Results 1 to 10 of 19
Thread: Replacing a haldex controller, gen 5
    New User
    Oct 2019
    Sweden
    am about to replace my faulty haldex gen 5 controller and was wondering what the coding procedure is.
    I can not longer access my haldex controller as it's not responding. MOdule 19 can gateway is reporting a fault 01324, No signal/communication with the awd control module.
    I've however found an old autoscan of the car and the question is if it's just a simple matter of copying the code 0201 of old module and coding the new one to the same code?
    Old part number is 0AY907554F and the new one is 0AY907554L
    Autoscan
     Wednesday,04,July,2018,22:10:14:51156
    VCDS Version: 18.2.1.2 (x64)
    VIN: WAUZZZ8X6FB001294   License Plate:
    Mileage: 37270km-23158mi   Repair Order:
    Chassis Type: 8X-AU21 (8U0)
    Scan: 01 03 08 09 10 14 15 16 17 19 22 25 42 44 46 52 55 5F 62 72
              A9
    VIN: WAUZZZ8X6FB001294   Mileage: 37270km-23158miles
    Address 01: Engine (J623-CWZA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8X0 906 259     HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1900322426010B0002
       Shop #: WSC 00046 412 00000
       ASAM Dataset: EV_ECM20TFS0208X0906259 001006
       ROD: EV_ECM20TFS_AU21.rod
       VCID: 7F08993FE63AA8BC5E-802A
    23651 - Heater Support Pump
              P16C6 00 [032] - Running Dry
    16803 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [032] - -
       Part No SW: 6C0 907 379 A    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0002
       Serial number: 08502182140302
       Coding: 34DF708B8D2333C14916307200552C0EB1CC920C0013E2090F00
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
       VCID: 2D5493777CD6EA2CBC-8078
    Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
       Part No SW: 8XA 820 043     HW: 8XA 820 043
       Component: Klima 1 Zone  H01 0010
       Serial number: 00000000261150
       Coding: 6403080890
       ASAM Dataset: EV_AirCondiFrontAU210 007002
       ROD: EV_AirCondiFrontAU210_007.rod
       VCID: 020E10CB95C8C55431-8056
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 R    HW: 8X0 907 063 R
       Component: BCM PQ35  M   113 0811
       Revision: AD113811
       Coding: 06000A2CA805E3C0201843E02104084C53F7630A21EF5D22E408878700C5
       Shop #: WSC 00046 000 00000
       VCID: 4B90FDEFEA02C41C82-801E
       Subsystem 1 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
       Serial number: 22432198
       Coding: 02005D
       Subsystem 2 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 Q    HW: 8X0 919 475
       Component: PARKHILFE 4K  H03 0070
       Revision: 11001001    Serial number: 37061408601625
       Coding: 000007
       ASAM Dataset: EV_EPHVA14AU21X0000 003006
       ROD: EV_EPHVA14AU21X0000_003.rod
       VCID: 54A2E6933F3C9BE4D3-8000
    Address 14: Susp. Elect. (J250)       Labels:. 6C0-907-359.clb
       Part No SW: 6C0 907 359     HW: 6C0 907 359
       Component: DAEMPFUNGS-SG H04 0007
       Serial number: 01041402000002
       Coding: 82
       ASAM Dataset: EV_SwitcDampeContiTemic 001004
       ROD: EV_SwitcDampeContiTemic.rod
       VCID: 6ADE586B8DB83D1499-803E
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8XA 959 655     HW: 8XA 959 655
       Component: Airbag10.41   H07 0011
       Revision: --------    Serial number: 003NV0001EA$
       Coding: 30323236303230313835554A304C38584153
       ASAM Dataset: EV_Airba1041BPAAU210 001018
       ROD: EV_Airba1041BPAAU210.rod
       VCID: 183A52A3E3547F84FF-804C
       Serial number: 3554VRB404V2G2O828V3
       Serial number: 3575HRB405N2AO0A3HQR
       Serial number: 3585HRB400250QOUBHT9
       Rear Impact Crash Sensor:
       Serial number: 3515ZRB400Q50RN8SHNX
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
       Revision: FF010018    Serial number: 20140402200262
       Coding: 1084204000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3D74A337ACB67AAC0C-8068
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8XA 920 930 C    HW: 8XA 920 930 C
       Component: KOMBI_MEDIUM  H06 0450
       Coding: 13CE01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
       VCID: 4B90FDEFE202C41C82-801E
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0063
       Revision: 1P120037    Serial number: 3741P143300071
       Coding: FBCF1059000100010253
       VCID: 50AAEA830324E7C4F7-8004
       Component: J367-BDM  H07 0190
       Serial number: 31064G41184121925167
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 140107000000000004E7
       Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
       Component: Haldex4Motion H52 7521
       Serial number: HA1-00028.02.14
       Coding: 0201
       VCID: 4E96F4FB1110F134E5-801A
       Component: IMMO          H06 0450
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
       Component: TSG FA        H10 0415
       Coding: 011E02200000000000
       VCID: 55A41B973CC682EC24-8000
       Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
       Component: EPS_TRW_ALow  311 3111
       Serial number: CE420741
       Coding: 0017
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       VCID: 4686CCDBF96039745D-8012
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
       Component: TSG BF        H10 0415
       VCID: 54A2E693373C9BE4D3-8000
       Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
       Component: ****LWR12**** H02 0010
       Serial number: 140221-0002-219
       Coding: 11B3AC1010022500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 4482D6D3CF5C0B6443-8010
       Part No SW: 8XA 035 182     HW: 8XA 035 182
       Component: RMC Cnct Plus H55 0812
       Coding: 0100040200C053470023020103010000010000
       VCID: 040216D387DCCB6403-8050
       Subsystem 1 - Part No SW: 8X0 919 603 B    HW: 8X0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9462D30E2766794
       Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
       Component: TSG HL        H07 0415
       Coding: 010802200000000000
       Component: TSG HR        H07 0415
       Part No SW: 8X0 907 159 C    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 140325202117
       VCID: 428ED0CBD548055471-8016
    End-------------------------(Elapsed Time: 03:28)--------------------------
    16.4905° S, 151.7375° W
    ....the question is if it's just a simple matter of copying the code 0201 of old module and coding the new one to the same code?
    - Thanks for posting your question, make sure you register your VCDS tool, so you can become a verified user here.
    Yes, use the same coding of the old/original J492 controller [0201] and you should have no issues as this controller does not appear to have "Component Protection". However, I can not confirm you will not receive a Parameterization fault code, like "No End of Line Programing". If so the controller will need to go on-line with Audi to clear codes.
    Note: The Factory repair information, says the J492-All Wheel Drive Control Module should be replaced with the N373-Haldex Clutch Control Valve.
    For example:
    Hope this helps,
    drpeter
  3. Likes Boki Ar, Uwe liked this post
    New User
    Oct 2019
    Sweden
    Thank you for the clarification drpeter.
    I'll also check into geting verified, still new to this forum so i'm running around like a blind hen over here
    I've replaced the haldex controller and it read out al OK by vcds. It's old 0505 coding was replaced by my original string 0201 without any issues and all output tests worked out fine, aswell as a testdrive.
    BUT, now i'm getting a 16652 error from the controller, see autoscan
     Monday,07,October,2019,10:03:05:51156
    VCDS Version: 19.6.2.0 (x64)
              A9
    VIN: WAUZZZ8X6FB001294   Mileage: 42860km-26631miles
       Revision: --H13---
       ROD: EV_ECM20TFS0208X0906259.rod
       VCID: 7F08993FE63AA8B7DE-802A
    Readiness: 0010 0001
       VCID: 2D5493777CD6EA273C-8078
       Coding: 6403080890
       VCID: 020E10CB95C8C55FB1-8056
       Coding: 080007
       Shop #: WSC 00046 412 12345
       VCID: 54A2E6933F3C9BEF53-8000
    Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
       Coding: 82
       VCID: 6ADE586B8DB83D1F19-803E
       VCID: 183A52A3E3547F8F7F-804C
       Coding: 1084204000
       VCID: 3D74A337ACB67AA78C-8068
       Coding: 13DE01
       VCID: 4B90FDEFE202C41702-801E
       VCID: 50AAEA830324E7CF77-8004
       Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
       Component: Haldex4Motion H53 7620
       Serial number: HA1-00018.09.15
       Coding: 0201
       Shop #: WSC 02737 790 50316
    16652 - Databus
                        Reset counter: 191
                        Mileage: 42864 km
                        Date: 2019.10.07
                        Time: 09:54:51
       Coding: 000002
       VCID: 55A41B973CC682E7A4-8000
       Coding: 0017
       VCID: 4686CCDBF960397FDD-8012
    Address 46: Central Conv.
       Coding: 011E02200C00000000
       Shop #: WSC 00046 123 12345
       VCID: 54A2E693373C9BEF53-8000
       VCID: 4482D6D3CF5C0B6FC3-8010
       VCID: 040216D387DCCB6F83-8050
       VCID: 428ED0CBD548055FF1-8016
    End-------------------------(Elapsed Time: 03:44)--------------------------
    What i also noticed while swapping the controller is that the new one had pins/contacts on all pins except nr 8 and my old one was missing pin 5 and 6 aswel las pin 8
    Are you sure that the "new" one:
    is an appropriate replacement for the old one?
    The hardware part numbers are very different.
  6. Likes PetrolDave liked this post
    Nov 2015
    You swapped out an 0AY controller for an 0CQ one. I think that would be a problem as they're different hardware.
  8. Likes Uwe, PetrolDave liked this post
  9. #6
    New User
    Oct 2019
    Sweden
    Hmm, never noticed that.
    Why does it come up as a 0CQ controller when the part number written on the controller itself is a
    0AY907554L?
    I was just assuming that it was a newer revision of my original controller as the part numbers were the same apart from the last letter.
  10. #7
    Nov 2015
    Are you confusing software versions with hardware versions?
  11. Likes Uwe liked this post
  12. #8
    New User
    Oct 2019
    Sweden
    Quote Originally Posted by Viking View Post
    Now i'm confused Isn't the number written on the part the hardware number?
    OLD module
    "NEW" Module
  13. #9
    No, that's the software number.
  14. #10
    May 2017
    Also good hint is the H number. Old module is H52, new one is H53 so new one is different HW revision.
    I hope you have return policy for the controller.
  15. Likes Uwe liked this post
