Hi guys I have a 2016 Octavia running very poor. lots of white smoke.
Looks and sounds very similar to a bad injector......
When I go into VCDS [01Engine] [Measuring Blocks] is shaded out? Am I doing something wrong or is there another way of viewing injection quantity?
Full autoscan below
Full autoscan below
Sunday,06,October,2019,15:20:05:13475
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Jonesy
VIN: TMBBG7NE1G0111121 License Plate: OCTAVIA
Mileage: 179008km-111230mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE1G0111121 Mileage: 179008km-111230miles
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2506
Revision: 22004001
Coding: 01114012430519090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CL 002006
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 79AFED00095A18FF8E9-802C
16408 - Actuator Module for Turbocharger 1
P00AF 00 [167] - Stuck
Mileage: 179008 km
Date: 2019.10.04
Time: 15:17:43
Engine speed: 1610.00 /min
Normed load value: 99.2 %
Vehicle speed: 43 km/h
Coolant temperature: 80 °C
Intake air temperature: 16 °C
Voltage terminal 30: 13.164 V
Turbine actuator 1 bank 1: posit.feedback - Spec.value: 97.21 %
Turbine actuator 1 bank 1: posit.feedback - Act.value: 60.46 %
Turbine actuator 1 bank 1: posit.feedback - Offset closed: -0.30 %
Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt: 2.145 V
Accelerator pedal travel: raw value: 65.68 %
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52705000000661
Coding: 1A078A911421096D0078060241C4245851289000608224F200430070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 4BC367C813465A6F6C5-801E
Part No SW: 5E0 820 047 M HW: 5E0 820 047 M
Component: AC Manuell H05 1202
Revision: 00001K07
Coding: 01110104000100001000000000400000
ASAM Dataset: EV_ACManueBHBVW37X 003129
ROD: EV_ACManueBHBVW37X_003.rod
VCID: 2C010454B6887D5745F-8078
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Reset counter: 24
Mileage: 179003 km
Date: 2019.10.03
Time: 15:51:04
Outside air temperature: 14.0 °C
Engine speed: 0 /min
Temperature after evaporator: 22.7 °C
System run time-Terminal 15 on: 255 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AQ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061527300310
Coding: 0F0008424207005307A04082B10407080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 074B9BF84FAE7E0F88D-8052
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 150822 041 0570
Serial number: 150913035736
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY152170D5F
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000033605408
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPLDBYRG
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7BB3D827DE264F40D-805A
Subsystem 1 - Part No SW: ----------- HW: 454 000 210 15
Serial number: 3576U0000007178DE61M
Subsystem 2 - Part No SW: ----------- HW: 454 002 909 15
Serial number: 3586U000000E5398761J
Subsystem 3 - Part No SW: ----------- HW: 454 802 709 15
Serial number: 3516RD2998508000000A
Subsystem 4 - Part No SW: ----------- HW: 454 802 709 15
Serial number: 3526R87218108000000Z
Subsystem 5 - Part No SW: ----------- HW: 454 801 208 15
Serial number: 3556V2DE30C08000000G
Part No SW: 5Q0 953 521 L HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151010500634
Coding: 0600
ROD: EV_SMLSVALEOMQB.rod
VCID: 3B23370843E6EAEFDC5-806E
Part No SW: 5E0 920 921 B HW: 5E0 920 921 B
Component: KOMBI 123 6420
Coding: 272402002100A600010808001000000000000000
VCID: 2313EF68DB56B22FF45-8076
Part No SW: 5Q0 907 530 AD HW: 5Q0 907 530 D
Component: GW MQB Low 126 1223
Revision: -------- Serial number: 0004039439
Coding: 030000040F087300EB000048080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 73B3DF282B3662AFC45-8026
Subsystem 2 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001510100558
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000170391512
Coding: 001000208001040100001100
VCID: 45D751F03522AC1FBA1-8010
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 0103
VCID: 44D14CF43E189517ADF-8010
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000169901283
Part No SW: 5Q0 035 842 A HW: 5Q0 035 842 A
Component: MU-S-D-ER H24 0245
Serial number: SKZAZ2R8850053
Coding: 03730100FF00000011111201008800002F0200C60120010000
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CTSAT_VW41.rod
VCID: 2D0709508D92745F521-8078
Subsystem 1 - Part No SW: 5E0 919 605 H HW: 5E0 919 605 H
Component: ABT_Std-2 H41 1028
Serial number: SKZ8Z9RBS00WNZ
End----------(Elapsed Time: 01:17, VBatt start/end: 13.0V/13.1V)-----------
