Hi everyone I have a problem with the egr on a seat ibiza which has been changed however the fault is still there and wont clear.
Hereb is the log file from VCDS.
Any help would be really appreciated. Thanks for your time.
VCDS Version: 19.6.2.0 (x64)
VIN: VSSZZZ6JZDR017950 License Plate:
Mileage: 97210km-60403mi Repair Order:
Chassis Type: 6J-SE25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56 61
VIN: VSSZZZ6JZDR017950 Mileage: 97210km-60403miles
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AB HW: 03P 906 021 BC
Component: R3 1.2l TDI H07 9978
Revision: 12005001 Serial number:
Coding: 00114014030501080000
Shop #: WSC 61398 001 1048576
ASAM Dataset: EV_ECM12TDI03103P906021AB 001019
ROD: EV_ECM12TDI03103P906021AA.rod
VCID: 68D464CE938AE20F0F-803C
15544 - EGR Valve (N18)
P0403 00 [191] - Malfunction
MIL ON - Confirmed - Not Tested Since Memory Clear
Mileage: 87539 km
Date: 2019.03.01
Time: 22:21:28
Coolant temperature: 68 °C
Intake air temperature: 18 °C
Voltage terminal 30: 13.640 V
Unlearning counter according OBD: 228
Sensor for engine block temperature: raw value: 68 °C
EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
EGR Solen.val.: actual value-PWM rate: 50.2 %
EGR valve: offset closed: -4 %
Deviation of exh.gas recirc. rate: 0.0 %
High press EGR actuator: actual unconditioned volt val: 1.079 V
EGR valve: offset open: 2 %
High pressure EGR actuator: activation: 0 %
OBD EGR position control-Position: 50.2 %
EGR specified value: 0.0 %
Voltage terminal 30 stabilized: 13.6 V
Terminal 15 status: On
16395 - EGR Valve (N18)
P0403 00 [216] - Malfunction
MIL ON - Intermittent - Confirmed - Not Tested Since Memory Clear
Mileage: 87539 km
Date: 2019.03.01
Time: 22:47:30
Engine speed: 1122.75 /min
Vehicle speed: 9 km/h
Coolant temperature: 66 °C
Intake air temperature: 30 °C
Voltage terminal 30: 14.968 V
Sensor for engine block temperature: raw value: 66 °C
EGR Vacuum Regulator Solen.val.: activation-PWM rate: 28.2 %
16408 - Actuator Module for Turbocharger 1
P00AF 00 [216] - Stuck
Mileage: 97050 km
Date: 2019.10.01
Time: 20:27:08
Engine speed: 1889.75 /min
Normed load value: 99.2 %
Vehicle speed: 48 km/h
Intake air temperature: 11 °C
Voltage terminal 30: 14.773 V
Accelerator pedal travel-Position: 62.7 %
Charge Pressure Actuator: activation-PWM rate: 71.8 %
Charge air pressure absolute position feedback-Position: 58.8 %
Turbocharger boost control: offset closed: -2 %
High press turbocharger actuator: actual uncond volt value: 2.944 V
16409 - Actuator Module for Turbocharger 1
Mileage: 97050 km
Date: 2019.10.01
Time: 20:27:08
Engine speed: 1897.25 /min
Normed load value: 100.0 %
Voltage terminal 30: 14.804 V
Charge Pressure Actuator: activation-PWM rate: 64.7 %
Charge air pressure absolute position feedback-Position: 68.6 %
High press turbocharger actuator: actual uncond volt value: 3.435 V
Readiness: 1 2 0 0 1
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 130224DB816E00B9C82E24E781D100921000
Shop #: WSC 04941 000 00000
VCID: 00045C6E97FA3A4FA7-8054
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
Component: J301 Klimaanlage 0330
Revision: 00 26 08 Serial number: 0000002454827-
Shop #: WSC 06402 785 00200
VCID: 244C30FEE722C66FE3-8070
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0353
Revision: BU050001 Serial number: 0456 066120016
Coding: 248829E888612500922008F02E0B8C800F00622F7E000409200000000000
Shop #: WSC 64564 324 38760
VCID: 4182996AD870F347E8-8014
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3130
Coding: 430000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3130
Coding: 420000
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 171 A
00329 - Control Circuit for Unlocking Rear Lid
Fault Status: 00100110
Fault Frequency: 11
Reset counter: 43
Fault Status: 00101011
Reset counter: 47
Mileage: 88291 km
Date: 2013.08.11
Time: 21:03:06
00893 - Switch for Trunk Handle (E234)
Reset counter: 47
Mileage: 97028 km
Date: 2014.02.21
Time: 03:00:56
00975 - Heated Rear Window (Z1)
Reset counter: 47
Mileage: 97028 km
Date: 2014.02.21
Time: 03:07:08
Fault Status: 00100001
Reset counter: 27
Mileage: 95642 km
Date: 2014.01.23
Time: 23:22:48
01134 - Alarm Horn (H12)
Reset counter: 12
Mileage: 86297 km
Date: 2013.06.25
Time: 06:20:14
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagA05 H10 0020
Revision: -------- Serial number: 003GX015834U
Coding: 003035
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A90BE46ED46301F39-801E
Serial number: 3495RRB405F15A9Q80EB
Serial number: 3505RRB405H15A9QCPR4
Part No SW: 6J0 920 904 J HW: 6J0 920 904 J
Component: KOMBI H03 0507
Coding: 410200
VCID: 3260C6A665D658DF61-8066
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0035
Revision: H38 Serial number: 230212F1002310
Coding: 2542C1
VCID: 346CC0BE97C256EF73-8060
Component: IMMO H03 0507
VCID: 6AD01EC68D86D01F19-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11211
Shop #: WSC 06402
VCID: 2F66CFD2EAE475370E-807A
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70E40CAE635A2ACF57-8024
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J2 035 153 G HW: 6J2 035 153 G
Component: Radio H15 0204
Revision: R0000000 Serial number: SEZAZ2M1963982
Coding: 0501020002
VCID: 2A50DEC64506101FD9-807E
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0035
Coding: 030B185A
VCID: 74EC00BED74216EFB3-8020
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970397986
End-------------------------(Elapsed Time: 02:28)--------------------------
Address 01: DTCs cleared
Address 01: Engine Labels: 03P-906-021-CFW.clb
Control Module Part Number: 03P 906 021 AB HW: 03P 906 021 BC
Component and/or Version: R3 1.2l TDI H07 9978
Software Coding: 00114014030501080000
Work Shop Code: WSC 61398 001 1048576
ASAM Dataset: EV_ECM12TDI03103P906021AB 001019 (SE25)
Fault Codes have been Erased
P0403 00 [063] - Malfunction
Mileage: 97213 km
Date: 2019.10.03
Time: 22:45:13
Coolant temperature: 52 °C
Intake air temperature: 35 °C
Voltage terminal 30: 12.085 V
Unlearning counter according OBD: 0
Sensor for engine block temperature: raw value: 52 °C
Voltage terminal 30 stabilized: 12.0 V
Address 09: DTCs cleared
