Results 1 to 6 of 6
Thread: 2015 VW Golf 7 R - increase Idle speed by more than 50
    Oct 2018
    Romania
    Hello!
    I own a 2015 VW Golf 7R and after installing the engine and transmission mounts from a tuning company the car vibrates badly at idle in D.
    For this reason I would like to increase the idle RPM value from 700 RPMs to around 900 RPMs.
    I used the VCDS - Idle correction - adaptation parameter from the Engine, but it only allows me to increase it by 50 RPMs.
    Kindly ask you to please let me know how may I be able to increase it more?
    For example 150 RPMs added?
    Thank you!
    Engine Autoscan indicated below:
    Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb
    Part No SW: 5G0 906 259 F HW: 06K 907 425 B
    Component: 2.0l R4 TFSI H13 0002
    Revision: --H13---
    Coding: 092500122466050B3004
    ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
    ROD: EV_ECM20TFS0205G0906259F.rod
    VCID: 313C1C4961A1210F757-8064
    Readiness: 0010 0001
    Dec 2016
    DE
    I guess this can't be done using VCDS, but as the car is tuned, maybe the tuner is able to optimize the idle rpm.
    Normally they are able to do this task. Just ask them to fix your vibration problem.
  3. Likes PetrolDave, Uwe liked this post
    Oct 2018
    Romania
    Thank you! I just did this.
    But my appointment is a noticeable amount of time from today, and I would like to do it via VCDS if there is a way to increase it by more than 50 RPMs.
    Quote Originally Posted by 320i24vv View Post
    I doubt it. VCDS can only work within the limits allowed by the firmware in the ECU.
  6. Likes PetrolDave liked this post
    Oct 2018
    Romania
    Update: asked my tuner for help. Received an ECU software update that set the idle speed to 950 RPMs and allows me + / - 250 RPMs adjustment.
    Currently I run the idle engine speed in Drive at 1100 RPMs, identical to the idle engine speed from Sport mode, this way making sure that I have no vibrations in the car due to the upgraded engine and transmission mounts.
    I solved the issue. Thank you!
  8. Likes Uwe liked this post
  9. #6
    Jun 2019
    Can you tell me how you did that? I want to do the reverse. Change idle speed in Sport to the same as Drive.
