Hesitation
Moxnix
C?ID=212386
Suggestions where to start ? New 2019 Allroad, no fault codes everything good with scan but car has slight hesitation accelerating after stop in all modes. Not the end of the world but annoying for sure. Only top tier gas thus far, less than a 1000 miles. Dealer states "no problem found".
The One
Australia
C?ID=277442
Have you compared with a comparable vehicle? It might still be abit early in car age / kms to start saying 'hesitation'..?
Moxnix
C?ID=212386
Well I have a 2017 which runs flawless and have driven several different brand new rental cars over the last month and I would say it's definitely a hesitation. No other way to describe it really, full stop, light acceleration and car does not respond smoothly, almost as if the start/stop function is engaging which is off. No at 65 I am gonna go out on a limb and call this a hesitation but I get your meaning. Car does not have a linear response to throttle input. Hesitates then advances smoothly.
DV52
C?ID=194404
^^^^ if the car has a MQB platform, the tweak for this would be changing IDE06419-Driving profile switchover on hex44 module from Incremental: controlled over time to Direct: controlled over threshold value' (using SA 19249)
downtime
C?ID=280813
^ Which only makes a marginal difference :(
This "hesitation" you call it, seems to be a common issue with newer VAG cars with direct shift automatic gearboxes. I don't know if it's due to emission software or whatnot as older than 2017 cars I've not encountered this kind of an issue. It's definitely an intentional software made feature of the engine and gearbox.
I had the same issue with my diesel Tiguan. There's a clear delay when accelerating from standstill and also if you accelerate quickly so that the car needs to do kickdown or even a normal one gear downshift.
No matter if you start-stop enabled or not. Same delay is presented.
How I fixed it (or made it almost non-existent) was getting a remap to the engine :) After the remap the delay is really really minimal compared to what it was on stock.
Our 2013 gasoline DSG Leon does not have any kind of delay. It has completely different characteristics compared to the newer car. That makes me suspect the software with some kind of emission lowering settings or something.
And seems particularly bad on the 1.5TSI engine with ACT - some Skoda owners in the UK report that VAG have released new engine ECU firmware which reduces but not solves the problem. Some owners have even started the process of rejecting their new vehicle as they consider it to be unsafe.
Moxnix
C?ID=212386
Well let me thank all of the posters for their input which seems to be right on target and especially Don whose suggestion I will undertake this week. Fortunately this issue only presents itself at a full stop and not once underway. It's also somewhat easier to deal with when you find out it's a known issue as I haven't come across this with a new car before so thanks for that.
Best to all
Moxnix
C?ID=212386
Thanks for the tip Don. Looks like mine is a MLB platform, oh well.
downtime
C?ID=280813
It should have the same setting in steering assist module. Check it
Moxnix
C?ID=212386
I will indeed, soon as the car is back in town. Thanks
Moxnix
C?ID=212386
Okay went to 44,basic settings and only available IDE are
IDE00498_MAS00675 reset all
IDE01475_MAS00675 reset all adaptations
IDE03467_MAS00675 rest learned values for steering assistance
ENG138072-MAS00675 warning lamp test
Did nothing just exited, then did auto scan
I notice there is a steering assist fault but I made no changes whatsoever, just looked and backed out. Any input appreciated. Also I did it with 19.6.1 have since updated.
Tuesday,08,October,2019,21:26:45:30397
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WA19NAF43KA115420   License Plate: 2019
Mileage: 2143km-1331mi   Repair Order:
Chassis Type: F4-AU49 (80A)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 36 39 3C 42 44 46 47 52
          5F 6C 6D 74 75 81 82 8B A5 BB BC CA CF D6 D7
VIN: WA19NAF43KA115420   Mileage: 2143km-1331miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 AB    HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0003
   Revision: --H15---
   Coding: 326500322366010E34280000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0208W0906259AB 001004
   ROD: EV_ECM20TFS0208W0906259AB.rod
   VCID: 014A5EEE907FB74796-8054
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 BN    HW: 0HK 927 156 B
   Component: 0CJ 20TFSINAR H01 0002
   Revision: --H01---    Serial number: 0000000273
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 76A03D32C9B180FFB3-8022
   Manual Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Part No SW: 8W0 907 379 AE    HW: 8W0 907 379 D
   Component: ESP9 Premium  H16 0777
   Coding: 18AA409928A32A9B91A24893207D52A2E5359A180214548912044A45A7AC59
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHCMP 002013
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 085C43CAB345860FD1-805C
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 AA    HW: 8W0 820 043 AA
   Component: Klima Zone 3  H60 0251
   Coding: 240809095544010D10020100080000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 72A80122A5D99CDF9F-8026
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000003895280
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: 0FC1DAB900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Coding: 07500363E0691CCD0517511958AE98B9110B3D080000000000000000200016010A69012B025709
   Shop #: WSC 06325 790 00001
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 034654E68A63A55784-8056
   Subsystem 1 - Part No SW: 8W1 955 119 A    HW: 566 955 119
   Component: J400FRWISCH  051 0822
   Serial number: 887353F0401917408712
   Coding: 7DC727
   Serial number: 23317216X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AL    HW: 4M0 941 531 AL
   Component: E1 - LDS  H06 0008
   Serial number: 02 04 2019  01930063
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z016202
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20190516212916 01332
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE101051923610434
   Coding: 030000
   Interior Light Module:
   Subsystem 7 - Part No SW: 4K0 947 135 AB    HW: 4K0 947 135 AB
   Component: Dachmodul  H42 0413
   Serial number: B01068156
   Coding: 0D0104
   Subsystem 8 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 4919000078520001
   Seat Backrest Fan 1 Front Left:
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BJ171A1198
   Seat Cushion Fan 1 Front Left:
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BJ17081875
   Seat Backrest Fan 1 Front Right:
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BJ17050824
   Seat Cushion Fan 1 Front Right:
   Subsystem 12 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BJ15676032
   Part No SW: 8W0 907 561 C    HW: 8W0 907 561
   Component: LRR4          H10 0340
   Coding: B4779FF258FFEC09959A81A1
   ASAM Dataset: EV_ACCBOSCHAU49X 003022
   ROD: EV_ACCBOSCHAU49X.rod
   VCID: 3E30E512A10108BFAB-806A
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 M    HW: 8W0 959 655 M
   Component: Airbag10.44   H05 0109
   Serial number: 0030C001K1SM
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 53E6A4A63A83F5D774-8006
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 8W0857705M0196T00490
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 8W0857706P0196T01850
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000BY6ZY0H
   Subsystem 4 - Part No SW: -----------    HW: 442 061 706 19
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00AD30BBBC2805D
   Subsystem 5 - Part No SW: -----------    HW: 442 061 706 19
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y00AD30BBBC1D11F
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 407 19
   Component: SideSensor_Dr  1C7 0148
   Serial number: 3517700C7328BA23F22E
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 407 19
   Component: SideSensor_Pr  1C7 0148
   Serial number: 3527700C7328BA2422BC
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 906 19
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500A93272093E0B9
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 906 19
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500AB3272093624%
   Part No SW: 4N0 907 129 G    HW: 4N0 907 129 G
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 3522FA3E9437CBE77A-8060
   Part No SW: 8W5 920 890 E    HW: 8W5 920 890 E
   Component: FBenUSA       H20 0417
   Coding: 09C699C3FC88CF0502A3E9601800400008000000
   ASAM Dataset: EV_DashBoardAU736 001032
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 45C28AFEC4D75B67EA-8010
   Part No SW: 80A 907 468 F    HW: 80A 907 468 B
   Component: Gateway       H05 0207
   Serial number: 1JF08063739301
   Coding: 03010001000006402907000000590032DCBA0007100000000175078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU49.rod
   VCID: 312ACE2E605FE7C726-8064
   Subsystem 1 - Part No SW: 4M0 951 523     HW: 4M0 951 523
   Component: J453 MFL  H06 0004
   Serial number: 20190705121326 30883
   Serial number: 3319261905
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8W9 927 755     HW: 0CJ 927 749 A
   Component: B9_DL3_H_SD6H01 0006
   Serial number: 19123B1398
   Coding: 11040000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 0B567CC6A233ED17FC-805E
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   ROD: EV_LCMLeftHELLAAU736_VW48.rod
   VCID: 78BC330AC3A5F68FA1-802C
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000381676673
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
   VCID: 79BA360EF8AFEF87DE-802C
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 566 F    HW: 4M0 907 566
   Component: MRR1Rear      H22 0440
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 383CF30A8325368F61-806C
   Part No SW: 4M0 959 793 M    HW: 4M0 959 793 J
   Component: TSG FS        010 0384
   Serial number: 0000382641495
   Coding: 005D0B215200108000010032
   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod
   VCID: 48DC83CAF3C5460F11-801C
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 0D008380008080
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42C891E2D5F96C5FCF-8016
   Part No SW: 8W1 907 064 AC    HW: 8W1 907 064 C
   Component: BCM2 MLBevo   044 0529
   Coding: 013400004FB100C0650BA0006C01080203004000810026502F0400000F04803F001E0001000010
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 7EB02512E181C8BFEB-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1916023R7
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047503227
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: 12214244
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAKJA064DD+
   Coding: 0194420800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   Part No SW: 4M0 959 792 M    HW: 4M0 959 792 J
   Component: TSG BFS       010 0384
   Serial number: 0000382798405
   Coding: 005D0B215E00108000010030
   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod
   VCID: 47DE80F6FEDB497718-8012
   Part No SW: 8W5 035 880 E    HW: 8W5 035 880
   Component: MU-P-LNS-US   035 1316
   Serial number: A798G0KB164327
   Coding: 019442020000000051220002041A00332F000CE401700904BE
   VCID: 41CA9EEED0FF7747D6-8014
   Subsystem 1 - Part No SW: V03 959 802 DM    HW: -----------
   Component: NAR 2019/2020  --- 0072
   Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00116041900820658
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK103071900020586
   Component: Gracenote2  --- 3013
6696 - Instrument Cluster Control Module on Optical Bus
          U10C0 00 [008] - No Communication
          [Control module for instrument cluster display: no communication]
                    Reset counter: 71
                    Mileage: 1604 km
                    Date: 2019.10.02
                    Time: 19:46:18
                    Voltage terminal 30: 13.0 V
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG085323
   Coding: 02940202BA0FA10038004000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 0570
   VCID: 3424C73A9F4DD2EF4D-8060
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 T    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H37 1215
   Serial number: 1507190602
   Coding: 1051506158
   ASAM Dataset: EV_ChassContrContiAU426 001003
   ROD: EV_ChassContrContiAU426.rod
   VCID: 58FC538A2365D68F81-800C
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F120500
   Coding: 01C020FE4040800000
   ASAM Dataset: EV_ConBoxAU651 002004
   ROD: EV_ConBoxAU651_002.rod
   VCID: 281C234A5385A60FF1-807C
458759 - Control Module Incorrectly Coded
          U1014 00 [008] - -
          [ECU_coded_wrong]
                    Reset counter: 80
                    Mileage: 19 km
                    Date: 2019.09.05
                    Time: 10:47:15
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 8W1 713 041 N    HW: 8W1 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19071253778965
   ASAM Dataset: EV_GSMWaehlZFAU736 001017
   ROD: EV_GSMWaehlZFAU736.rod
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 8W5 919 617 B    HW: 8W5 919 617 B
   Component: HeadUpDisplay H21 1640
   Coding: 4F01E0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736.rod
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 C    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 003022
   ROD: EV_ACC2BOSCHAU49X.rod
   VCID: 3C34EF1AB71D1AAF85-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 E    HW: 8W0 907 217 C
   Component: BVS           H18 0055
   Coding: 0404090200000202022023A6AD0000FCB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   Part No SW: 4M0 959 795 M    HW: 4M0 959 795 J
   Component: TSG HFS       010 0384
   Serial number: 0000381978234
   Coding: 000D0B200000108040000020
   ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
   VCID: 4AD8B9C2EDC9B41F07-801E
   Component: TSG HBFS      010 0384
   Serial number: 0000381978404
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 4K0 907 594 AA    HW: 4K0 907 594
   Coding: 228040049202
   ROD: EV_SunRoofCONTIAU736_009_AU49.rod
   VCID: 73A60426DAC395D794-8026
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 F    HW: 4M0 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   ROD: EV_RearRadarS2BoschAU736.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16601DB2E9F120FF53-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:26, VBatt start/end: 12.3V/12.2V)-----------
downtime
C?ID=280813
Why did you go to basic settings when the adaptation values are under adaptation menu?
Moxnix
C?ID=212386
i did it without going back and reading the posts?
downtime
C?ID=280813
Ok :)
The thing your are looking for is to be found under module 44 - Steering assist -> Adaptation.
Even better is that if you could take a module map from module 44 and post it here? VCDS -> Applications -> Control module map, write 44 as module address and choose csv as output format and Go. It will get an adaptation map what you can post here.
Moxnix
C?ID=212386
Will do, thanks for the help and I will take more care following instructions. I also was thrown off a little because I had updated my software fairly recently and then when I was out at the car I got the message it wasn't current. Now I am current and will get the info you want me to post. Going to be a couple of days days but I will get it done. Thanks again
Moxnix
C?ID=212386
So do I need a workshop code to get the map?
downtime
C?ID=280813
What do you mean? Security access code? I have not needed it ever when exporting the controller map.
Moxnix
C?ID=212386
Okay I will try again but my window had a field in red for the address (44) and right below it a field, also in red for a workshop code. Pretty sure I followed the instructions properly.
Moxnix
C?ID=212386
Okay put in 19249 and that makes the "do it" field highlight. I did get partial maps but can you give me an idea of how long it should take as the only status bar I see is the rotating symbol "line" up top and the message 2ms latency 3ms latency fluctuation. Do I just wait until the bar stops spinning? Does a message come up when complete?
Are you on this screen? Because there's no [Do It] button on that screen:
See: https://www.ross-tech.com/vcds/tour/controller-channels-map.php
