sign assist works partial because of RNS315 - waiting for DM. What I do not like is 1 fault code in A5-Camera that seems to be related ABS. Do You think if I put newer ABS it will send needed signal or I really need 7E0 ABS as used in 2016+ Caddys.
    I think this Lane Assist camera was also used in Passat NMS which still had MK60EC1 ABS?
    PS! If Dana/Sebastian/Niels reading, LCode helper seems to be missing coding description for Caddy.
    EDIT: Odis doesn't have suggestions about this fault and doesn't create task for Test Plan.
    Wednesday,09,October,2019,20:10:08:39429
    VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Tarfor OÜ
    VIN: WV2ZZZ2KZDXxxxxxx   License Plate: CADDY LANE INSTALL
    Mileage: 174110km-108186mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 4C 4F 52 56 69 A5
    VIN: WV2ZZZ2KZDXxxxxxx   Mileage: 174110km-108186miles
    Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 8013
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114016032400080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023PC 003009
       ROD: EV_ECM16TDI02103L906023PA.rod
       VCID: F6A09EF2495DB8FF33-80A2
    Readiness: 1110 1000
       Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
       Revision: 00H31001
       Coding: 423C400D092703FA420B02E6901EC041300400
       Shop #: WSC 35110 377 08192
       VCID: FCB48CDA7F71E2AF45-80A8
       Part No SW: 5K0 907 044 GL    HW: 5K0 907 044 GL
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004002
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: FBB68FC6727FE5974C-80AE
       Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
       Component: BCM PQ35 B+   021 2068
       Revision: BB021001
       Coding: 411A0A3A80251A6B0888008A910000E407F172885223A960648020000040
       Shop #: WSC 63672 002 1048576
       VCID: C2C832225D15545F4F-8096
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 12091  26  0512
       Coding: 009795
       Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
       Component: RLS 080515 03  37  0059
       Coding: 0228DD
       Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
       Component: VW10Airbag01P H07 0013
       Revision: --------    Serial number: 003HN009XDCO
       Coding: 000000000000000000000000000000003150
       VCID: B32667E61AAFEDD7D4-80E6
       Serial number: 3495RRB405P1BBHA79ES
       Serial number: 3505RRB405N1BBHALGI0
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90849LII000CO
       Coding: 1082160000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: F2A8A2E22535A4DF1F-80A6
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0255998
       Coding: 820000
       Part No SW: 2K0 920 875 L    HW: 2K0 920 875 L
       Component: KOMBI         H05 0705
       Coding: 181A01
       VCID: B83C50CA03C90E8FE1-80EC
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 C
       Component: Standheizer     044 4840
       Revision: 00044000    Serial number: 09024302000000
       Coding: 0031012
       Shop #: WSC 00999 444 64523
       VCID: B52259FEDCDBF3E7FA-80E0
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AJ
       Component: J533  Gateway H51 1682
       Revision:   H51       Serial number: 18011400F15339
       Coding: 357400
       Shop #: WSC 00015 115 00050
       VCID: FBB68FC67A7FE5974C-80AE
       Component: IMMO          H05 0705
       VCID: EA98BA820DE56C1FA7-80BE
       Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
       Component: RNS315-EU   H55 0319
       Serial number: VWZAZ2M5501773
       Coding: 000004110200130000029001
       ASAM Dataset: EV_RNS315EUV2UDS 001705
       ROD: EV_RNS315EUV2UDS.rod
       VCID: AE107692F18DC03FBB-80FA
       Subsystem 1 - Part No: 3AA 919 866 A
       Component: EUR_E_V8  0069
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2109
       Coding: 0000048
       VCID: C8DC200ABB297E0F91-809C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       Shop #: WSC 00046 000 00000
       VCID: B93A55CEF0C317871E-80EC
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
       Component: EZE_2         H51 1682
       Coding: 00000000
       VCID: EFAEAB963E078937F0-80BA
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000048
       VCID: C7DE2336B637717798-8092
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Revision: 3A001001    Serial number: 00008030287892
       Coding: 410D000100000000
       VCID: B02C68EAE3B9D6CFA9-80E4
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H06 0610
       Serial number: 14091711P12027
       Coding: 0103040201000401002200018080880090000E00002000
       ROD: EV_MFKBoschMQBB_002_VW36.rod
       VCID: C0CC382A5B19464F59-8094
    0033 - Databus
              [mBremse_8_BR8_Laengsbeschl_Qbit]
                        Reset counter: 25
                        Mileage: 174111 km
                        Date: 2019.10.09
                        Time: 00:25:09
                        Control Module temperature: 39 °C
                        Outside air temperature: 18.0 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 138.6 s
                        Voltage terminal 15: 11.6 V
                        mid: 02 DD
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
    End----(Elapsed Time: 01:07, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    The world is my oyster...
  2. Likes Uwe, Dana liked this post
  3. #2
    Which controller ?
  4. Likes Dana liked this post
  5. #3
    Tartu, Estonia
    Which controller ?
  6. Likes Dana liked this post
  7. #4
    May 2017
    Have you researched is the ABS block sw upgradeable? If you upgrade to block to higher index?
  8. #5
    I have made update suggestion.
  9. Likes downtime, Dana liked this post
  10. #6
    Tartu, Estonia
    I know older software compatibility updates, but I have no idea about these ones.
    Anyway official file is only for 0152 from 015x series.
    Next one would be 0166 and from there 0174 and 0175. But I don't know if this results in brick or functioning ABS.
    PS! 0164,0166,0172 and 0174 are all supported to flash 1K0907379CC 0175.
  11. #7
    May 2017
    ^ Probably too risky. 16x onwards looks to be H46 so different HW already.
    Is there any functionality restrictions due to this error? It’s missing message and those usually don’t cause any bigger issues.
  12. Likes Dana liked this post
  13. #8
    United States
    I cannot comment on the risk levels of creating a brick but I agree with downtime on the H46 topic. All of the scans we have with SW# 1K0 907 379 CC are: ESP MK60EC1 H46 0175
    I also searched for Component: ESP MK60EC1 H__ 0175 (excluding H46 and the part number) but the results were identical. All SWL 0175s were also H46
  14. Likes golfi_vend, Uwe, downtime liked this post
  15. #9
    Tartu, Estonia
    I've driven 10km since retrofitting, but one who knows me, knows that I dislike such messages and auto-scan has to be fault free.
    I'll search the possibility of connecting 379CC ABS pump to test if it resolves this fault. Also the possibility to even code it in older vehicle.
  16. Likes downtime liked this post
  17. #10
    May 2017
    I fully understand you. I’m the same, I just hate it if there’s errors in the memory
