Results 1 to 7 of 7
Thread: esp front mk 60
    Nov 2014
    Norway
    esp front mk 60
    Hi
    oblem with esp front mk 60..so no i have removed the whole esp mk 60 and replaced it..The light is still on and i cant erase the light..and when i se in the scan log it have become many faults on the esp.Is there anyone that know how to erase and remove the faults on esp front??Cant do it the normal way.
    Wednesday,07,January,2015,15:27:14:45374
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN: WVGZZZ1TZ5W013138   License Plate:
    Mileage: 214960km-133569mi   Repair Order:
    Chassis Type: 1T (1K0)
    Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 55 56 62 69 72
    VIN: WVGZZZ1TZ5W013138   Mileage: 214960km-133569miles
    Address 01: Engine        Labels: 03G-906-016-BKC.lbl
       Part No SW: 03G 906 016 DK    HW: 028 101 194 6
       Component: R4 1,9L EDC G000AG  6247
       Revision: 12345678    Serial number: VWZ7Z0D0029025
       Coding: 0000078
       Shop #: WSC 01324 785 00200
       VCID: 6FEDDDF97E2C3259861-803A
       Part No SW: 02E 300 041 R    HW: 02E 927 770 AD
       Component: GSG DSG         041 0812
       Revision: 00004010    Serial number: 00000405250202
       VCID: 2149EBC1F878D429405-8074
    18255 - Please check DTC Memory of ABS Controller
                P1847 - 000 -
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0021190
       VCID: 3A7B3CAD75EEA7F161F-806F
    00493 - ESP-Sensor Unit (G419)
    00810 - Sensor 1/2 for Brake Pressure
       Part No: 1K0 907 044 L
       Component: ClimatronicPQ35 061 0201
       VCID: 306F1E85A3926DA1DFB-8065
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
       Component: Bordnetz-SG 1.0 H30 0704
       Revision: 00030000    Serial number: 00000000821478
       Coding: 0B8B8F020004200000120C000000000000
       VCID: 408F4E451332FD212FB-8015
       Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW358  012  0401
       Coding: 00065493
    01064 - Terminal 58d; Interior Dimming
    Address 15: Airbags        Labels: 1T0-909-605.lbl
       Part No SW: 1T0 909 605 B    HW: 1T0 909 605 B
       Component: 02 AIRBAG VW62 0506 1400
       Revision: 07023000    Serial number: 0037SD07T225
       Coding: 0012338
       VCID: 34671295578A5181BB3-8061
       Part No SW: 1K0 953 549 AM    HW: 1K0 953 549 AM
       Component: J0527           032 0070
       Coding: 0010042
       Shop #: WSC 00220 218 55170
       VCID: 7DF1F7B1244050C904D-8028
       Part No: 1T0 920 861 A
       Component: KOMBIINSTRUMENT VDD 0714
       Coding: 0007103
       Shop #: WSC 00011 888 96745
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 1K0 815 071 H
       Component: Zuheizer        031 1312
       Revision:        A    Serial number: 09010046
       Coding: 0000011
       Shop #: WSC 00690 218 178596
       VCID: 2A5B0CED854E177111F-807F
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2600104519027B
       Coding: 7F3F5340078002
       VCID: 275DF5D9965C2A190E1-8072
       Component: IMMO            VDD 0714
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1T0 959 701
       Component: Tuersteuergeraet 09 0157
       Coding: 0000116
       VCID: 74E7D295170A11817B3-8021
       Part No: 1K1 909 144 G
       Component: EPS_ZFLS Kl.0       1401
       VCID: 2F6D1DF9BEAC7259C61-807A
    Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 C
       Component:    KSG              0201
       Coding: 00E802087F2D8404084F0100
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1T0 959 702
       Coding: 0000116
       VCID: 75E1EF911C7008894CD-8020
       Part No: 1T0 907 357
       Component: Dynamische LWR      0002
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D5107F1B4A00049F4D-8078
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 B
       Component: Tuersteuergeraet 06 0214
       Coding: 0000048
    Address 69: Trailer
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 B
       Coding: 0000048
    End-------------------------(Elapsed Time: 01:56)--------------------------
    Do you have a scan from before you replaced it?
    Where did you get the replacement module? Is it the correct one?
    Nov 2014
    Norway
    Hi
    Had some trouble with sending the post..i bought the item used from a dealer.And it was working..i Checked the item up with my car from vw.part number on the other car.and reg number.and my car and that car had identical part numbers.I think that i maibe have to go in too the different fault codes and erase it??i have only had a full scan and then clear all dtc or dts?? And the fault code was still there..I was srating up my webasto..and then i had to set in a number and then it was working..If someone knows wat i can doo???
    Its the adress 03..
    Sunday,30,November,2014,16:24:40:45374
    Mileage: 213140km-132439mi   Repair Order:
    VIN: WVGZZZ1TZ5W013138   Mileage: 213140km-132439miles
       Coding: 0000078
                P1847 - 000 -
       Component: ESP FRONT MK60      0103
       Coding: 0021190
       Coding: 00065493
       Coding: 0012338
       Coding: 0010042
       Coding: 0007103
       Coding: 0000011
                        Fault Frequency: 19
                        Reset counter: 181
                        Mileage: 200974 km
                        Time: 16:21:38
    00664 - Fuel gauge
                        Fault Frequency: 16
                        Reset counter: 90
                        Mileage: 212981 km
                        Time: 17:59:26
    01410 - Heater Over-Temp
                000 -  -  - Intermittent
                        Reset counter: 217
                        Mileage: 185813 km
                        Time: 06:25:58
                            Ctrl. Pause
                        Temperature: 148.0C
                        Temperature: 7.0C
    02251 - Heater Unit Locked
                        Reset counter: 217
                        Mileage: 185813 km
                        Time: 06:25:58
    01411 - Temperature Sensor (G18)
                        Fault Status: 00100111
                        Fault Frequency: 255
                        Reset counter: 231
                        Mileage: 204405 km
                        Time: 23:17:19
                            Malfunction
                        Temperature: 205.0C
                        Temperature: 43.0C
       Coding: 0000116
       Component:    KSG              0201
       Coding: 0000116
       Coding: 0040400
       Coding: 0000048
    Address 69: Trailer
       Coding: 0000048
    End-------------------------(Elapsed Time: 01:53)--------------------------
    Jun 2014
    Poland
    G419 is a DuoSensor located under glove box , near Passenger Airbag switch
    this is a separate sensor, If replacement pump cant see it , seems pump is faulty (your old one havent see that problem)
    of course you can try replaced it (easier to replace it then whole ABS) , but I will look also for each wire ABS <-> Duo Sensor
    but 1st - try do that adaptations
    Nov 2014
    Norway
    i have replaced the whole abs unit.?it`s the abs module that i have changed erlier and it`s after that the 5 faults came on adress 03.how can i erase fault codes??? step by step..I have sendt some things here erlier and then people told me that the pump ++ was broken on some other things..i went in on the spesific module on the computer program and got a step by step way to erase the fault..and everything works perfektly now.I have tried to clear more faults and now there are 3 faults instead of 5 faults.. the faults that are back is
    Have you looked at this page?
    http://wiki.ross-tech.com/wiki/index...#Basic_Setting
  7. #7
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by bjkandre View Post
    I do not think you are getting this.
    ESP sensor is separate unit from ABS unit.So replacing ABS unit will not fix ESP sensor code.
    Other codes will be clear when you do adaption what UWE post it. .
