Hi
Fresh VCDS user here. Been using the tool since Christmas (Christmas present to myself), and slowly starting to get into it. I'm mostly just doing minor cosmetic adjustments with VCDS, anything else is way beyond me.
One thing I'm having trouble with, is controlling how/when the bi-xenon is used. I've already coded the "Coming Home" and "Leaving Home" functions to use the fog lights, and not the xenon lights. Currently when the light switch is in "Auto", the xenon lights are always on. I want to avoid using the xenon lights for every little thing, to preserve the bulbs. What I'm trying to achieve is this: When the light switch is in "Auto", and the light sensor says it's daytime, the LED DRL should be on full brightness front and back, and the xenon off. When it gets dark, the xenon should automatically turn on.
I assume this is done by coding in the "09 Cent. Elect". But there are a lot of undocumented bits in the long coding helper, and I'm very wary of experimenting too much with unknown bits. Is it done by some of the undocumented bits or in "Byte 18" maybe? Been Googleing this for a couple of weeks, but to no avail. Seems like my car model is not all to common, at least not in the US, and I'm having a hard time finding info for this specific model. It's a 2011 Passat Highline, 3C/B7 (Variant 365) Euro, with original bi-xenon and LED in the front and back.
Any feedback is greatly appreciated.
Kent
PS: Found and confirmed a couple of undocumented bits. Is this something I should post on the forums?
Latest AutoScan:
Kent
Latest AutoScan:
Tuesday,06,January,2015,17:01:41:40089
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVWZZZ3CZBE372910 License Plate: PASSAT
Mileage: 142540km-88570mi Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 47 4F 52 53 55 56
61 62 69 72 77
VIN: WVWZZZ3CZBE372910 Mileage: 142540km-88570miles
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 FS HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9970
Revision: --H43--- Serial number: 00000000000000
Coding: 00194036032401080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM16TDI02103L906023FS 003009
ROD: EV_ECM16TDI02103L906023FS.rod
VCID: 7CF7D819F777FEC1333-8029
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 N HW: 3AA 614 109 N
Component: J104 C2 450M VD07 0005
Revision: --H07--- Serial number: 00000003961087
Coding: 0003495
Shop #: WSC 05311 000 00000
VCID: 387F04094BCF12E197B-806D
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 ED HW: 5K0 907 044 ED
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000003
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 71E9F92DA03583A9905-8024
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 B HW: 3AA 937 087 B
Component: BCM PQ47 H+ 413 0452
Revision: BC413001
Coding: 0000000000000000001800805000A9F467FD0088626D8760E480C7240041
Shop #: WSC 05311 123 12345
VCID: 3979010DB0C50BE9685-806C
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 03031 10 0603
Coding: 00B795
Component: RLS 220311 05 54 0403
Coding: 033028
01800 - Light Switch (E1)
Reset counter: 45
Mileage: 142459 km
Date: 2015.01.05
Time: 09:25:46
Term 15 Off
Voltage: 12.70 V
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 28291105527082
Coding: 108002
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW47X0000.rod
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__101 VW10 HI 1918
Revision: 22014000 Serial number: 003K0P53AGHD
Coding: 0012337
VCID: 4C9748D92F578E41C33-8019
Subsystem 1 - Serial number: 6332MTS635420541
Subsystem 2 - Serial number: 6342MTS617090601
Subsystem 3 - Serial number: 6351HTS6HGM3R9KR
Subsystem 4 - Serial number: 6361HTS6T61FR9KJ
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BN HW: 5K0 953 569 AB
Revision: FF010040 Serial number: 20110316201820
Coding: 1182250000
VCID: 76E3CA31C95BA491457-8023
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 870 A HW: 3AA 920 870 A
Component: KOMBI H20 0420
Coding: 161F01
Shop #: WSC 05314 115 00000
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 306F3C296BBFCAA1DFB-8065
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 G HW: 1K0 907 951
Component: J533 Gateway H41 1614
Revision: H41 Serial number: 150311F1002569
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 3467303997A7F681BB3-8061
03927 - Function Restriction due to Driver Fatigue Recognition
Reset counter: 19
Mileage: 141429 km
Date: 2014.12.05
Time: 07:27:27
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76E3CA31015BA491457-8023
Component: ELV 029 0380
3C0905861J ELV 029 0380
01176 - Key
Reset counter: 204
Mileage: 140322 km
Date: 2014.10.20
Time: 14:22:13
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669656750
VCID: 285FD4495B6F826107B-807D
03138 - Input AUX IN
Fault Status: 00101001
Reset counter: 47
Mileage: 142010 km
Date: 2014.12.24
Time: 13:53:17
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0529
Revision: 12110009 Serial number: 0002466090
Coding: 0200B7
Shop #: WSC 05311 115 00000
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 35610D3D94DDEF898CD-8060
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002018387
Coding: 000090
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.309 0802
Revision: 1AH03729 Serial number: 00110680222901
Coding: 0000258
VCID: 3B751B057AF939F97A9-806E
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0631
Coding: 0191020052830E76300494157C084FCE707C01
Component: Neigungssensor 004 0611
Part No SW: 5K0 035 456 A HW: 5K0 035 456 A
Component: KonzernAmp 8K H06 0180
Revision: -------- Serial number: BP218809237629
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst8KanalBNO2.rod
VCID: 285FD449536F826107B-807D
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1614
Coding: 00000008
VCID: 6FEDFF55BE019559861-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0529
Revision: 14110009 Serial number: 0002498376
Coding: 0200B6
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 36630A3189DBE491857-8063
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002021563
Coding: 000090
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000244902
Coding: 0022067
VCID: 3365332552A9F1B9A29-8066
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 E HW: 7L6 907 357 C
Component: AFS-ECU H04 0080
Coding: 029200000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
ROD: EV_HeadlRegulVWAFSPt.rod
Subsystem 1 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A
Component: LeiMo links H04 0011
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 A HW: 3D0 941 329 A
Component: LeiMo rechts H04 0011
Coding: 230000
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 A HW: 3C8 035 195 A
Component: Radio RCD510 041 0166
Revision: 00000001 Serial number: VWZ1Z3K9802173
Coding: 0101000001
VCID: 2643DA71517B9411357-8073
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1614
Coding: 030B185A
VCID: 71E9F92DA83583A9905-8024
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000145412381
Coding: 0100000100000000
VCID: 306F3C2963BFCAA1DFB-8065
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 B HW: 7P6 035 730 B
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668940739
Coding: 0A01000000010101
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 3169392D60B5C3A9D05-8064
End-------------------------(Elapsed Time: 03:22)--------------------------
