Results 1 to 2 of 2
Thread: 2012 Audi A6 - Coding Changes Not Permanent
    Nov 2017
    The teardrop wiping on my front wiper irritates me so I found the option in the Central Electric Module to make the "Teardrop Wiping For Front Wiper Inactive". I have this tickbox checked. I also have a tickbox for "Tear Wiping Active" unchecked. The changes were saved it was effective for the first two or three times I used the windscreen washer and then it returned to normal giving me the teardrop wipe. Why can't i disable this permanently?
    I have a similar issue with the Stop/Start, another piece of technology I would really like to disable but so far it keeps coming back. In the Engine module I have "Start/Stop Function Active" unchecked but it still operates. How do I permanently turn it off?
    Also, pretty much every time i carry out an autoscan it comes up with some fault or other, but they differ all the time and I have no issues with the car, the attached scan being a good example. Should these random fault codes bother me?
    Thursday,03,October,2019,13:04:22:45944
    VIN: WAUZZZ4G8CN165114   License Plate:
    Mileage: 137976km-85734mi   Repair Order:
    Chassis Type: 4G-AU57 (4G5)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62 69
              72
    VIN: WAUZZZ4G8CN165114   Mileage: 137976km-85734miles
    Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 311 D    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0003
       Revision: 53H37---
       Coding: 12194012052401020000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907311D 001007
       ROD: EV_ECM30TDI0114G0907311D.rod
       VCID: 2412E429EE50C8A78DF-8070
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Coding: 07A08701E005E1808B00
       VCID: 36362E6148CC4A3723B-8062
       Part No SW: 4H0 907 064 BG    HW: 4H0 907 064 BG
       Component: BCM2 2.0      H31 0333
       Coding: 03993006000000000000
       VCID: 6FB8DB0577963BFF20D-803A
       Serial number: 2312000061223016
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0064
       Serial number: 16041200040477
       Coding: 3622000820
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       Part No SW: 4H0 907 063 BJ    HW: 4H0 907 063 B
       Component: BCM1 2.0      H12 0111
       Revision: 13012002    Serial number: 00000001278715
       Coding: 69080011C034AF600405008300005F5F0F9D860827080101000004402000
       VCID: 71BCDD7D61A22D0F369-8024
       Component: WWS57X 120309  H35 0080
       Serial number:         120317110303
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 20136956
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
       Component: E1 - LDS  H07 0044
       Serial number: 04 04 2012  00000709
       Serial number: 43788226000000000001
                        Reset counter: 18
                        Mileage: 137867 km
                        Date: 2019.10.01
                        Time: 18:48:00
       Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0060
       Revision: 11001001    Serial number: 55901209300226
       Coding: 090207
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_EPHVA18AU57X0000 004005
       VCID: 40DA48B91A08F487897-8014
       Revision: --------    Serial number: 003JG007Y8JK
       Coding: 30323436313330303537554A305234473053
       Serial number: 3575HRB406718NQOG0N+
       Serial number: 3585HRB406918NQO39EV
       Serial number: 3515JRB40104UHL8E9OV
       Serial number: 3525JRB405H184CO3GD7
       Serial number: 3554VRB400M4UHPKGP5$
       Serial number: 3564VRB400M4UHPKIHA$
       Revision: 00000000    Serial number: 20120413001477
       Coding: 000015
       VCID: 303A1879AA286407797-8064
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0009
       Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
       Component: TDieGb        H79 0416
       Revision: 28460177    Serial number: 658030412596020
       Coding: 33A4100003012600010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 3C223C4976E09067D5F-8068
       Part No SW: 4G5 907 468 A    HW: 4G5 907 468
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000457606
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       VCID: 333017755BBE5F1F045-8066
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790807976
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 14011200000000000029
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0009
       Revision: --------    Serial number: EJ1BPA32021L0N0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 6B80CF15430EC7DF0C5-803E
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204001620002080002
       VCID: 42DE42B11484E6979F3-8016
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0026467717
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323E1271A4A456170F3-8066
       Revision: 00002001    Serial number: 0174000125
       Coding: 013B062220B9044083200904000104000000000000000000000000000000
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41DC4DBD1182FD8F869-8014
       Revision: --------    Serial number: 00000000316200
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A0E0A118C741ED7B73-807E
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230DQ0C7556510
       Coding: 010003020100000001
       VCID: 2310E735EBDECF9FF45-8076
       Part No SW: 4G0 035 670 H    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 0526
       Revision: --------    Serial number: 190DM0C7501016
       Coding: 050101010003A1ED05008B3E00000003000001000000000000
       VCID: 280AF01992F82CC7A17-807C
       Subsystem 1 - Part No: 8R0 060 884 DF
       Component: EUR 2016  2204
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC94017AAC
       Subsystem 3 - Part No SW: 4G2 919 710 C    HW: 4G2 919 710 C
       Serial number: 90349LD500108
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 44D244A90E90E8A7ADF-8010
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Towbar module H07 0100
       Coding: 0100000100000000
       Component: TSG HR        H04 0212
    End----------(Elapsed Time: 01:59, VBatt start/end: 12.2V/12.1V)-----------
    Many thanks
    Adam
    United States
    I see you have both Tear Drop Wiping for Front Wiper inactive in address 09 -and- Tear Wiping active unchecked in the WWS slave (wiper motor) so the only thing I can think of that might override coding would be MMI settings. 5F has coding for Menu Wipers active so make sure there isn't an in-car menu for wipers that can be configured. If so, make sure to switch it OFF using both vehicle keys to rule out Key Personalization reverting it back to another configuration.
    I cannot assist with the SS system
    DTC wise, this car has Halogen headlights so the coding of 09 must be incorrect in regards to:
    You may want to revert that controller back to the factory value if unchecking Headlight Regulation active/enabled [PR-8Q3] in address 09 doesn't resolve it. In that case, this thread may be helpful:
    https://forums.ross-tech.com/showthr...y-nets-for-you
  3. Likes Uwe liked this post
