Results 1 to 9 of 9
Thread: 2016 Skoda Yeti Headlight Coding mistake
    Oct 2019
    Hi everyone this is the first time i have needed to use the forum to ask for help. I have made a mistake in coding the Central Electronic module and done something i shouldn't have. I changer the coding in Byte 18 Lighting from standard parameters (00) to Skoda yeti (5l1/sk356) with separate DRLs (1D). I now can't get it back to original settings. The car uses the same bulb for side/corner lights and the DRLs. I now get an error on the side/corner lights as in effect they are no longer there. Please can you help.
    VIN: TMBKC75L7G6024914   License Plate:
    Mileage: 64680km-40190mi   Repair Order:
    Chassis Type: 5L-SK35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61 62 72
    VIN: TMBKC75L7G6024914   Mileage: 64680km-40190miles
    Address 01: Engine (J623-CUUA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 F    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1188
       Revision: 8AH20---
       Coding: 01110012042501090000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_ECM20TDI01104L906016F 001003
       ROD: EV_ECM20TDI01104L906016F_001.rod
       VCID: 2C01F9EA5688E90745F-8078
    17158 - Databus
                        Mileage: 64689 km
                        Date: 2019.10.08
                        Time: 00:38:05
                        Coolant temperature: 33 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 11.780 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 4
                        Drivetrain coordinator: brake function status-Bits 0-7: 32
                        Acceleration: 0.000 m/s²
       Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
       Component: ESP MK60EC1   H46 0174
       Revision: 00H46001
       Coding: 933F200E092405FEC91404E5901DA092A0000021
       Shop #: WSC 33361 790 00063
       VCID: 74B1218ACEB8F1C7DDF-8020
       Part No SW: 3T0 907 044 CD    HW: 3T0 907 044 CD
       Component: Climatronic   H19 0709
       Revision: 00001009
       Coding: 0010000003
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 76B51B82D844E3D7E3B-8022
       Part No SW: 1K0 937 086 AD    HW: 1K0 937 086 AD
       Component: BCM PQ35  M   112 0903
       Revision: AC112903
       Coding: 4E000ABCA01BF1C0400800C0110081EC4B0000AE624D8160E48187000041
       VCID: 72BD2792B4ACFFF7CF3-8026
       Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
       Component: SK356  26  0610
       Coding: 00F7B5
       Subsystem 2 - Part No: 1K8 951 171
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 3
                        Mileage: 64689 km
                        Date: 2019.10.08
                        Time: 00:38:02
                            Term 15 On
                        Voltage: 11.85 V
                            Term 50 On
                        Reset counter: 3
                        Mileage: 64689 km
                        Date: 2019.10.08
                        Time: 00:38:02
                            Term 15 On
                        Voltage: 11.85 V
                            Term 50 On
    Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
       Part No SW: 5J0 919 475 C    HW: 5J0 919 475 A
       Component: PARKHILFE 4K  H11 0011
       Revision: --H11---    Serial number: 32931522902066
       Coding: 108006
       ASAM Dataset: EV_EPHVA14SKxxx0000 002001
       ROD: EV_EPHVA14SKxxx0000_002.rod
       VCID: 3537DC8E85C2A8CF2A1-8060
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Component: AirbagVW10    014 0613
       Serial number: 003G5RAV1YHF
       Coding: 00004E42
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313FE89E71AA84EF769-8064
       Serial number: 3572MSME3A180C53ZZZZ
       Serial number: 3582MSME4F021953ZZZX
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3516KSME41315C38ZZZQ
       Serial number: 3526KSME28493A38ZZZ.
       Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150818101207
       Coding: 1082140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EA503A2F074AB97BBB-802A
       Subsystem 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000C0099010815
       Coding: 820000
       Part No SW: 5L0 920 940 T    HW: 5L0 920 940 T
       Component: KOMBI         H03 1007
       Coding: 720E010100
       ROD: EV_Kombi_UDS_VDD_RM09_005_SK26.rod
       VCID: 3D27C4AEBDF2708FE21-8068
    13654544 - Databus
              [Steuergerät für Telefon keine Kommunikation]
                        Reset counter: 3
                        Mileage: 64689 km
                        Date: 2019.10.08
                        Time: 00:38:03
       Part No SW: 7N0 907 530 BA    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1663
       Revision:   H58       Serial number: 180815F1001925
       Coding: 356323
       VCID: 70B92D9ABAA0CDE7397-8024
                        Reset counter: 3
                        Mileage: 64689 km
                        Date: 2019.10.08
                        Time: 00:38:02
       Component: IMMO          H03 1007
       VCID: 6A8D3FF29CFC3737773-803E
       Part No SW: 7N0 959 793 H    HW: 7N0 959 793 F
       Component: TSG FA        H04 0561
       Revision:             Serial number: 0000162845743
       Coding: 011402208001231004
       VCID: 47CBA646EFAE2A5F48D-8012
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 69     3501
       Revision: 00H22000
       VCID: 392FD0BEA55A4CAFCE9-806C
       Part No SW: 7N0 959 792 H    HW: 7N0 959 792 F
       Component: TSG BF        H04 0561
       Revision:             Serial number: 0000163653720
       Coding: 011400208001231004
       VCID: 46D5AB42E8A43357B3B-8012
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1663
       Coding: 030F1873
       VCID: 71BF289EB1AAC4EF369-8024
       Component: J367-BDM  H07 0180
       Serial number: 42202206241491441790
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
       Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
       Component: TSG HL        H04 0561
       Revision:             Serial number: 0000163662669
       Coding: 010000200001531004
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
       Component: TSG HR        H04 0561
       Revision:             Serial number: 0000164295288
    End----(Elapsed Time: 01:05, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
    Jun 2014
    Swansea, UK
    What do you mean by "I now can't get it back to original settings"?
    Did you save an auto-scan before you made any changes?
    If so, can you not just change the coding back to the previous values?
    Oct 2019
    Yes, we've changed the coding back to previous values but the sidelights still don't work.
    There was a warning on VCDS that changing the coding might cause problems...
    Jun 2014
    Swansea, UK
    Could you also post up the scan from before the change for comparison?
    Oct 2014
    If byte 18 was originally 00, then it might not be possible to restore the original lighting config using VCDS.
    Where in the UK are you?
  6. #6
    Quote Originally Posted by langers2k View Post
    A byte 18 value of 00 masks the true value, it has been posted many times on here that if byte 18 is zero then changing it is likely to end in tears - as OP has found.
    AFAIK the only way to recover is for someone with the dealer tool to restore factory settings?
  7. Likes downtime liked this post
    Nov 2015
    It's a good job Ross Tech post a warning in big red letters, isn't it...
  9. Likes Mike@Gendan, PetrolDave, NZDubNurd liked this post
  10. #8
    Oct 2014
    Other tools will allow EEPROM access so with some experience and a wiring diagram, you can normally generate something close, if not identical to the stock config
  11. Likes PetrolDave liked this post
  12. #9
    Oct 2019
    Sincere thanks to all that posted helpful information, situation was easily rectified today using ODIS
