Results 1 to 4 of 4
Thread: EA189 Rollback
    Dec 2018
    Manchester UK
    EA189 Rollback
    Hi, I hope this is posted in the correct place.
    I am looking to get a rollback on my VW Caddy 1.6tdi dsg, but the tuner has had trouble locating the original files on the ECU or his database (wiped by VW no doubt).
    The ECU label is of no use either as it just shows the number 03L-907-425c, which is the hardware number according to the coding.
    Is there any way or place I can retrieve the original files?.
    Address 01: Engine Labels: 03L-906-023-CAY.clb
    Control Module Part Number: 03L 906 023 TK HW: 03L 907 425 C
    Component and/or Version: R4 1.6l TDI H43 9977
    Software Coding: 00254014032500080000
    Work Shop Code: WSC 35110 790 50316
    ASAM Dataset: EV_ECM16TDI02103L906023TK 003001 (VN35)
    ROD: EV_ECM16TDI02103L997557M.rod
    VCID: 025E838A748E7EF7DCD-8056
    Many thanks Steve
    Dec 2016
    DE
    It's in the current Volkswagen flash disc available to everyone, according to this: https://vag-flashinfo.de/index.php?p...06+023+TK+&as=
    The tuner should have no hazzle flashing back the ECU to stock firmware with this.
  3. Likes Dana liked this post
    Dec 2018
    Manchester UK
    Thanks for your reply
    The only files on this site for my software number are all files post Vag emissions fix. I am looking for files pre emissions fix i.e. earlier than revision 9976
    Dec 2016
    DE
    It should have had another software part number prior to the emissions update. Just check your old Auto-Scan logs. The TK in "03L 906 023 TK" came only after the update as far as I am informed.
