Results 1 to 4 of 4
Thread: Skoda Octavia 2009 L&K 2.0TDI ABS coding missing/deleted
    Oct 2019
    I'm wondering if it is possible to re-install the coding for an ABS module that has been wiped leaving the code section full of zeros, the unit was working fine until i mistakenly plugged a different instrument module in and the result is the ABS module has lost its coding, I have returned to the original instrument cluster (one problem at a time) any help would be really appreciated, i've included a scan.
    Monday,07,October,2019,11:14:45:37288
    VIN: TMBAE61Z092066779   License Plate: PF09FFG
    Mileage: 63510km-39463mi   Repair Order: 1st test
    Chassis Type: 1Z-SK35 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 36 42 44 46 52 55 56 62 72
              77
    VIN: TMBAE61Z092066779   Mileage: 63510km-39463miles
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 TC    HW: 03G 906 021 AN
       Component: R4 2,0L EDC G000SG  2048
       Revision: --H11---    Serial number:
       Coding: 0000072
       Shop #: WSC 73430 790 00999
       VCID: 73B3DF1197BC321FC45-8026
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 000 - Open Circuit
                        Mileage: 63517 km
                        Date: 2014.02.27
                        Time: 00:00:26
                        RPM: 840 /min
                        Load: 0.0 %
                        Voltage: 14.21 V
                        Bin. Bits: 00001100
                        Temperature: 12.6°C
                        Bin. Bits: 10110000
       Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
       Component: ESP MK60EC1   H35 0106
       Revision: 00H35001
       VCID: 75B7E10995C82C2FEA1-8020
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 88
                        Mileage: 63516 km
                        Date: 2014.02.20
                        Time: 00:28:12
                        Count: 16391
                        Count: 8192
                        Count: 143
                        Count: 42240
                        Reset counter: 88
                        Mileage: 63516 km
                        Date: 2014.02.20
                        Time: 00:28:12
                        Count: 16391
                        Count: 8192
                        Count: 195
                        Count: 42240
       Part No SW: 3T0 907 044 AC    HW: 3T0 907 044 AC
       Component: Climatronic   122 0203
       Revision: 00003001
       Coding: 0100000000
       ASAM Dataset: EV_Climatronic A01001
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 73B3DF119B3C321FC45-8026
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Reset counter: 128
                        Time: 00:00:00
       Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
       Component: BCM PQ35  H   103 0537
       Revision: 00103 AB
       Coding: 48180AB8F841B1C04008008011001124017000AE626D85605C0440000000
       VCID: 323D1A1524267B170F3-8066
       Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 21040  22  0601
       Coding: 00D7B7
       Component: RLS 150509 05  54  0402
       Coding: 0730ED
       Subsystem 3 - Part No: 1Z0 951 171
       Component: Innenraumuebe  008 5101
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
    Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
       Part No SW: 1Z0 919 475     HW: 1Z0 919 475
       Component: PARKHILFE 4K  H06 0004
       Revision: --------    Serial number: 66640912820298
       VCID: 7EA5FE25A0FE6F77BBB-802A
       Component: Q8 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2DCFGL
       Coding: 0020792
       VCID: 3D273929E178B46FE21-8068
       Subsystem 1 - Serial number: 6332MSME473417568
       Subsystem 2 - Serial number: 6342MSME47425658D
       Subsystem 3 - Serial number: 6351HSME00286216Z
       Subsystem 4 - Serial number: 6361HSME002E27485
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Component: J0527           055 0111
       Coding: 0000732
       VCID: 78A9E83D8EDA5147F17-802C
       Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO   H07 0011
       Coding: 00000130
       Part No SW: 1Z0 920 943 D    HW: 1Z0 920 943 D
       Component: KOMBI         H21 0109
       Coding: 410F00
       Shop #: WSC 73430 031 00999
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: 3A2D3235FCD68357C73-806E
       Part No SW: 1K0 907 530 S    HW: 1K0 907 951
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K0951202D5
       Coding: E9A1FF06000612001303
       VCID: 372B2B01C3449E3F38D-8062
                        Reset counter: 88
                        Mileage: 63515 km
                        Date: 2014.02.20
                        Time: 18:23:26
                        Reset counter: 128
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H21 0109
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Component: SG EXT.PLAYER H13 0084
       Revision: A1001003    Serial number: 7667421721
       VCID: 2615F64518EE17B793B-8072
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1102
       Revision: 00005000    Serial number: 00000000000000
       VCID: 2F3B13613B1456FF60D-807A
       Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
       Component: Tuer-SG         009 2108
       Coding: 0005118
       VCID: 76B5E60584CE2737E3B-8022
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H15000
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Coding: 0005118
       VCID: 48C958FDBEBAE1C7417-801C
       Component: AFS-Steuergeraet    0142
       Coding: 1507610
       VCID: 34311C0DD23275271DF-8060
       Coding: 00000023
       Coding: 00000023
       Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
       Component: BOLERO        008 0053
       Revision: 0A001001    Serial number: SKZ1Z3I8158712
       Coding: 090004000001
       VCID: 35372109D5486C2F2A1-8060
                        Reset counter: 88
                        Mileage: 63515 km
                        Date: 2014.02.20
                        Time: 18:31:57
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012551
       VCID: 323D1A1528267B170F3-8066
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 33331F11D73C721F045-8066
    Address 77: Telephone
    End----(Elapsed Time: 01:15, VBatt start/end: 11.9V/11.9V. VIgn 11.7V)-----
    Oct 2014
    At a guess, the stock coding was probably similar to:
    133B401C09280000C81202EB902200823400
    However, based on the capabilities of the module I'd use one of these:
    133B401C09280000C81202EB902200823500 (adds hill hold control)
    133B401C09280000C81202EB902200823508 (adds hill hold control and XDS)
    Oct 2019
    Quote Originally Posted by langers2k View Post
    Thank you very much for your help so far, I entered the codes you have given me and the first code you suggested (add hill control) has been accepted by the module, the flashng ABS and ESP lights have stopped on the instrument cluster but there is a message of ESP fault and a solid ESP light on the cluster, the second code you suggested apparently is "out of range" i wondered if
    I have done something wrong? (real newbie) Ive included another scan with the new ABS code.
    Friday,11,October,2019,14:13:05:37288
    VIN: TMBAE61Z092066779   License Plate: PF09 FFG
    Mileage: 63510km-39463mi   Repair Order: scan 2
              77
       Coding: 0000072
                        Fault Status: 01110000
                        Mileage: 63517 km
                        Date: 2014.02.27
                        Time: 00:00:26
                        RPM: 840 /min
                        Load: 0.0 %
                        Voltage: 14.21 V
                        Bin. Bits: 00001100
                        Temperature: 12.6°C
                        Bin. Bits: 10110000
       Revision: 00H35001
       Coding: 133B401C09280000C81202EB902200823500
                        Reset counter: 88
                        Mileage: 63516 km
                        Date: 2014.02.20
                        Time: 00:28:12
                        Count: 16391
                        Count: 8192
                        Count: 195
                        Count: 42240
                        Reset counter: 88
                        Mileage: 63516 km
                        Date: 2014.02.20
                        Time: 00:28:12
                        Count: 16391
                        Count: 8192
                        Count: 143
                        Count: 42240
                        Reset counter: 88
                        Date: 2014.03.03
                        Time: 03:21:24
                        Count: 7
                        Count: 12288
                        Count: 212
                        Count: 41728
       Revision: 00003001
       Coding: 0100000000
              U1111 00 [008] - -
                        Reset counter: 128
                        Time: 00:00:00
       Revision: 00103 AB
       Coding: 00D7B7
       Coding: 0730ED
       Coding: 0020792
       Coding: 0000732
       Coding: 00000130
       Coding: 410F00
                        Reset counter: 88
                        Mileage: 63515 km
                        Date: 2014.02.20
                        Time: 18:23:26
                        Reset counter: 128
       Coding: 0005118
       Revision: 00H15000
       Coding: 0005118
       Coding: 1507610
       Coding: 00000023
       Coding: 00000023
                        Reset counter: 88
                        Mileage: 63515 km
                        Date: 2014.02.20
                        Time: 18:31:57
       Coding: 0000144
       Coding: 0000144
    End----(Elapsed Time: 01:15, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
  4. Likes Uwe liked this post
    Looks like you still need to do some of the Basic Settings described here:
    http://wiki.ross-tech.com/wiki/index..._%28MK60EC1%29
  6. Likes PetrolDave liked this post
