I'm wondering if it is possible to re-install the coding for an ABS module that has been wiped leaving the code section full of zeros, the unit was working fine until i mistakenly plugged a different instrument module in and the result is the ABS module has lost its coding, I have returned to the original instrument cluster (one problem at a time) any help would be really appreciated, i've included a scan.
Monday,07,October,2019,11:14:45:37288
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBAE61Z092066779 License Plate: PF09FFG
Mileage: 63510km-39463mi Repair Order: 1st test
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 36 42 44 46 52 55 56 62 72
77
VIN: TMBAE61Z092066779 Mileage: 63510km-39463miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 TC HW: 03G 906 021 AN
Component: R4 2,0L EDC G000SG 2048
Revision: --H11--- Serial number:
Coding: 0000072
Shop #: WSC 73430 790 00999
VCID: 73B3DF1197BC321FC45-8026
005659 - Glowplug for Cylinder 2 (Q11)
P161B - 000 - Open Circuit
Mileage: 63517 km
Date: 2014.02.27
Time: 00:00:26
RPM: 840 /min
Voltage: 14.21 V
Bin. Bits: 00001100
Temperature: 12.6°C
Bin. Bits: 10110000
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
VCID: 75B7E10995C82C2FEA1-8020
00003 - Control Module
Fault Status: 01100101
Reset counter: 88
Mileage: 63516 km
Date: 2014.02.20
Time: 00:28:12
Count: 16391
Count: 8192
Count: 143
Count: 42240
Reset counter: 88
Mileage: 63516 km
Date: 2014.02.20
Time: 00:28:12
Count: 16391
Count: 8192
Count: 195
Count: 42240
Part No SW: 3T0 907 044 AC HW: 3T0 907 044 AC
Component: Climatronic 122 0203
Revision: 00003001
Coding: 0100000000
ASAM Dataset: EV_Climatronic A01001
VCID: 73B3DF119B3C321FC45-8026
U1111 00 [008] - -
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Reset counter: 128
Time: 00:00:00
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0537
Revision: 00103 AB
Coding: 48180AB8F841B1C04008008011001124017000AE626D85605C0440000000
VCID: 323D1A1524267B170F3-8066
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 21040 22 0601
Coding: 00D7B7
Component: RLS 150509 05 54 0402
Coding: 0730ED
Subsystem 3 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0004
Revision: -------- Serial number: 66640912820298
Coding: 000001
VCID: 7EA5FE25A0FE6F77BBB-802A
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q8 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2DCFGL
Coding: 0020792
VCID: 3D273929E178B46FE21-8068
Subsystem 1 - Serial number: 6332MSME473417568
Subsystem 2 - Serial number: 6342MSME47425658D
Subsystem 3 - Serial number: 6351HSME00286216Z
Subsystem 4 - Serial number: 6361HSME002E27485
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 055 0111
Coding: 0000732
VCID: 78A9E83D8EDA5147F17-802C
Subsystem 1 - Part No: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0011
Coding: 00000130
Part No SW: 1Z0 920 943 D HW: 1Z0 920 943 D
Component: KOMBI H21 0109
Coding: 410F00
Shop #: WSC 73430 031 00999
ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
VCID: 3A2D3235FCD68357C73-806E
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0951202D5
Coding: E9A1FF06000612001303
VCID: 372B2B01C3449E3F38D-8062
Reset counter: 88
Mileage: 63515 km
Date: 2014.02.20
Time: 18:23:26
Reset counter: 128
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H21 0109
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0084
Revision: A1001003 Serial number: 7667421721
VCID: 2615F64518EE17B793B-8072
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1102
Revision: 00005000 Serial number: 00000000000000
VCID: 2F3B13613B1456FF60D-807A
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2108
Coding: 0005118
VCID: 76B5E60584CE2737E3B-8022
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 69 2901
Revision: 00H15000
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0005118
VCID: 48C958FDBEBAE1C7417-801C
Component: AFS-Steuergeraet 0142
Coding: 1507610
VCID: 34311C0DD23275271DF-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000023
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 008 0053
Revision: 0A001001 Serial number: SKZ1Z3I8158712
Coding: 090004000001
VCID: 35372109D5486C2F2A1-8060
Reset counter: 88
Mileage: 63515 km
Date: 2014.02.20
Time: 18:31:57
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 323D1A1528267B170F3-8066
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 33331F11D73C721F045-8066
Address 77: Telephone
End----(Elapsed Time: 01:15, VBatt start/end: 11.9V/11.9V. VIgn 11.7V)-----
