Long Coding Helper [LCH] ... where are you ?
Fat
USA, E Coast
C?ID=381732
I am very new to the VCDS software, its usability, and so I am going to say my hello and ask a question.
I bought the Ross-Tech just like everyone I imagine. I really want to change some exterior light settings and turn off some of the warning noises.
I have watched quite a few youtubes on how work with the software ...
Ok, off we go. let's do the first Exterior Light Coding ...
* Disable amber corner lights
[09 – Cent. Elect.] [Coding - 07] [Long Coding Helper]
Byte 10 Submodule 0 Bit 3 - Set to 0
So when I select [Coding-07], I don't have a [Long Coding Helper] tab to click ?
* the YouTube Vids I watched all show a [LCH] choice. Is this an issue with the [09-Controller] or am I missing a piece of the software ?
ANY help appreciated.
I'm looking forward to toying at these, but without the [LCH], I'm lost:
* Enable DRL Selectable via MMI
[09 – Cent. Elect.] [Coding – 07] [Long Coding Helper]
Byte 3 Bit 5 - Set to 1
* Disable "Lights are on" Warning
Byte 5 Bit 3 - Set to 0 to disable warning
* Enable DRL
Byte 2:
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
* Enable fog lamp to come on for the same side as turn signal
* Fog Light turns on with turn signal (Curb Side Lighting)
Byte 4 Bit 0 - Set to 1
*Headlights must be on without Fog Lights for this to work
* Keep LED DRL's on With Turn Signals
Byte 3 Bit 7 - Change 1 to 0
Screen Shots
* '11 Audi A6 C6 3.0T Prestige Sport
DV52
C?ID=194404
Fat: Hello and welcome. Now that you have purchased your VCDS - probably wise to register as a forum member - it's quite painless and you get to become "officially recognized", which doubtless like me you can then tick-off your bucket list !!:D
As to your question (and for any other futer questions) it's prudent to post-up a copy of an auto-scan for your car. That way, we get to see what type of vehicle it is (I'm guessing an Audi A6, or perhaps Q7) and we also get to see what other equipment is on the car.
It's highly unlikely that you are "missing a piece of the software" - my guess is that you are using the wrong instructions. But I will suspend suspicion until you post-up the auto-scan
MasterTommy
Amsterdam
C?ID=295586
For one, please post a complete autoscan. Its just text, so no need to make a picture or host it on a different site, just copy paste it in a reply here and put it in between
 and [/ code] tags (without the space).
Second, following any tutorial and/or video is only relatively straightforward if your car is of the same generation, model year, chassis code, etc. The systems in Any brand of car evolve constantly, and changing bits based on what you read in a guide or seen in a video is only safe when you are absolutely sure you have the same car as is the subject of said guide/video, and by exact i mean the criteria stated above, and not model name or year of registration.
For example, any VAG car you buy now could either have an 09 module with settings that are changed in the long coding, in which case a long coding helper is usually (but not always) available. But it could also be your 09 unit has a long coding that consists of only zero’s, in which case usually all settings are changed in adaptations. It could also be your car has a separate comfort electronics control module (which is not module 09), which handles comfort related functions. It could also be that the function you are trying to tweak is not changeable on your vehicle (settings that can be changed and what they can be changed into are 100% module dependent and not decides by VCDS). And lastly, it could also be the system you are trying to make changes to has its own dedicated control module, the BCM is good at doing a lot of different stuff but when a system get more complicated it is handled by a different module.
Typed on phone so apologies for any typos.
PetrolDave
Westbury, UK
C?ID=1423
The Long Coding Helper only appears for modules that use Long Coding (not all do).
As said by both previous replies we need to see a full unedited VCDS Auto-Scan to be able to help you further.
Fat
USA, E Coast
C?ID=381732
Hey guys, thanks for keeping me straight,
So I'll try to get this formatted correctly:
Sunday,06,October,2019,09:07:08:43223
Dealer/Shop Name: TPC
Chassis Type: 4F0
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 72 76
   Mileage: 164730km-102358miles
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Cannot be reached 1100
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603001628256
   Coding: 0000007
   Shop #: WSC 02323 785 00200
   VCID: 2517F161C9EB8B5F9A1-8070
   Subsystem 3 - Part No: 4F0 910 220 G
   Component: FBSAUDIC6 IDG   H01 0053
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01110010
                    Reset counter: 117
                    Mileage: 151342 km
                    Date: 2018.07.28
                    Time: 19:41:04
                    Reset counter: 153
                    Mileage: 164714 km
                    Date: 2019.10.02
                    Time: 11:14:02
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000030574263
   Coding: 0524326
   Shop #: WSC 02325 785 00200
   VCID: 1D67D981E1BB439FC21-8048
   Part No SW: 4F0 910 279 AE    HW: 4F0 907 279 A
   Component: ILM Fahrer      H30 0390
   Coding: 0133122
   Shop #: WSC 02335 785 00200
   VCID: 6C81C4456A817A1705F-8038
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
                    Fault Status: 01111011
                    Fault Frequency: 15
                    Reset counter: 117
                    Mileage: 163256 km
                    Date: 2019.07.11
                    Time: 19:40:00
                    Reset counter: 117
                    Mileage: 164620 km
                    Date: 2019.09.27
                    Time: 09:18:00
                    Reset counter: 150
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:31:00
00532 - Supply Voltage B+
                    Reset counter: 150
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:32:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1577C1A1158B1BDF0A1-8040
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H09 0209
   Revision: 00000000    Serial number: FKX40JX7A
   Coding: 83570A050B00CF05010201
   Shop #: WSC 02391 823 56573
   VCID: 313F15318123D7FF769-8064
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L10807002A
   Coding: 000303
   VCID: 392F2D1159531FBFCE9-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790360108
02076 - Media Player Position 1 (R118)
                    Reset counter: 142
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 14:36:02
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 12
                    Bin. Bits:    10011
01304 - Radio
                    Reset counter: 142
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 15:48:44
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 7
                    Bin. Bits:    10011
                    Reset counter: 153
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:08:30
                    Bin. Bits:    10111
                    Voltage: 10.70 V
                    Count: 7
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00001002044805
   Coding: 00581B00004011110000
   VCID: 323D1A3D8425ECE70F3-8066
Address 46: Central Conv.
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000103255
   Coding: 05000000
   VCID: 290FFD51A9F3AF3FBE9-807C
Address 4C: Tire Pressure II
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000737459
   Coding: 0002014
   VCID: 5EE59E8DAC3D18879BB-800A
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 471H 0A7522656
   Coding: 020007010000000000
   VCID: 2411EC65CED172578DF-8070
   Part No SW: 4E0 035 664 E    HW: 4E0 035 664 A
   Component: H-BN-NA       H49 0189
   Revision: --------    Serial number: 488H40A7537327
   Coding: 010200000202E3EF55000F05EF6300030000
   VCID: 2615F66DB8ED804793B-8072
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466H/0A0079843
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001661693
   Component: CD-Database  1886
                    Reset counter: 102
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 13:40:38
                    Voltage: 12.10 V
                    Reset counter: 113
                    Mileage: 164714 km
                    Date: 2019.10.01
                    Time: 06:50:39
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000100 10000000
Address 62: Door, Rear Left
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Serial number: 12391020308021
   Coding: 0221206
   VCID: 290FFD51A5F3AF3FBE9-807C
End----(Elapsed Time: 01:17, VBatt start/end: 11.8V/11.8V. VIgn 0.0V)------
Just re ran the Auto Scan with engine running ......
Sunday,06,October,2019,09:27:43:43223
VIN: WAUKGAFB0BN024708   License Plate:
Chassis Type: FB-AU56 (4F0)
          56 5F 62 6C 72 76
VIN: WAUKGAFB0BN024708   Mileage: 164730km-102358miles
0E-Media Player 1 -- Status: Sporadic communication error 1000
4C-Tire Pressure II -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H07---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 66565 257 00032
   VCID: 2411EC65C2D172578DF-8070
               U1017 - 000 -  - Intermittent
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:00:35
                    RPM: 1312 /min
                    Mass Air / Rev.: 212.6 mg/str
                    Temperature: 21.0°C
                    Bin. Bits: 00000010
                    Load: 16.5 %
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Mileage: 163935 km
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 27.0°C
                    Bin. Bits: 00000000
                    Voltage: 11.42 V
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0020
   Revision: --H05---    Serial number:        4584852
   VCID: 2A0D025DA0F5A427B73-807E
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E85CE4D5C9D88072BB-803A
                    Reset counter: 153
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:00:24
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0024
                    Hex Value: 0x018D
                    Hex Value: 0x00FF
   Coding: 0000007
00956 - Key 2
                    Reset counter: 117
                    Mileage: 151342 km
                    Date: 2018.07.28
                    Time: 19:41:04
                    Reset counter: 153
                    Mileage: 164714 km
                    Date: 2019.10.02
                    Time: 11:14:02
   Coding: 0524326
   Coding: 0133122
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Fault Frequency: 15
                    Reset counter: 117
                    Mileage: 163256 km
                    Date: 2019.07.11
                    Time: 19:40:00
                    Reset counter: 117
                    Mileage: 164620 km
                    Date: 2019.09.27
                    Time: 09:18:00
                    Reset counter: 150
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:31:00
                    Reset counter: 150
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:32:00
   Revision: AA001001
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FA001D324
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 3635262D68CDF0C723B-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000004VJ6
   Serial number: 3574SRB40000C50CA96E
   Serial number: 3584SRB40000C3D0E126
   Serial number: 3516HRB402HDKJMQS3HQ
   Serial number: 3526HRB402JDKJMR3BA6
   Serial number: 3554NRB400005C59640.
   Serial number: 3564NRB400005C597A79
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90025101990043
   Coding: 0012141
   VCID: 270BFB69B3E7994FA8D-8072
   Component: E0221           H02 0100
   Coding: 000303
                    Reset counter: 142
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 14:36:02
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 12
                    Bin. Bits:    10011
01304 - Radio
                    Reset counter: 142
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 15:48:44
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 7
                    Bin. Bits:    10011
                    Reset counter: 153
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:08:30
                    Bin. Bits:    10111
                    Voltage: 10.70 V
                    Count: 7
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0004000149728
   Coding: 011F57204E40410001
   VCID: 48C958D512B97637417-801C
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01344885370000
   Coding: 4618269
   VCID: 35372121794BFBDF2A1-8060
                    Fault Status: 00101001
                    Reset counter: 151
                    Mileage: 164115 km
                    Date: 2019.09.05
                    Time: 09:40:16
                    Reset counter: 148
                    Mileage: 164552 km
                    Date: 2019.09.23
                    Time: 13:35:51
                    Reset counter: 151
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:30:52
   Coding: 05000000
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H03 0110
   Revision: 00000276    Serial number: 00002760031930
   Coding: 0623301
   VCID: 2313EF79C7DF756FF45-8076
02214 - Tire Pressure Warning
                    Reset counter: 146
                    Mileage: 164124 km
                    Date: 2019.09.05
                    Time: 09:47:12
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.20 V
                    Temperature: 25.0°C
                    (no units): 80.0
                    Fault Status: 11101101
                    Reset counter: 113
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:01:46
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 12.30 V
                    Temperature: 28.0°C
                    (no units): 0.0
                    Fault Status: 00101101
                    Reset counter: 153
                    Mileage: 163258 km
                    Date: 2010.04.16
                    Time: 00:00:23
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 10.00 V
                    Temperature: 28.0°C
                    (no units): 0.0
   Coding: 0002014
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0004000150519
   Coding: 011F57205E40410001
   VCID: 47CB5BE91FA7794F48D-8012
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211FE571DDC3677FE69-8074
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Component: AFS 1           H01 0010
   Coding: 0000026
   VCID: 2B030759AF0FBD2F4C5-807E
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
                    Reset counter: 110
                    Mileage: 164640 km
                    Date: 2019.09.28
                    Time: 16:31:35
                    Reset counter: 102
                    Mileage: 164267 km
                    Date: 2019.09.11
                    Time: 13:40:38
                    Voltage: 12.10 V
                    Reset counter: 113
                    Mileage: 164714 km
                    Date: 2019.10.01
                    Time: 06:50:39
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0004000151900
   Coding: 010E57204040220001
   VCID: 46D556ED18AD6047B3B-8012
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H04---    Serial number: 525PA8-J0721H3
   Coding: 1000304
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0004000151903
   Coding: 0221206
End----------(Elapsed Time: 01:52, VBatt start/end: 13.5V/13.9V)-----------
PetrolDave
Westbury, UK
C?ID=1423
FYI You don't need the engine running, just the ignition on, to access all modules :thumbs:
Fat
USA, E Coast
C?ID=381732
Hi Thanks for the help Dave.
Help me understand the difference between the two scans and why I don't need the engine running to get a complete Auto Scan:
with the "engine NOT running" i couldn't see the faults. "running",... i now can ??
Many (most?) modules in the 4F chassis cars do not use "long" coding. Most still use the older-style short coding.
I'm not sure what car the instructions in the videos you've watched were for, but it's clear they not applicable to the 4F A6.
Was the ignition on?
The ignition needs to be on, but the engine doesn't have to be running. Note that the 4F chassis is quite power-hungry and should not spend much time in Key-ON/Engine-OFF mode unless you connect a battery charger.
Fat
USA, E Coast
C?ID=381732
Excellent Sir. Again, very new to this, these are absolutely the instructions I don't know.
Is there a reference that i can turn to for for the 4F C6 ? I'd like to believe i can accomplish more than reading and clearing codes.
Start here:
http://wiki.ross-tech.com/wiki/index.php/Audi_A6/S6/RS6/allroad_(4F)
Enabling DRLs is done in the regular (short) coding of the 09-CECM module; see here.
0xxxx?x: Daytime Running Lights
0 = w/o Daytime Running Lights
1 = with Daytime Running Lights (not selectable via MMI)
2 = with Daytime Running Lights (selectable via MMI)
That means it's in the second-to-last digit of that module's coding.
Yours is already set to 0133122, meaning DRLs are set to be selectable in the MMI
This was also shown in one of the screen-shots you previously linked to:
You may also want to check some model-specific sections of various Audi forums for things you can do.
Reactions: Fat
Fat
USA, E Coast
C?ID=381732
Thanks Uwe, I'm good with the DRL's , good with the headlights as well as the highs, and the fogs, but I've also got amber corners with 5w bulbs in the front bumper. These are two of the the faults i'm getting. I've replaced the bulbs but still get err message. I'd just as soon turn these off to solve issue.
Faults Found:
                    Fault Frequency: 15
                    Reset counter: 117
                    Mileage: 163256 km
                    Date: 2019.07.11
                    Time: 19:40:00
                    Reset counter: 117
                    Mileage: 164620 km
                    Date: 2019.09.27
                    Time: 09:18:00
Do I keep these Fault Codes as a record ?
Looks like some of them date to 2010.
or, will clearing these faults remove the flashing DIS warning and restore the "Scan Log" to no fault status ?
Thanks again for the hlp, going to start reading up on code scanning and clearing fault codes, doesn't look like i am going to be able to do much of anything else.
PetrolDave
Westbury, UK
C?ID=1423
With fault codes having a date that old it's definitely worth clearing them and seeing if they come back - if they don't then they were a historical record of a fault that no longer exists.
Interesting that the faults are "open circuit" and not flagged "intermittent".
Do these lights currently work?
What kind of bulbs did you install?
Fat
USA, E Coast
C?ID=381732
I'm not getting a bulb at all now.
This is the reason i bought the VCDS. want to just turn these off.
About 2 weeks ago i started getting a warn in the DIS about L corner bulb (WY5W *amber)
Popped the lenses a week ago, swapped bulbs L/R for a few days [warn on right side!]
Pulled both bulbs from sockets for several days, ordered a pair of (W5W *white) bulbs, put them in the sockets, confirmed seat.
Dont think they have worked since. Going to have try a new set of bulbs tomorr.
* thanx, I appreciate your help !
MasterTommy
Amsterdam
C?ID=295586
Make sure you check the contacts for corrosion/fatigue as well. As with license plate light fittings, these aren’t always perfectly watertight and may corrode over time, and the bulb socket itself or whatever part its part of usually doesn’t cost that much.
Well I hate to be the giver of bad news, but I don't think you can arbitrarily disable individual lights on this old CECM. I don't think the module has the flexibility you desire, and VCDS can only change the things that the module has provisions to change.
