EGR Problem Seat Ibiza
judge360
C?ID=77581
Hi everyone I have a problem with the egr on a seat ibiza which has been changed however the fault is still there and wont clear.
Hereb is the log file from VCDS.
VCDS Version: 19.6.2.0 (x64)
VIN: VSSZZZ6JZDR017950   License Plate:
Mileage: 97210km-60403mi   Repair Order:
Chassis Type: 6J-SE25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZDR017950   Mileage: 97210km-60403miles
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 AB    HW: 03P 906 021 BC
   Component: R3 1.2l TDI   H07 9978
   Revision: 12005001    Serial number:
   Coding: 00114014030501080000
   Shop #: WSC 61398 001 1048576
   ASAM Dataset: EV_ECM12TDI03103P906021AB 001019
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 68D464CE938AE20F0F-803C
15544 - EGR Valve (N18)
          P0403 00 [191] - Malfunction
          MIL ON - Confirmed - Not Tested Since Memory Clear
                    Mileage: 87539 km
                    Date: 2019.03.01
                    Time: 22:21:28
                    Coolant temperature: 68 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 13.640 V
                    Unlearning counter according OBD: 228
                    Sensor for engine block temperature: raw value: 68 °C
                    EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
                    EGR Solen.val.: actual value-PWM rate: 50.2 %
                    EGR valve: offset closed: -4 %
                    Deviation of exh.gas recirc. rate: 0.0 %
                    High press EGR actuator: actual unconditioned volt val: 1.079 V
                    EGR valve: offset open: 2 %
                    High pressure EGR actuator: activation: 0 %
                    OBD EGR position control-Position: 50.2 %
                    EGR specified value: 0.0 %
                    Voltage terminal 30 stabilized: 13.6 V
                    Terminal 15 status: On
16395 - EGR Valve (N18)
          P0403 00 [216] - Malfunction
          MIL ON - Intermittent - Confirmed - Not Tested Since Memory Clear
                    Mileage: 87539 km
                    Date: 2019.03.01
                    Time: 22:47:30
                    Engine speed: 1122.75 /min
                    Vehicle speed: 9 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 14.968 V
                    Sensor for engine block temperature: raw value: 66 °C
                    EGR Vacuum Regulator Solen.val.: activation-PWM rate: 28.2 %
16408 - Actuator Module for Turbocharger 1
          P00AF 00 [216] - Stuck
                    Mileage: 97050 km
                    Date: 2019.10.01
                    Time: 20:27:08
                    Engine speed: 1889.75 /min
                    Normed load value: 99.2 %
                    Vehicle speed: 48 km/h
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.773 V
                    Accelerator pedal travel-Position: 62.7 %
                    Charge Pressure Actuator: activation-PWM rate: 71.8 %
                    Charge air pressure absolute position feedback-Position: 58.8 %
                    Turbocharger boost control: offset closed: -2 %
                    High press turbocharger actuator: actual uncond volt value: 2.944 V
16409 - Actuator Module for Turbocharger 1
                    Mileage: 97050 km
                    Date: 2019.10.01
                    Time: 20:27:08
                    Engine speed: 1897.25 /min
                    Normed load value: 100.0 %
                    Voltage terminal 30: 14.804 V
                    Charge Pressure Actuator: activation-PWM rate: 64.7 %
                    Charge air pressure absolute position feedback-Position: 68.6 %
                    High press turbocharger actuator: actual uncond volt value: 3.435 V
Readiness: 1 2 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 130224DB816E00B9C82E24E781D100921000
   Shop #: WSC 04941 000 00000
   VCID: 00045C6E97FA3A4FA7-8054
Address 08: Auto HVAC        Labels: 6J0-820-045.clb
   Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
   Component: J301  Klimaanlage   0330
   Revision: 00 26 08    Serial number: 0000002454827-
   Shop #: WSC 06402 785 00200
   VCID: 244C30FEE722C66FE3-8070
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0353
   Revision: BU050001    Serial number: 0456 066120016
   Coding: 248829E888612500922008F02E0B8C800F00622F7E000409200000000000
   Shop #: WSC 64564 324 38760
   VCID: 4182996AD870F347E8-8014
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3130
   Coding: 430000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3130
   Coding: 420000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 4 - Part No: 1K8 951 171 A
00329 - Control Circuit for Unlocking Rear Lid
                    Fault Status: 00100110
                    Fault Frequency: 11
                    Reset counter: 43
                    Fault Status: 00101011
                    Reset counter: 47
                    Mileage: 88291 km
                    Date: 2013.08.11
                    Time: 21:03:06
00893 - Switch for Trunk Handle (E234)
                    Reset counter: 47
                    Mileage: 97028 km
                    Date: 2014.02.21
                    Time: 03:00:56
00975 - Heated Rear Window (Z1)
                    Reset counter: 47
                    Mileage: 97028 km
                    Date: 2014.02.21
                    Time: 03:07:08
                    Fault Status: 00100001
                    Reset counter: 27
                    Mileage: 95642 km
                    Date: 2014.01.23
                    Time: 23:22:48
01134 - Alarm Horn (H12)
                    Reset counter: 12
                    Mileage: 86297 km
                    Date: 2013.06.25
                    Time: 06:20:14
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA05 H10 0020
   Revision: --------    Serial number: 003GX015834U
   Coding: 003035
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A90BE46ED46301F39-801E
   Serial number: 3495RRB405F15A9Q80EB
   Serial number: 3505RRB405H15A9QCPR4
   Part No SW: 6J0 920 904 J    HW: 6J0 920 904 J
   Component: KOMBI         H03 0507
   Coding: 410200
   VCID: 3260C6A665D658DF61-8066
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0035
   Revision:   H38       Serial number: 230212F1002310
   Coding: 2542C1
   VCID: 346CC0BE97C256EF73-8060
   Component: IMMO          H03 0507
   VCID: 6AD01EC68D86D01F19-803E
   Part No: 6R0 423 156 B
   Coding: 11211
   Shop #: WSC 06402
   VCID: 2F66CFD2EAE475370E-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70E40CAE635A2ACF57-8024
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H15 0204
   Revision: R0000000    Serial number: SEZAZ2M1963982
   Coding: 0501020002
   VCID: 2A50DEC64506101FD9-807E
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0035
   Coding: 030B185A
   VCID: 74EC00BED74216EFB3-8020
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970397986
End-------------------------(Elapsed Time: 02:28)--------------------------
Address 01: DTCs cleared
                Address 01: Engine       Labels: 03P-906-021-CFW.clb
Control Module Part Number: 03P 906 021 AB    HW: 03P 906 021 BC
  Component and/or Version: R3 1.2l TDI   H07 9978
           Software Coding: 00114014030501080000
            Work Shop Code: WSC 61398 001 1048576
              ASAM Dataset: EV_ECM12TDI03103P906021AB 001019 (SE25)
Fault Codes have been Erased
          P0403 00 [063] - Malfunction
                    Mileage: 97213 km
                    Date: 2019.10.03
                    Time: 22:45:13
                    Coolant temperature: 52 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.085 V
                    Unlearning counter according OBD: 0
                    Sensor for engine block temperature: raw value: 52 °C
                    Voltage terminal 30 stabilized: 12.0 V
Address 09: DTCs cleared
Any help would be really appreciated. Thanks for your time.
HMC
C?ID=28246
Hi judge_360,
Was it a genuine EGR? What wiring checks have you done?
Regards HMC
judge360
C?ID=77581
Hi HMC I never fitted the egr but I suspect its aftermarket, ive not done any checks on wiring yet either.
Also the turbo actuator faults aren't likely helping things.
HMC
C?ID=28246
"I never fitted the egr but I suspect its aftermarket,"
In my experience aftermarket has a high failure rate. Who fitted it and why are they not fixing it?
Regards HMC
judge360
C?ID=77581
The garage Ive just started for fitted it, and I have the job of fixing it. As far as I am aware even after fitting the fault code would not clear.
judge360
C?ID=77581
Hi everyone, I need some help trying to fix this car, the egr has been changed, the turbo and actuator has been renewed and the N75 valve has been renewed yet I still have the same fault codes and the car is exactly the same as when it first came in. I am at my wits end and don't know where to go next, any help would be greatly appreciated. Thanks.
judge360
C?ID=77581
Thought I would update this thread as I found out what was wrong with this car. After checking the wiring from the ecu to the egr I noticed a loose connection on one of the wires on the block connector that went onto the egr. I fixed that and the car has had no more issues and runs great now. Thanks for the help. :)
