Results 1 to 8 of 8
Thread: Audi a4 2013
    Mar 2018
    Italy
    Audi a4 2013
    hello, i have audi a4 in my garage vin WAUZZZ8K8DA234004,my customer changed POWER STEERING ECU with used one,now i have dtc actived C10AC07-C10AD29-C10ACF0,can i solve with vcds?thanks.
    Mar 2018
    Italy
    Thursday,03,October,2019,15:34:55:40494
    VIN: WAUZZZ8K8DA234004   License Plate:
    Mileage: 218240km-135608mi   Repair Order:
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 72
    VIN: WAUZZZ8K8DA234004   Mileage: 218240km-135608miles
    44-Steering Assist -- Status: Malfunction 1010
    Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 HT    HW: 03L 906 018 JL
       Component: R4 2,0L EDC   H25 3110
       Revision: 45H25---
       Coding: 12034012230401080000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TDI01103L906018HT 003006
       ROD: EV_ECM20TDI01103L906018HT.rod
       VCID: 034678CE8A8B3657BA-8056
    18735 - Steering Effort Control Module
              U0130 00 [032] - No Communications
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 17:14:22
                        Coolant temperature: 60 °C
                        Intake air temperature: 48 °C
                        Voltage terminal 30: 12.240 V
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 8K9 927 155 A    HW: 0AW 927 156 K
       Component: 0AW 20TDI RdW H05 0001
       Revision: --H05---    Serial number: 0000001025
       Coding: 000002
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMVL381 A02432
       ROD: EV_TCMVL381.rod
       VCID: 3A38C52ABDC1B79FA9-806E
       Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
       Component: ESP8 front    H09 0100
       Coding: 171544
       VCID: 004C77C2939D2D4FA7-8054
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 2
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 17:35:13
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x000A
                        Hex Value: 0xC095
                        Hex Value: 0x0000
                        Reset counter: 2
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 18:20:39
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x0010
                        Hex Value: 0x1095
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
       Component: BCM2 2.0      H12 0633
       Coding: 01A24040000000000000
       VCID: 77BE1C1EC6536AF796-8022
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0813000039822011
       Part No SW: 8K1 820 043 AG    HW: 8K1 820 043 AG
       Component: KLIMA 1 ZONE  H02 0122
       Revision: A1000000    Serial number: 01050420130256
       Coding: 342002E000
       VCID: 6D923E76B40FD0277C-8038
       Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
       Revision: 04016001    Serial number: 00000581886102
       Coding: 29000030803400C00081000300001F1F001C460826080401000004004001020000000020000000
       VCID: 74A42B12D72501EFB3-8020
       Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: MITSUBA130912  H18 0461
       Serial number: 12091207003610
       Coding: 004577
       Subsystem 2 - Part No SW: 8K0 941 531 AR    HW: 8K0 941 531 AR
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002203135369
       Subsystem 3 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Serial number: 7F6880A6000000000001
       Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Serial number: 20330410
                        Reset counter: 253
                        Mileage: 218024 km
                        Date: 2019.09.25
                        Time: 19:41:49
       Serial number: 003KFD999E6C
       Coding: 30514435363030303030554A304C384B3053
       Shop #: WSC 00765 002 1048576
       VCID: 48DCAFE2F32DD50F2F-801C
       Serial number: 6334MSME7B062645E
       Serial number: 6344MSME7B03122DD
       Serial number: 6352QSME202F117CH
       Serial number: 6362QSME4C2F0678W
       Serial number: 63732SME252F5740$
       Serial number: 63832SME735A47250
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20130403001553
       Coding: 000013
       VCID: 4FEE84FE1E4302376E-801A
       Part No SW: 8K0 920 901 F    HW: 8K0 920 901 F
       Component: KOMBIINSTR.   H09 0556
       Revision: 00500000    Serial number: UVF79PM3E
       Coding: 1386100002010008040000
       VCID: 2E10F97A79896B3F05-807A
                        Reset counter: 42
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 17:14:23
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0056
       Revision: 1V080027    Serial number: 2741V1332084C6
       Coding: 80CF07FF00
       VCID: 48DCAFE2FB2DD50F2F-801C
       Serial number: 9332400203
       Serial number: 13085000918011200410
                        Reset counter: 42
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 17:14:23
                        Bin. Bits:    10111
                        Voltage: 12.20 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Component: TSG FA        H02 0508
       Revision:             Serial number: 0000054839207
       Coding: 011002205C00410001
       Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
       Component: RCEPS         H41 0509
       Revision: 00001000    Serial number: 0021120637
       Coding: 100000010001
       Shop #: WSC 06334 123 12345
       ASAM Dataset: EV_RCEPSAU48X 008016
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 383CDF2283CDA58F5F-806C
    5258760 - Steering
              C10AC 07 [137] - Mechanical Failure
              [Einfriergefahr der Lenkung]
                        Mileage: 217981 km
                        Date: 2019.09.02
                        Time: 20:50:25
                        Write only channel
    7341600 - Position Sensor for Motor
              C10AD 29 [137] - Signal Implausible
              [Unplausible Werte vom Resolver (Warnung)]
                        Reset counter: 2
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 19:00:36
                        Write only channel
    7341570 - Position Sensor for Motor
              [Unplausible Werte vom Resolver (beherrschbarer Fehler)]
                        Mileage: 217981 km
                        Date: 2019.09.02
                        Time: 20:49:31
                        Write only channel
              [Lenkungsendanschläge nicht angelernt]
                        Fault Frequency: 11
                        Reset counter: 8
                        Mileage: 218247 km
                        Date: 2019.10.02
                        Time: 19:00:36
                        Write only channel
       Revision: 00002001    Serial number: 0303807813
       Coding: 0100062020B90080812002368000000F
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 252
                        Mileage: 218008 km
                        Date: 2019.09.11
                        Time: 12:17:47
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 252
                        Mileage: 218008 km
                        Date: 2019.09.11
                        Time: 12:18:19
       Component: TSG BF        H02 0508
       Revision:             Serial number: 0000056016776
       Coding: 011002205E00410001
       VCID: 4ED099FA19490B3F65-801A
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 00000001280447
       ROD: EV_ParkiBrake_AU48.rod
       Part No SW: 8R1 035 186 N    HW: 8R1 035 186 N
       Component: Concert3      H09 0470
       Revision: 00000003    Serial number: AUZ5Z6N2086828
       Coding: 0500048004020500015A071000
       Shop #: WSC 13334 002 1048576
       VCID: 40CCB7C2D31DED4FE7-8014
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
       Revision:             Serial number: 0000056059993
       Coding: 010002204000210001
       VCID: 46C0A1DAF139C37FDD-8012
       Revision:             Serial number: 0000056051048
    End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
    I do not think you can solve faults like "Mechanical Failure" and "Signal Implausible" with VCDS.
  5. Likes Jack@European_Parts, PetrolDave liked this post
    Mar 2018
    Italy
    hello,thanks for reply,i tried also with odis online but nothing.
    Quote Originally Posted by Tunnel View Post
    I do not think you can solve faults like "Mechanical Failure" and "Signal Implausible" with ODIS either.
  8. Likes Zenerdiode, downtime, PetrolDave liked this post
    May 2017
    Uwe, you never know
  10. #8
    Mar 2018
    Italy
    Wednesday,04,September,2019,19:14:39:40494
    Mileage: 218250km-135614mi   Repair Order:
    VIN: WAUZZZ8K8DA234004   Mileage: 218250km-135614miles
    33-Flux Capacitor -- Status: Malfunction 0010
       Revision: 45H25---
       Coding: 000002
       Coding: 171544
       Coding: 342002E000
       Coding: 004577
       Coding: 000013
       Coding: 80CF07FF00
       Component: RCEPS         H41 0507
       VCID: 3424EB129FA541EF73-8060
                        Reset counter: 2
                        Mileage: 218250 km
                        Date: 2019.10.07
                        Time: 20:12:19
                        Write only channel
       Component: Display
    End----------(Elapsed Time: 01:13, VBatt start/end: 14.0V/14.0V)-----------
    only one dtc in power steering.
