Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Golf 6 MK6 Xenon to Halogen *Help pls*
    New User
    Oct 2019
    Calgary, Canada
    Hi everyone,
    I am new to the Vag Com world, at least to this level of depth, and am pretty impressed with the support on these topics.
    I am using our car clubís cable to configure my Osram Xenarc LED headlights on my 2010 GTI. Iíve browsed the forums and found one thread that was probably the most help so far, but since I am new to this I think Iíll need some more help haha
    So here we go. I have a 2010 GTI that came stock with Xenon and AFS. I owned a 2.5 with Halogens before and had purchased a set of the Osram Xenarc LEDs (https://www.osram.com/ecat/LEDriving...t/ZMP_4055174/) that were plug and play for the Halogen car. Now I think you know where this is going haha
    The headlights are a 10pin and the xenon harness is a 14pin connector. We managed to make our own reverse harness and everything, well almost everything, is working. The issue at this point is that the controls are not working 100%, low beams are always on, canít control DRLs separately.
    I am guessing that disconnecting the gateway and removing it in the settings as outlined in this post https://forums.ross-tech.com/showthr...+xenon+halogen could work but figured Iíd check in here for advice.
    I do have the LED tails, I think there might be some settings I need to consider as well. I will be able to post the scan this week as soon as I get it off the laptop (forgot to do it) and will post it here. Wanted to start the conversation anyway 😀
    Let me know if you need anything else and thanks in advance!
    -Seb
    Oct 2017
    Northwest UK
    Hi Seb
    If you've made your own harness, are using lights that we have no idea what the pins represent and are retrofitting a non VW part, then collectively this spells trouble. It's impossible for anyone to help. This is a project that someone would have to undertake to be able to assist. In this forum we recommend the use of factory wiring diagrams and retrofit genuine parts. Third party parts are not supported I'm afraid.
    New User
    Oct 2019
    Calgary, Canada
    Hi there!
    Well the Osram (OEM parts provider) headlights have the exact same connectors/pins as the OEM housing. Hence why a simple reverse harness from a 14 pin car to a 10 pin housing worked just fine. This is the exact same scenario that I linked to in this thread - Xenon car to halogen headlights. Everything is working, high beams, low beams, DRLs, signals with NO coding at all. All I am trying to figure out is what base coding I should be using to tell the car that Halogen headlights are installed so that the low beams arenít staying on all the time.
    I really hope the community can point out some options that we can explore. Pls help...
    Thanks in advance!
    -Seb
    New User
    Oct 2019
    Calgary, Canada
    Is there a way to post a picture? I have the wiring diagram that we used. Thanks!
    Quote Originally Posted by the.seabass View Post
    Please see: How to Post Pictures.
    New User
    Oct 2019
    Calgary, Canada
    Great, thank you @Uwe!
    @myonous Here is the wiring diagram we used to build the harness:
    https://drive.google.com/file/d/1FMx...ew?usp=sharing
    Hope this helps
  7. #7
    Oct 2017
    Northwest UK
    Hi
    There would likely be changes you would need to make to the adaptation channels. Are the low beams are staying on as DRL's? Can you please post an admap of 09 BCM.
  8. #8
    Plus please post a VCDS Auto-Scan...
  9. #9
    New User
    Oct 2019
    Calgary, Canada
    Sorry for the late response! Here we go:
    Sunday,06,October,2019,14:58:02:03411
    VCDS Version: 19.6.1.0 (x64)
    VIN: WVWGV7AJ6AW408033   License Plate:
    Mileage: 182000km-113089mi   Repair Order: Sebastian
    Chassis Type: AJ-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 62 72 77
    VIN: WVWGV7AJ6AW408033   Mileage: 182000km-113089miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AM    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0030
       Revision: AAH16---    Serial number:
       Coding: 0403010A18070160
       Shop #: WSC 00001 000 00000
       VCID: 71E25FCB68A449C766-8024
    008801 - Boost Pressure Control Valve (N249)
                   P2261 - 000 - Mechanical Malfunction - Intermittent
                        Fault Frequency: 196
                        Mileage: 179788 km
                        Date: 2013.12.28
                        Time: 11:01:47
                        RPM: 2141 /min
                        Load: 8.2 %
                        Speed: 78.0 km/h
                        Temperature: 63.0įC
                        Temperature: 21.0įC
                        Absolute Pres.: 890.0 mbar
                        Voltage: 14.224 V
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 114B600C49220002880B06E7921C0041300800
       VCID: 78F462EFCBDE188FA1-802C
       Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
       Revision: 00003001
       Coding: 0000000002
       VCID: 7EF874F7E1FA26BFEB-802A
       Part No SW: 1K0 937 087 F    HW: 1K0 937 087 F
       Component: BCM PQ35  H   103 0575
       Revision: 00103 AG
       Coding: 6D180A1E90272AC40088008560000D0441051586534D8D60648020200000
       VCID: 346C96DF97363CEF4D-8060
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 21041  21  0512
       Coding: 009795
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R006X32
       Coding: 00003042
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3972A7EBB854C1879E-806C
       Serial number: 3572MSME2F760452ZZZY
       Serial number: 3582MSME53460452ZZZN
       Serial number: 3512QSME1E4E5B07ZZZ4
       Serial number: 3522QSME02305B15ZZZJ
       Serial number: 35527SME4E234421ZZZA
       Serial number: 35627SME0E475721ZZZH
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Component: J0527           056 0111
       Coding: 0000532
       VCID: 78F462EF0BDE188FA1-802C
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5K6 920 870 D    HW: 5K6 920 870 D
       Component: KOMBI         H03 0305
       Coding: 370F00
       VCID: 346C96DF9F363CEF4D-8060
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 260410F2000951
       Coding: E9817F06001602000002
       VCID: 69D237AB4074B1072E-803C
    01304 - Radio
                        Fault Status: 00110100
                        Reset counter: 165
                        Mileage: 180965 km
                        Date: 2014.02.04
                        Time: 15:04:18
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223R8PN206
       VCID: 7EF874F729FA26BFEB-802A
       Component: IMMO          H03 0305
       VCID: 6AD048A78D72BA1F27-803E
       Component: Tuer-SG         009 2113
       Coding: 0001204
       VCID: 31629FCBA82409C726-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Component: Tuer-SG         009 2139
       Coding: 0001204
       VCID: 346C96DF57363CEF4D-8060
       Component: AFS-Steuergeraet    0142
       Coding: 1446940
       Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
       Component: AFS-Lst.-Modul l    ....
       Coding: 00000255
       Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
       Component: AFS-Lst.-Modul r    ....
       Coding: 00000255
    6 Faults Found:
    02233 - Left Headlight Power Output Stage (J667)
                        Fault Status: 11100100
                        Reset counter: 164
                        Mileage: 182000 km
                        Date: 2014.02.26
                        Time: 14:32:40
                        Voltage: 13.92 V
                            ABS 1
                        Reset counter: 164
                        Mileage: 182000 km
                        Date: 2014.02.26
                        Time: 14:32:40
                        Voltage: 13.92 V
                            ABS 1
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 164
                            Invalid
                            Invalid
                            Invalid
    02656 - Power Output Stage for Left Headlight (J667); Not Coded
                000 - - - MIL ON
                        Reset counter: 164
                            Invalid
                            Invalid
                            Invalid
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
                000 - - - MIL ON
                        Reset counter: 164
                            Invalid
                            Invalid
                            Invalid
                        Fault Status: 11100101
                        Reset counter: 164
                            Invalid
                            Invalid
                            Invalid
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0035
       Revision: -----20S    Serial number: VWZ4Z7J1135286
       Coding: 2500040004
       VCID: 61C22F8B7844F947F6-8034
    6 Faults Found:
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 165
                        Mileage: 178465 km
                        Date: 2013.11.16
                        Time: 19:24:10
                        Reset counter: 165
                        Date: 2014.02.05
                        Time: 13:12:39
                        Reset counter: 27
                        Mileage: 178465 km
                        Date: 2013.11.16
                        Time: 19:24:10
                        Reset counter: 165
                        Date: 2014.02.05
                        Time: 13:12:39
                        Reset counter: 165
                        Date: 2014.02.05
                        Time: 13:12:39
                        Reset counter: 165
                        Date: 2014.02.05
                        Time: 13:12:39
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0001168
       VCID: 356AABDB5C4C25E77A-8060
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000330873487
       Coding: 412100
       VCID: 2A5088A745F27A1FE7-807E
    01304 - Radio
                        Reset counter: 165
                        Mileage: 181050 km
                        Date: 2014.02.05
                        Time: 12:53:46
    End-------------------------(Elapsed Time: 02:14)--------------------------
    Main thing thatís not working besides the AFS error messages are the low beams canĎt be turned off and DRLs can be controlled with auto headlight switch.
    Really appreciate the help!
    -Seb
  10. #10
    If your new lights are "plug & play" with halogens, why do you still have a Xenon controller in the car?
