Trying to code ABS after new clocks/ECU/BCM was fitted
car runs fine but cannot code ABS just getting the error 22
have tried using the calculator tables
please see attached full autoscan and VIN
hoping someone can give a code that works.
car is RHD with CAYB engine
I'm aware of it neeving to be over 12V battery voltage. just ran a quick autoscan with no charger connected.
please help!
cheers,
Will
Tuesday,08,October,2019,21:03:06:40315
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4441.4
Dealer/Shop Name: w h enterprise
VIN: WVWZZZ6RZAU015607 License Plate: CY59LNR NEW
Mileage: 194130km-120626mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZAU015607 Mileage: 194130km-120626miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 BC HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 8876
Revision: --H13--- Serial number:
Coding: 00114014000500080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023BC 003007
ROD: EV_ECM16TDI02103L906023AH_003.rod
VCID: 688944E422FA0CF736D-803C
7332 - Mass Air Flow Sensor (G70)
P0103 00 [165] - Signal too High
Mileage: 193905 km
Date: 2019.10.07
Time: 23:51:41
Coolant temperature: 12 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.633 V
Engine speed: 0 /min
Battery voltage: 11.6 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
14359 - Exhaust Gas Temperature Sensor 4 Bank 1
P2470 00 [165] - Short to Ground
Mileage: 193905 km
Date: 2019.10.07
Time: 00:40:48
Engine speed: 983.25 /min
Normed load value: 22.0 %
Coolant temperature: 53 °C
Intake air temperature: 23 °C
Voltage terminal 30: 13.892 V
Exh.gas temp.sen 3-TEG_MES[1]: 11.41 °C
Sensor for engine block temperature: raw value-Coolant temperature: 12 °C
Exh.gas temp.sen 1-TEG_MES[0]: 19.98 °C
Exh.gas temp.sen 4-TEG_MES[2]: -175.02 °C
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 R HW: 6R0 907 379 R
Component: ESP8.2i front H04 0002
Revision: --------
Shop #: WSC 31414 790 31414
VCID: 4DC79570AD98C9DF25B-8018
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 23:34:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x1497
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
Fault Status: 01100101
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 23:34:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1B97
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
00493 - ESP-Sensor Unit (G419)
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 23:34:53
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x1A97
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
Hex Value: 0x0000
03306 - Coding Not Valid
Reset counter: 93
Mileage: 194137 km
Date: 2014.02.27
Time: 23:37:11
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x2597
Hex Value: 0x00FF
Hex Value: 0x7F80
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC (J3ÿÿÿ) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 E HW: 6R0 820 045 E
Component: Climatic 24 0600
Revision: 00 10 24
VCID: 3039EC84DA2A84372ED-8064
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Mileage: 4069 km
Date: 2010.11.04
Time: 16:33:40
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H09 0029
Revision: BF009001 Serial number: 9955A267090629
Coding: 25B02BBF08E12400923000003D2B0CD00000410F600400002000
Shop #: WSC 00389 210 88335
VCID: 3C21C8B406627057825-8068
Subsystem 1 - Part No SW: 6R0 959 802 H HW: 6R0 959 802 H Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 005 0803
Serial number: KU0-KU025.09.0915949
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 K HW: 6R0 959 801 K Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 005 0803
Serial number: KU0-KU028.09.0910648
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU030061100015273
Coding: 08BC32
Subsystem 4 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 005 0803
Serial number: KU0-KU015.09.0910328
Coding: 08BC32
Fault Status: 00101011
Reset counter: 93
Reset counter: 93
Mileage: 194136 km
Date: 2014.02.25
Time: 23:24:59
02660 - Radio Remote Control not Matched/Adapted
Fault Frequency: 7
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 00:01:46
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00B H09 0018
Revision: -------- Serial number: 003DW007DHSR
Coding: 003042
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 42DDB64C640606A7C89-8016
Serial number: 3572SRB400009BCC81BM
Serial number: 3582SRB400009BE52A6G
Serial number: 3516GRB402V9BR0F14IJ
Serial number: 3526GRB4021DJ2ND8JBD
Part No SW: 6R0 920 961 B HW: 6R0 920 961 B
Component: KOMBI H23 0110
Coding: 440A00
VCID: 3537DD9025C8A11F7DB-8060
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Reset counter: 93
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Airbag: keine Kommunikation]
Reset counter: 93
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0029
Coding: 002300
VCID: 70B92C841AAAC4376ED-8024
02078 - Media Player Position 3 (R120)
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 00:00:04
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H23 0110
Address 2E: Media Player 3
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10130
Shop #: WSC 31414
VCID: 2E05F2FCC95E92C73C1-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 013 0049
Revision: 01000000 Serial number: VWZ1Z2I6829004
Coding: 0500040002
Shop #: WSC 77011 210 104168
VCID: 6B833BE8338C27EF5BF-803E
03272 - Control Module for Audio Interface
Reset counter: 53
Mileage: 194137 km
Date: 2014.02.27
Time: 00:00:59
End----(Elapsed Time: 01:31, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
please help!
cheers,
Will
