Hi
I have looked through past postings and cannot get a definite answer.
We have fitted new traditional rear shocks to this vehicle and I am trying to code out the magnetic suspension.
Can anyone help with some instructions on how to complete this process?
Regards
Simon
Regards
Simon
Chassis Type: 8J (1K0)
Scan: 01 02 03 08 09 14 15 16 17 19 22 25 42 44 46 47 52 55
VIN: TRUZZZ8J581016981 Mileage: 128320km-79734miles
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 LA HW: 022 906 032 GP
Component: TT-3.2-DQ-EU4 1056
Revision: 1QH02--- Serial number: AUX7Z0G7FN102E
Coding: 0010178
Shop #: WSC 01236 785 00200
VCID: 55AA7E00FCE485E7A4-8000
Part No SW: 02E 300 011 CC HW: 02E 927 770 AE
Component: GSG DSG 081 1403
Revision: 04608010 Serial number: 00000706290707
VCID: 52A0851CCD0A92DF41-8006
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 HW: 8J0 614 517
Component: ESP MK60E1 0130
Revision: 00H52001
Coding: 0026177
VCID: 6AD03DFC459A3A1F19-803E
Reset counter: 111
Mileage: 128322 km
Count: 192
Count: 4865
Count: 297
Count: 35584
Part No SW: 8J0 820 043 AF HW: 8J0 820 043 AF
Component: J255 Klima 1 Zone 0080
Revision: 00H07003 Serial number: 00000001052647
Coding: 1049670
Reset counter: 151
Mileage: 128322 km
Date: 2019.10.07
Time: 00:03:41
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007456879
Coding: E1061E8380141C00471800001800000000095E075A240802000000000000
VCID: 458AAE400C443567D4-8010
Subsystem 1 - Part No: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0060
Coding: 00064784
Shop #: WSC 01236
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00149804
Shop #: WSC 01236
01117 - Generator Terminal DF Load Signal
Fault Frequency: 32
Reset counter: 135
Mileage: 125910 km
Date: 2019.05.14
Time: 18:05:00
Voltage: 12.85 V
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 8J0 910 376 HW: 8J0 907 376 A
Component: J250 Raddaempfung 0050
Revision: --H16--- Serial number: 190DPH 7067038
Coding: 0000012
VCID: 6CDC3BE44F6E242F6B-8038
00144 - Rear Left Dampening Adjustment Valve (N338)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Reset counter: 111
Mileage: 128322 km
Date: 2019.10.07
Time: 00:03:11
Voltage: 13.56 V
Voltage: 4.95 V
Bin. Bits: 00010010
Bin. Bits: 00010000
Ohms: 0.0
00145 - Rear Right Dampening Adjustment Valve (N339)
Reset counter: 111
Mileage: 128322 km
Date: 2019.10.07
Time: 00:03:11
Voltage: 13.56 V
Voltage: 4.95 V
Bin. Bits: 00010010
Bin. Bits: 00010000
Ohms: 0.0
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K001PFK4
Coding: 0011636
VCID: 79F212B0303C8187E0-802C
Subsystem 1 - Serial number: 6332DRB4058B4918T
Subsystem 2 - Serial number: 6342DRB405DD1226Q
Subsystem 3 - Serial number: 63747RB40268CDC81
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0011111
VCID: 4182BA50186C1947E8-8014
Component: E0221 H03 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 930 E HW: 8J0 920 930 E
Component: KOMBIINSTR. VDO H22 0130
Revision: D0H22001 Serial number: 2247G001011063
Coding: 0097928
Shop #: WSC 52091 001 1048576
VCID: 2E58F1ECB9F2963F05-807A
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0771883EE
Coding: ED8B1F061000024101
VCID: 3064EF94A3C680CF17-8064
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
VCID: 3668D98C41A2AEFF4D-8062
Revision: D0H22001 Serial number: AUX7Z0G7FN102E
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
Part No: 8J8 959 801 B
Component: Tuer-SG H02 0060
Coding: 0000565
VCID: 3C7CCBA47F8E74AFBB-8068
Part No: 8J2 909 143 C
Component: EPS_ZFLS Kl.155 H08 1903
VCID: 3162EA90A8CC89C718-8064
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 C
Component: KSG H10 0080
Coding: 1890300201182D298505489A0167
00956 - Key 2
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 B HW: 8J0 035 223 B
Component: J525 Amp Std H03 0120
Revision: 00H03001 Serial number: 93802003155306
Coding: 0106117
VCID: 234E10D8E2302B579A-8076
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
Part No: 8J8 959 802 B
Coding: 0000565
VCID: 3D7AC6A064947DA78C-8068
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000025
VCID: 295202F0801CF107D0-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
