Results 1 to 7 of 7
Thread: ABS coding Passat B6
    Verified VCDS-User
    May 2018
    Romania
    Hello guys , we try to repair a passat b6 ABS module . The original module has lost communication , so no matter what we tried we coudln't get it to communicate with DIAG . Replaced the unit with the same number on it , and now .. we can't code it ! Please help !
    Monday,07,October,2019,13:04:25:40571
    VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WVWZZZ3CZ9E070185   License Plate:
    Mileage: 258370km-160543mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72 77
    VIN: WVWZZZ3CZ9E070185   Mileage: 258370km-160543miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BL    HW: 03L 907 309
       Component: R4 2.0l TDI G000SG  9977
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 18432 807 600232
       VCID: 70B92DB896AAF4373A1-8024
                   U1017 - 000 -
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:49:27
                        Voltage: 11.25 V
                        Bin. Bits: 11001010
                        Bin. Bits: 00000000
                        (no units): 0.0
                   U1017 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:49:32
                        Voltage: 11.70 V
                        Torque: 219.0 Nm
                        Hex Value: 0xFF00
                        Bin. Bits: 11001010
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000795393370
       Coding: 0003368
       Shop #: WSC 00028 028 00001
       VCID: 629D57F0484656A7BC5-8036
    6 Faults Found:
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00011111
                        Count: 150
                        Hex Value: 0x0000
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
    01542 - Yaw Rate Sensor (G202)
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
    00810 - Sensor 1/2 for Brake Pressure
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 DA    HW: 3C0 907 044 DA
       Component: ClimatronicPQ46 132 0811
       Revision: 00132023    Serial number: 00000000000000
       VCID: 639352F4575C5FAFB73-8036
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:07
       Revision: 00H54000    Serial number: 00000008898702
       Coding: E38A8F0700041A00470A00000F000000000B5D435C000120000000000000
       Shop #: WSC 05124 000 00000
       VCID: 3333E2B4A73C8F2F073-8066
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 040908 003  0205
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     071008 054  0402
       Coding: 00208936
       Shop #: WSC 05124
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__005 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPKNMWDV
       Coding: 0012341
       Shop #: WSC 05311 000 00000
       VCID: 3B23CA948F6C476FDF3-806E
       Subsystem 1 - Serial number: 6333FTS651252268
       Subsystem 2 - Serial number: 6343FTS615222568
       Subsystem 3 - Serial number: 6353ETS61497VVNJ
       Subsystem 4 - Serial number: 6363ETS6BEH3VVNR
       Part No SW: 3C0 953 549 AD    HW: 3C0 953 549 AD
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507BA
       Coding: 0000014
       VCID: 6E8533C08C9EE2C728D-803A
       Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
       Component: KOMBIINSTRUMENT VD1 2416
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007105
       Shop #: WSC 11111 111 11111
       VCID: 26150BE064EEEA8790D-8072
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P08A01038E
       Coding: F9817F06000602002002
       VCID: 2A0DFFD070F6CEE7B45-807E
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 45091 001 1048576
       VCID: 392FD09C8550757FCDF-806C
       Component: J386  TUER-SG FT    1517
       Revision: 72009005    Serial number: 00000644488909
       Coding: 0000181
       VCID: 6FBB2EC48B94EBCF23B-803A
       Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.082 0401
       Revision: 1AH02234    Serial number: 00080810126902
       Coding: 0000258
       VCID: 3635DBA0B44E9A0720D-8062
       Component:    KSG PQ46 ELV 042 0472
       Coding: 0091020051030E763004941570084F0E707C01
       Shop #: WSC 33691 001 1048576
       Component: J387  TUER-SG BT    1517
       Revision: 72009005    Serial number: 00000507488911
       Coding: 0000180
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000153118
       Coding: 0000056
       VCID: 280905D86EFAFCF7A21-807C
                        Fault Status: 11111101
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 12:57:06
                        Voltage: 11.60 V
                        Count: 71
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Component: AFS-Steuergeraet    0133
       Coding: 2311169
       VCID: 3431E1A8A23288171E9-8060
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Coding: 00000035
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  012 0029
       Revision: 00000000    Serial number: VWZ1Z2H5799455
       Coding: 0500040004
       Shop #: WSC 05314 000 00000
       VCID: 65974CEC5568219F597-8030
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000626788
       Coding: 0000144
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000641877
       Coding: 0000144
       VCID: 71BF28BC9DA0FD3F35F-8024
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730     HW: 1K8 035 730
       Component: Telefon       H06 3100
       Revision: 00006000    Serial number: 20387920056910
       Coding: 011100
       VCID: 66954BE0A86E2A8750D-8032
    End----(Elapsed Time: 01:20, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
    As far I can see, Coding should be: 0000274
    After coding see wiki here
    Verified VCDS-User
    May 2018
    Romania
    Hello , tried , request out of range ..
    Try this before coding.
    [Options]
    [User Interface and Identification]
    write numbers for wsc, importer, device no.
    For example 12345 123 23456
    [Save]
    [Close VCDS]
    Start VCDS
    Verified VCDS-User
    May 2018
    Romania
    No luck , but stupid thing i tried ,.,the coding was 0010000 i substract tpms and said coding accepted but now its looking for AWD . no AWD on this car...
    Monday,07,October,2019,15:08:06:40571
    Control Module Part Number: 3C0 614 109 AF    HW: 3C0 614 109 AF
      Component and/or Version: J104    C4 440 V2   0015
               Software Coding: 0007952
                Work Shop Code: WSC 00028 028 00001
    9 Faults Found:
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00000000
                        Count: 222
                        Hex Value: 0x0000
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00000000
                        Count: 227
                        Hex Value: 0x0000
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Hex Value: 0x0000
                        Voltage: 12.00 V
                        Bin. Bits: 00000000
                        Count: 149
                        Hex Value: 0x0000
    03201 - Adaptation Overboost
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:06:26
    Verified VCDS-User
    May 2018
    Romania
    Also another combo working but another fault insted of AWD ...
    Monday,07,October,2019,15:35:09:40571
    VCDS Version: Release 19.6.0 (x64) Running on Windows 7 x64
               Software Coding: 0000269
                Work Shop Code: WSC 05311 000 00000
                          VCID: 629D57F0494656A7BC5-8036
    Fault Codes have been Erased
    8 Faults Found:
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 199
                        Hex Value: 0x0000
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Hex Value: 0x0000
                        Voltage: 11.75 V
                        Bin. Bits: 00011111
                        Count: 149
                        Hex Value: 0x0000
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
                        Reset counter: 7
                        Mileage: 258379 km
                        Date: 2019.10.07
                        Time: 15:33:37
  7. #7
    Verified VCDS-User
    May 2018
    Romania
    Can someone guide me where can i get the coding ? There is no dealer in 100km radius ...
