Results 1 to 9 of 9
Thread: 2012 8R Q5 OBD Mode 10 Permanent codes not shown
    Nov 2015
    Question 2012 8R Q5 OBD Mode 10 Permanent codes not shown
    Hi, I used VCDS 19.6.2 with HEX-NET to set all readiness on this car. When it went for a smog (CA) it failed for permanent DTC P0300 and P0301 misfire. I went back with VCDS into the OBD function and mode 10 permanent DTC, no codes stored. I used a Autel OBD reader and now I can see the codes in permanent codes. Has anyone seen VCDS not showing the codes before? WA1LFAFP4BA103189 8RB56A CAEB NEV 4/11. Thanks for any help or info.
    Please post a VCDS Auto-Scan.
    Nov 2015
    Auto-Scan
    Here is the Auto-scan. Please let me know if and what I should log and send in.
    Tuesday,08,October,2019,16:26:15:57829
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WA1LFAFP4BA103189   License Plate:
    Mileage: 234380km-145636mi   Repair Order:
    Chassis Type: FP-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
              6C 6D 72
    VIN: WA1LFAFP4BA103189   Mileage: 234380km-145636miles
    Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8R0 907 115 P    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0002
       Revision: E1H19---
       Coding: 0121010A290F0160
       Shop #: WSC 04091 002 1048576
       ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
       ROD: EV_ECM20TFS0118K2907115AG.rod
       VCID: C1CA1F6D5068AF4768-8094
       Part No SW: 8R0 927 158 T    HW: 0BK 927 156 R
       Component: 0BK 20TFSIUSA H08 1003
       Revision: --H08---
       Coding: 000002
       ASAM Dataset: EV_TCMAL551211 002018
       VCID: CED034519136403FE5-809A
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
       Component: ESP8 quattro  H06 0110
       Coding: 121D18
       Shop #: WSC 06334 000 00000
       VCID: C5C20B7D4C40836754-8090
       Part No SW: 8K0 907 064 CS    HW: 8K0 907 064 CS
       Component: BCM2 2.0      H05 0435
       Coding: 090500
       Shop #: WSC 06335 000 00000
       VCID: 8346D56502F47D573A-80D6
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0511000016297007
       Serial number: 2311000059607009
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01050420110342
       Coding: 64112000
       VCID: 804CDA6913E2664F27-80D4
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000856069
       Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
       VCID: BC346E993F8AC2AF3B-80E8
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 110316  H11 0050
       Serial number: 90243014110314124248
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 11363154
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002603111021
    02258 - Door Opener Transmitter
                        Reset counter: 220
                        Mileage: 234384 km
                        Date: 2010.05.17
                        Time: 01:12:00
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0080
       Revision: 11001001    Serial number: 12501108802423
       Coding: 300105
       VCID: F8BCB2894B322E8F1F-80AC
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003GPD0N5032
       Coding: 303633313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: C7DE01757E4C9177A6-8092
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R1100002YKH
       Serial number: 6334MSME5C7311136
       Serial number: 6344MSME5D561911F
       Serial number: 6352QSME6E092876T
       Serial number: 6362QSME30061E74D
       Serial number: 63732SME2306536C-
       Serial number: 63832SME75050156T
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KCS001GF
       Coding: 000017
       VCID: BD32639D2490CBA70C-80E8
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 981 G    HW: 8R0 920 981 G
       Component: KOMBIINSTR.   H20 0258
       Revision: 00000000    Serial number: EK037KN3C
       Coding: 8B1622000300D705020000
       VCID: BE3064912996D0BF15-80EA
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E113160587
       Coding: 00C303
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650113037
                        Fault Frequency: 27
                        Reset counter: 7
                        Mileage: 234385 km
                        Date: 2010.06.26
                        Time: 04:28:00
                        Bin. Bits:    10000
                        Voltage: 11.90 V
                        Count: 11
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0075
       Revision: AA000000    Serial number: 00001002377646
       Coding: 00581300000000000000
       VCID: C2C810615D6EB45F71-8096
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000005714723
       Coding: 011D03205E00440004
       VCID: CAD83841655E6C1FB9-809E
       Revision: 00002001    Serial number: 0145907325
       Coding: 0126023A20FA749484B0053200000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000378581
       Component: J245EE20SKB13  H02 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H02 0220
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000113571727
       VCID: C9DA074D60586707B0-809C
       Revision: 00000003    Serial number: 00000000908285
       VCID: B42446B917DA0AEFF3-80E0
       Part No: 8K0 907 357 D
       Component: Dynamische LWR  H02 0010
       Coding: 0000006
       VCID: B6207CB1C1A618FFCD-80E2
       Part No SW: 4G0 035 082     HW: 4G0 035 082
       Component: Radio U SIRIU H51 0052
       Revision: AB001007    Serial number: 471DR0B7570222
       Coding: 020007020100000001
       VCID: DDF2C31DC4D0EBA76C-8088
       Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
       Component: H-BN-NA       H51 0116
       Revision: --------    Serial number: 490D 0B7612973
       Coding: 010200060005A1EF41000B0E000000030000
       VCID: B83C72890BB2EE8FDF-80EC
       Subsystem 1 - Part No: 8R0 060 884 P
       Component: NAR 2010  0407
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0084
       Serial number: 9466CV0B0552662
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000790361
       Component: CD-Database  1886
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000114666133
       Coding: 010C03204000240004
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H05---    Serial number: 525PA8-J12A0KI
       Coding: 1020010
       VCID: B42446B9D7DA0AEFF3-80E0
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Component: J605  Master  H51 0330
       Revision: --------    Serial number: 8R0827851B
       VCID: BB366D853A84C59732-80EE
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Component: J756  Slave  H51 0330
       Serial number: 8R0827852B
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000114666130
    End----------(Elapsed Time: 01:51, VBatt start/end: 13.6V/13.7V)-----------
    Tuesday,08,October,2019,16:27:00:57829
    Mode 10: Permanent Fault Codes
    __________________________________________
    Tuesday,08,October,2019,16:27:33:57829
    Mode 03: Emission related fault codes
    Mode 07: Pending emission related fault codes
    Address 7E8: No fault code found.
    Address 7E9: No fault code found.
    Tuesday,08,October,2019,16:28:00:57829
    Tuesday,08,October,2019,16:29:08:57829
    Type 02 - VIN : WA1LFAFP4BA103189 (Address E8)
    Type 04 - Calibration ID : 8R0907115P Q0002 (Address E8)
    Type 04 - Calibration ID : 8R0158T 100322   (Address E9)
    Type 06 - Calibration Verification Number : 35256D79 (Address E8)
    Type 06 - Calibration Verification Number : 4954B6B1 (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 1896
        Ignition cycle count : 6538
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 3322 / 1881
             Catalyst monitor bank 2 : 0 / 0
             O2 Sensor monitor bank 1 : 2430 / 1896
             O2 Sensor monitor bank 2 : 0 / 0
             EGR-VVT monitor : 4808 / 1896
             AIR monitor : 0 / 0
             EVAP monitor : 48 / 247
             Secondary O2 Sensor monitor bank 1 : 2829 / 1881
             Secondary O2 Sensor monitor bank 2 : 0 / 0
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
    Tuesday,08,October,2019,16:29:30:57829
    Mode 01 - PID 01 : Readiness  --  Address 7E8
    Number of DTCs stored: 0  --  MIL Status: MIL OFF
    Misfire monitoring:  Passed
    Fuel System:  Passed
    Comprehensive Components:  Passed
    Catalyst monitoring:  Passed
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring:  Passed
    Secondary air system monitoring: Not installed.
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring:  Passed
    Oxygen sensor heater monitoring:  Passed
    Exhaust Gas Recirculation:  Passed
    This makes little sense to me, with no faults showing in native VAG mode, none in any of the three generic OBD modes, and OBD Readiness explicitly claiming "Number of DTCs stored: 0".
    Is there any history of misfire codes in this car?
    Nov 2015
    I am sure it did have misfires at some point. This is a shop car and has been sitting around for a while.
    Here is a pic of the codes.
  6. #6
    Nov 2015
    Uwe would it help to log anything and send it. I would be glad to help further development.
  7. #7
    Well, what would be most interesting is a log of what those other tools are doing when they pull those codes. If you were local, I'd say bring the car by so we can have a look at it with some other tools we have, but I think your distance to us precludes that.
    Let me ask this in a straightforward manner: Is is this ECU tuned?
  8. #8
    Nov 2015
    No everything is stock. I will keep an eye out for another car with a PD DTC and then see if it is detected by VCDS and report back.
  9. Likes Uwe liked this post
  10. #9
    Administrator Andy's Avatar
    Sector 7G
    Quote Originally Posted by Shzeps View Post
    Thanks for the details, this is helping us to look into this.
  11. Likes Uwe liked this post
