Results 11 to 20 of 37
Thread: 2005.5 A4 B7 Avant Quattro Automatic TiP - Cranks but wont start died while driving.
    Oct 2019
    Oregon, USA
    No progress yet but im at least learning
    Just tossing this out there... but it would seem that maybe the ECM goes dead at times. Clear codes in all the control modules. Start paying VERY CLOSE ATTENTION to the MIL bulb check when you turn the ignition on... it should always do a bulb check, if not, that implies the ECM isn't talking. Is there a connection between crank/no start and a lack of MIL when ignition is first turned on? When you get a crank/no start, do you some of those fault codes back?
    And of course, it goes without saying, if the ECM is kicking the bucket while you are cruising down the road, the engine ain't gonna run. Again, do said fault codes come back?
    Hey JeF I finally had a moment to work on the car again last night. I cleared the codes and checked them without attempting to start then attempted to start and re scanned.
    Thursday,10,October,2019,17:57:19:43608
    VIN: WAUKF68E05A438025   License Plate: 10-10-19
    Mileage: 180260km-112008mi   Repair Order:
              67 69 75 76 77
    VIN: WAUKF68E05A438025   Mileage: 180260km-112008miles
       Part No SW: 8E0 910 115 B    HW: 8E0 907 115 C
       Component: 2.0l R4/4V TFSI     0130
       Revision: --H02---    Serial number:
       Coding: 010C010A190F0120
       Shop #: WSC 00191 264 15243
       VCID: 2019E785B6C94687E97-8074
    Readiness: 0110 0100
       Part No SW: 8E1 910 156 A    HW: 09L 927 156
       Component: AG6 09L 2,0TFSI USA 0020
       Revision: --H01---    Serial number:        0078784
       Shop #: WSC 06325 000 00000
       VCID: 2517F691A9EBA3AF9A1-8070
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
       Component: ESP8 quattro    H04 0180
       Coding: 0004528
       VCID: 270BFC99D3E7B1BFA8D-8072
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x0722
                        Hex Value: 0x00FF
                        Hex Value: 0xFF96
                        Hex Value: 0x00FF
                        Fault Status: 00101011
                        Reset counter: 14
                        Hex Value: 0x3D40
                        Hex Value: 0x4006
                        Hex Value: 0x00FF
                        Hex Value: 0xFFAB
                        Hex Value: 0x00FF
                        Fault Frequency: 16
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF93
                        Hex Value: 0x00FF
    18265 - Load Signal
                P1857 - 000 - Error Message from ECU - Intermittent
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x6222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF9D
                        Hex Value: 0x00FF
       Part No: 8E0 820 043 AM
       Component:   A4 Klimaautomat   2728
       Coding: 00000
       Shop #: WSC 26130
       VCID: 6C81C3B50F9152E705F-5160
                27-00 - Implausible Signal
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  USA 0304
       Coding: 11023
       Shop #: WSC 65536
       VCID: 3B2330E93A7F055FDC5-4B00
                30-00 - Open or Short to Plus
    Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
       Part No SW: 8E0 035 593 E    HW:
       Component: SDAR XM
       Revision:             Serial number: AUZ4Z7D5019110
       VCID: 2B0300A9CF2F95DF4C5-5184
    02788 - Internal Communications Error
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
       Component:    Airbag 9.41  H10 3230
       Revision: 91H10323    Serial number: 0036N0001LKV
       Coding: 0032607
       VCID: 3C2133F53A610267D5F-8068
       Subsystem 1 - Part No: 8E0 910 339 B
       Component: BF-Gewichtsens. 02  0070
       Serial number: 6332DRB4011C4714D
       Coding: 00032607
       Subsystem 2 - Serial number: 6342DRB4011CD19AV
       Subsystem 3 - Serial number: 6352ARB4003BDBEA1
       Subsystem 4 - Serial number: 6362ARB4003BEA83W
       Subsystem 5 - Serial number: 63729RB400366A89P
       Subsystem 6 - Serial number: 63829RB400366AD0M
    01794 - Control Module - Incorrect Chassis (VIN) Number
                        Fault Status: 00110000
                        Reset counter: 99
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 02042
       Shop #: WSC 06325
       VCID: 41DF420158936F8F869-4B00
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 981 N    HW: 8E0 920 981 N
       Component: KOMBI+WFS 4     H12 0040
       Revision: 0040        Serial number: 00000000000000
       Coding: 0021261
       Shop #: WSC 26130 444 84535
       VCID: 38292FE50E492E47317-5184
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0021261
    Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
       Part No: 8E0 959 760
       Component: Sitzmemory R2 F     0305
       Coding: 00002
       VCID: 71BFD2C12883BF0F369-4B3C
                79-00 - Please Check Fault Codes
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 E    HW: 8E0 035 192 E
       Component: RNS-E US        H52 0020
       Revision:      02S    Serial number: AUZBZ7D0000558
       Coding: 0309137
       Shop #: WSC 26027 444 53511
       VCID: 2615F19DD4CDA8B793B-5184
    00532 - Supply Voltage B+
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 18:41:47
                        Voltage: 12.30 V
                        Fault Frequency: 7
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 17:46:53
                        Voltage: 10.80 V
                        Mileage: 655350 km
                        Count: 2112
                        Clock: 00:48
       Part No: 8E0 959 433 BT
       Component: Komfortgerát T7B    3132
       Coding: 12092
       Shop #: WSC 06325
       VCID: 04518B150701BAA7EDF-4B00
       Component: Tőrsteuer.FS BRM 1406
       Subsystem 2 - Part No: 8E1959802G
       Component: Tőrsteuer.BF BRM 1406
       Component: Tőrsteuer.HL BRM 1406
       Component: Tőrsteuer.HR BRM 1406
    12 Faults Found:
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Rear Right
                35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Rear Left
                35-00 - -
    00956 - Key 2
                35-10 - - - Intermittent
                62-10 - No or Incorrect Adjustment - Intermittent
    01705 - Selection Switch for Mirror-Adjust (E48)
                53-10 - Supply Voltage Too Low - Intermittent
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Coding: 0000019
       Shop #: WSC 26131 444 92477
       VCID: 2615F19DD4EDA8B793B-8072
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H05 0030
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH01 0020
                        Reset counter: 7
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0309137
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 18:41:47
                        Voltage: 12.30 V
                        Fault Frequency: 7
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 17:46:53
                        Voltage: 10.80 V
                        Mileage: 655350 km
                        Count: 2112
                        Clock: 00:48
    End----------(Elapsed Time: 04:50, VBatt start/end: 13.5V/13.6V)-----------
    Thursday,10,October,2019,18:05:20:43608
    VIN: WAUKF68E05A438025   License Plate: 10-10-19-2
              67 69 75 76 77
       Coding: 0004528
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x0722
                        Hex Value: 0x00FF
                        Hex Value: 0xFF96
                        Hex Value: 0x00FF
                        Reset counter: 14
                        Hex Value: 0x3D40
                        Hex Value: 0x4006
                        Hex Value: 0x00FF
                        Hex Value: 0xFFAB
                        Hex Value: 0x00FF
                        Fault Frequency: 17
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF93
                        Hex Value: 0x00FF
    18265 - Load Signal
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x6222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF9D
                        Hex Value: 0x00FF
       Coding: 00000
       Shop #: WSC 26130
       Coding: 11023
       Shop #: WSC 65536
       Component: SDAR XM
       Coding: 0032607
       Coding: 00032607
                        Reset counter: 99
       Coding: 02042
       Shop #: WSC 06325
       Coding: 0021261
       Coding: 0021261
       Coding: 00002
       Coding: 0309137
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 18:41:47
                        Voltage: 12.30 V
                        Fault Frequency: 7
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 17:46:53
                        Voltage: 10.80 V
                        Mileage: 655350 km
                        Count: 2112
                        Clock: 00:48
       Coding: 12092
       Shop #: WSC 06325
    12 Faults Found:
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    00956 - Key 2
       Coding: 0000019
                        Reset counter: 6
    End----------(Elapsed Time: 04:44, VBatt start/end: 13.6V/13.6V)-----------
              67 69 75 76 77
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - Intermittent
                        Mileage: 180260 km
                        Temperature: 12.0°C
                        Temperature: 13.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.589 V
    18265 - Load Signal
                        Reset counter: 40
                        Mileage: 180260 km
                        (no units): 30.0
                        (no units): 60.0
                        Temperature: 14.0°C
                        T.B. Angle: 0.0°
       Coding: 0004528
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x0722
                        Hex Value: 0x00FF
                        Hex Value: 0xFF96
                        Hex Value: 0x00FF
                        Reset counter: 14
                        Hex Value: 0x3D40
                        Hex Value: 0x4006
                        Hex Value: 0x00FF
                        Hex Value: 0xFFAB
                        Hex Value: 0x00FF
                        Fault Frequency: 21
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x4222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF93
                        Hex Value: 0x00FF
    18265 - Load Signal
                        Reset counter: 40
                        Hex Value: 0x0000
                        Hex Value: 0x6222
                        Hex Value: 0x00FF
                        Hex Value: 0xFF9D
                        Hex Value: 0x00FF
       Coding: 00000
       Shop #: WSC 26130
       Coding: 11023
       Shop #: WSC 65536
       Coding: 0032607
       Coding: 00032607
                        Reset counter: 99
       Coding: 02042
       Shop #: WSC 06325
       Coding: 0021261
       Coding: 0021261
       Coding: 00002
       Coding: 0309137
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 18:41:47
                        Voltage: 12.30 V
                        Fault Frequency: 7
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 17:46:53
                        Voltage: 11.20 V
                        Mileage: 655350 km
                        Count: 2112
                        Clock: 01:08
       Coding: 12092
       Shop #: WSC 06325
    12 Faults Found:
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    00956 - Key 2
       Coding: 0000019
                        Reset counter: 2
       Coding: 0309137
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 18:41:47
                        Voltage: 12.30 V
                        Fault Frequency: 7
                        Reset counter: 33
                        Date: 2017.07.12
                        Time: 17:46:53
                        Voltage: 11.20 V
                        Mileage: 655350 km
                        Count: 2112
                        Clock: 01:08
    So thats what I got out of that exercise.
    I have a constant CEL with the key in the on position.
    I noticed something strange today. When I open my door my fuel pump doesnt prime and I know it always has before, does that mean anything?
  2. #12
    Oct 2019
    Oregon, USA
    OK so even tho Jack is a huge PITA to deal with he has posed a few valid questions. I would like to answer a few of them that I could pick out of his aggressive, borderline autistic posts.
    The car is stage 1 tuned by Motoza with 034 HFC and DV+ from GFB, KN filter and a silicon 034 turbo inlet hose.
    Plugs and coils are all brand (<5k miles) new and were replaced with BOSH and genuine audi parts.
    The cat is showing ready b/c I had it disabled by my tuner.
    I dont know why Im on version 0130?? I just downloaded that from the RossTech webpage the day I posted the thread so.. I assumed they would have the latest version on the page. I also tried auto update and it told me there were no new versions available.
  3. Likes Uwe liked this post
  4. #13
    Quote Originally Posted by PnwQuattro View Post
    "0130" is the software version in your ECU, not the VCDS version.
  5. #14
    OP are you saying you want my assistance & even though I'm an asshole & indeed autistic recognizing my special impairments which could help you?
    Should I reengage your thread, further removing you from ignore list or should I remain in the corner and watch till milk time?
  6. #15
    Oct 2019
    Oregon, USA
    O man I didnt even realize that newer ECU software existed. I rooted around for a bit and cant seem to figure out where to start upgrading it.
    Do I need to upgrade it?
    Will it wipe out my tune?
    For some reason I dont think that the firmware is the issue but I cant find much about it specifically.
  7. #16
    Oct 2019
    Oregon, USA
    Jack, I recognize your abilities, but your delivery could use work. Feel free to engage just chill a little ,yeh?
  8. #17
    Yay I brought pickup sticks, tinker toys, and blocks to share.
    Okay I will try and you are removed from ignore list.
    When meds wear off be forewarned.
    Does car during cranking, register a G28 & G40 signal in blocks?
    See I bet you have more than just the CAT code tampered and is why I would recommend to reflash to stock to see what other codes may appear, does that make sense?
    Did you verify intake & exhaust are unrestricted?
    Compression check?
    If you spray flammable fluid in intake will it fire?
    Spark/Fuel at HPP and does FPS register anything in blocks for N276 duty cycle or rail PSI?
    What tool are you using for reading and writing full flash & are you altering virtual eeprom in flash blocks part writes or direct memory blocks access in eeprom external or using ram flips for anything?
    Is tune with switch tables?
  9. Likes PnwQuattro, Uwe, Larry Manton liked this post
  10. #18
    Oct 2019
    Oregon, USA
    -I will check tomorrow. Thanks
    -Quite possible that youre right about more being tampered with I didnt request any other ones be shut off specifically but only my tuner would really know.
    I have my stock tune in a file Ill reflash it when I get off work tomorrow.
    -I dont know how the exhaust would be clogged but Ill have my wife crank it for me and Ill feel the exhaust. I have a straight view into the turbo with my air box off right now, completly clean.
    - Yes it will defiantly fire if I spray it . That was the first thing I did after listening for fuel pump and checking the filter. Is there a location on the rail to check pressure? Im suspicious of the HPFP at this point but its like 1 month old. I got a Hitachi cause it had great reviews.
    -Spark/Fuel at HPP and does FPS register anything in blocks for N276 duty cycle or rail PSI?
    I dont quite under stand this. I did check the values in the fuel pressure block but I failed to save the numbers so I dont have them. I will check again while I check the N276 block tomorrow.
    - I can tell you its the usb to odb2 that came from my tuner. >>>I dont know what any of the rest of that means. I just plug my car in and record a log while doing a list of tasks like idle accelerate to 50 and a 3-4 gear pull ( private roads only) then I send it to him and he does his magic and sends it back and I flash my car with the provided GUI. Rinse and repeat a few times until both parties are satisfied. Its been tuned for almost 2 years I think. Runs great usually no over heating or extra oil loss no smoke in the exhaust.
    Thanks for the help, will report back tomorrow.
  12. #19
    Okay so runs on spray, which implies fuel systems related?
    Did you check fuses yet as per JPPSG?
    Fuel system tests should be done with whether electrical or mechanical must be verified as per the RTFB in order to be done in spirit of safety first, okay?
    Now if ECU is running interference or relay or CCM as you aforementioned with fuel pump door prime you may require investigation using WD too, no?
    Sounds pretty straight forward.
  13. #20
    Report?
