Results 1 to 10 of 20
Thread: 2009 VW Tiguan - No Start - Multiple Codes
    Jan 2017
    Question 2009 VW Tiguan - No Start - Multiple Codes
    Good evening.
    I got a call from my wife the other day stating that her car wouldn't start. I immediately got off work and went to see what the situation was. After attempting to start it, to no avail, we had it towed home.
    I ran the following scan on it and saw the dreaded P0016 code populate, so there it sat as I have had zero time to work on it.
    Tuesday,24,September,2019,19:13:56:06683
    VIN: WVGAV75N59W503659   License Plate:
    Mileage: 184910km-114897mi   Repair Order:
    Chassis Type: 5N (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 65 72
    VIN: WVGAV75N59W503659   Mileage: 184910km-114897miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 G    HW: 06J 906 026 AF
       Component: MED17.5 TFSI 2,0    8217
       Revision: AAH03---    Serial number: VWX7Z0H53NI11C
       Coding: 0423010A19070160
       Shop #: WSC 14112 002 1048576
       VCID: 2E06042ECC16E4C7685-807A
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 163
                        Mileage: 180947 km
                        Time: 23:26:27
                        RPM: 1020 /min
                        Load: 32.5 %
                        Temperature: 68.0C
                        Temperature: 39.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.462 V
                   P2015 - 000 - Implausible Signal - Intermittent
                        Fault Frequency: 162
                        Mileage: 181039 km
                        Time: 09:17:03
                        RPM: 2478 /min
                        Load: 43.1 %
                        Speed: 42.0 km/h
                        Temperature: 96.0C
                        Temperature: 25.0C
                        Voltage: 13.843 V
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
                   P0016 - 000 - Incorrect Correlation - Intermittent - MIL ON
                        Fault Status: 10100000
                        Fault Frequency: 52
                        Mileage: 184361 km
                        Time: 06:32:21
                        RPM: 1212 /min
                        Load: 28.6 %
                        Temperature: 73.0C
                        Temperature: 53.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.843 V
       Part No SW: 09G 927 750 KM    HW: 09G 927 750 KM
       Component: AQ 250 6F           1394
       Revision: 00H76000    Serial number:
       Coding: 0000840
       Shop #: WSC 00000 785 00200
       VCID: 06569C8E04268C87F05-8052
    Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
       Part No SW: 5N0 614 517 L    HW: 5N0 614 517 L
       Component: J104    C2 450 V2   0006
       Revision: --H11---    Serial number: 00000001228087
       Coding: 0002329
       VCID: 3728214A334C250F3B3-8062
       Part No SW: 1K0 820 047 HR    HW: 1K0 820 047 HR
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7BA0FD7A4FE4C16F9FB-802E
       Revision: 00H54000    Serial number: 00000008528988
       Coding: 108C0FA340041C0047190000140000000008F3475C400104390000000000
       Shop #: WSC 01287 785 00200
       VCID: 323E105ED82EC0270CD-8066
       Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 130608  012 0203
       Coding: 00038805
       Shop #: WSC 01287
    01516 - Terminal 30; Left
                        Fault Status: 00101011
                        Reset counter: 178
                        Mileage: 184912 km
                        Voltage: 12.20 V
       Part No SW: 5N0 959 655 B    HW: 5N0 959 655 B
       Component: J234__200 VW10 HI   1815
       Revision: 19013000    Serial number: 0039EPAJ7Y6+
       Coding: 0012336
       VCID: 3C223E660A6A0657D61-8068
       Subsystem 1 - Part No: 5N0 959 339 A
       Component: BF-Gewichtsens. 001 0004
       Subsystem 2 - Serial number: 00000000000S45
       Subsystem 3 - Serial number: 0008.03.08000010000064003963
       Subsystem 4 - Serial number: 6400396333FTS647731458 63
       Subsystem 5 - Serial number: 31458 6343FTS642541468 63
       Subsystem 6 - Serial number: 41468 6353ETS67KTLTVNP 63
       Subsystem 7 - Serial number: LTVNP 6363ETS64DFLTVNH 63
       Subsystem 8 - Serial number: LTVNH 6373JTS6GVPCTVNH 63
       Subsystem 9 - Serial number: CTVNH 6383JTS6MBMCTVNH
       Subsystem 10 - Serial number: CTVNH
       Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
       Coding: 0010022
       VCID: 77A8E14A73CCE50FFB3-8022
       Part No SW: 5N0 920 950 D    HW: 5N0 920 950 D
       Component: KOMBIINSTRUMENT VDD 1224
       Revision: V0003000    Serial number: VWX7Z0H53NI11C
       Coding: 0007204
       VCID: 303A1A56D622F2377A9-8064
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K0850506B4
       Coding: FD807F070002026002
       VCID: 35342B422940D71F29F-8060
       Component: IMMO            VDD 1224
       Part No SW: 5N0 959 701     HW: 5N0 959 701
       Component: Tuer-SG         006 1205
       Coding: 0001205
       VCID: 72BED05E18AE8027CCD-8026
       Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
       Component: J500__APA-BS KL.285 1501
       Revision: 1BH04843    Serial number: 00171300055601
       Coding: 0000258
       Shop #: WSC 46536 002 1048576
       VCID: 42DE409E688E70A79CD-8016
       Component:    KSG PQ35 RDK 052 0222
       Coding: 9380078852832C1B1B04058FB0880F0C88DCA0
       VCID: 04528686321ABE97EE1-8050
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 97
                        Mileage: 180947 km
                        Time: 22:57:31
       Part No SW: 5N0 959 702     HW: 5N0 959 702
       Coding: 0001204
       VCID: 73B0D55A67B4892FC7B-8026
       Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
       Component: J540 EPB3  VW-09384 0005
       Revision:   H08       Serial number: 00000000073967
       Coding: 0000057
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       017 0021
       Revision: 00017000    Serial number: VWZ4Z7H6345021
       Coding: 0040401
       VCID: 201AEA1686C242B7EA9-8074
       Part No SW: 5N0 959 703 A    HW: 5N0 959 703 A
       Component: Tuer-SG         006 1301
       Coding: 0001168
       Shop #: WSC 01287 785 1012552
       Coding: 0100101
       Shop #: WSC 01234 785 00200
       Part No SW: 5N0 959 704 A    HW: 5N0 959 704 A
       Coding: 0001168
       VCID: 36362C4E3446DC07205-8062
    End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    I'm not super concerned about the intake flap position sensor, as I've changed that intake 3 times so far and after about a year or so it fails. I tend to believe that's not the problem.
    What worries me is the following:
    I know this engine has a tendency to throw the timing chain, but would that cause a no-start so abruptly. She claims the car was running fine before that and wasn't exhibiting any issues. The only idiot light that came on was the check engine, but that has been on for a while according to her, however, she didn't tell me because "she thought it was ok and just needed an oil change". Yeah ok, thanks, woman.
    Anyway, wondering if any of you suspect anything else from this scan, aside from the infamous chain tensioner issues. If that is the problem, we will likely be getting rid of the car and moving on, as I don't have the capacity to fix it right now.
    Have you checked for useful life warranty, reimbursement for your aforementioned issues you stated and the JPPSG yet?
  3. Likes dannation liked this post
    Compression check?
    Sump conditions?
    Fuel injectors?
    Barbara Streisand?
  5. Likes dannation liked this post
  6. #4
    Jan 2017
    I'm not sure what the useful life warranty is, but I did check with VWGOA for any recalls and extended warranties I may be missing. I spoke to a representative via chat who confirmed that the vehicle is out of warranty due to being at 114k miles and being just over 10 years old. With that said, we will likely not receive any reimbursement through VW.
    Thank you for the helpful link to your guide. I will go through what's been done and provide a little background, using your guide as a reference.
    Info from your guide including my answers. Apologies if this isn't what you are looking for.
    \\\\\\\\\\\\\\\\\\\\ JPPSG GUIDE AND ANSWERS \\\\\\\\\\\\\\\\\\\\\\\\\\\
    VW / Tiguan / 2009 / S.
    Step 1 Tag of PR-Build data picture posted
    WVGAV75N59W503659
    Step 2 Status of car stock or modified in any way? If so list!
    Car is stock
    Step 3 "VCDS" COMPLETE Auto-Scan in code tags!
                        Mileage: 180947 km
                        Time: 23:26:27
                        RPM: 1020 /min
                        Load: 32.5 %
                        Temperature: 68.0°C
                        Temperature: 39.0°C
                        Voltage: 13.462 V
                        Mileage: 181039 km
                        Time: 09:17:03
                        RPM: 2478 /min
                        Load: 43.1 %
                        Speed: 42.0 km/h
                        Temperature: 96.0°C
                        Temperature: 25.0°C
                        Voltage: 13.843 V
                        Fault Frequency: 52
                        Mileage: 184361 km
                        Time: 06:32:21
                        RPM: 1212 /min
                        Load: 28.6 %
                        Temperature: 73.0°C
                        Temperature: 53.0°C
                        Voltage: 13.843 V
       Coding: 0000840
       Coding: 0002329
       Coding: 00038805
       Shop #: WSC 01287
                        Reset counter: 178
                        Mileage: 184912 km
                        Voltage: 12.20 V
       Coding: 0012336
       Subsystem 3 - Serial number: 0008.03.080000100000640039ÿ†63
       Subsystem 4 - Serial number: 640039ÿ†6333FTS647731458 ÿ†63
       Subsystem 5 - Serial number: 31458 ÿ†6343FTS642541468 ÿ†63
       Subsystem 6 - Serial number: 41468 ÿ†6353ETS67KTLTVNP ÿ†63
       Subsystem 7 - Serial number: LTVNP ÿ†6363ETS64DFLTVNH ÿ†63
       Subsystem 8 - Serial number: LTVNH ÿ†6373JTS6GVPCTVNH ÿ†63
       Subsystem 9 - Serial number: CTVNH ÿ†6383JTS6MBMCTVNH ÿ
       Subsystem 10 - Serial number: CTVNH ÿ
       Coding: 0010022
       Coding: 0007204
       Coding: 0001205
       Coding: 0000258
                        Reset counter: 97
                        Mileage: 180947 km
                        Time: 22:57:31
       Coding: 0001204
       Coding: 0000057
       Coding: 0040401
       Coding: 0001168
       Coding: 0100101
       Coding: 0001168
    Step 4 Describe recent repairs or services, problem at hand, & attempts at repair.
    Recent repairs include water pump repair replacement on 4/2019, intake manifold replacement 12/2018
    Step 5 Are parts OEM or AFT? If so, "what", and what origin?
    All parts are OEM
    Step 6 Identify specific issues to be addressed/concerned about, or say ALL.
    The specific and immediate issue is the no-start and the following code found in the scan:
    000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28) P0016 - 000 - Incorrect Correlation - Intermittent - MIL ON
    Step 7 Now that you jumped through the first few hoops of fire, did you check the FUSES/Battery connections?
    The battery connection is good. The fuses and relays have not been checked yet.
    I have a solid understanding of mechanics, as I was an aircraft mechanic and work on the majority of my vehicles. With that said, I am by no means a VW tech and the system is fairly new to me.
    Current symptoms are no start. I haven't been able to perform a compression test. I pulled the coils and there is no oil on them. I checked to make sure the camshaft position sensor was plugged in and the wires were not damaged, but I haven't checked for any of the electrical systems as of yet. I have not been into the engine as of yet to know if there is FOD, and I didn't see anything in the oil that looks troubling
    I am assuming my first step will be to check electrical systems, and then move to fuel. Would the be accurate?
    Depending on the complexity of the work and cost of parts I will either be doing the work myself or selling the vehicle as parts.
    I have downloaded all PDF's from VW relating to the Tiguan and have them at my disposal.
    I do know how to read schematics
    The VCDS firmware was having issues updating upon initially plugging the dongle into the vehicle, but they seemed to resolve themselves after several restarts.
    Jan 2017
    Low and behold, it was Barbra Streisand!
    Just kidding.
    I haven't performed a compression check yet and there doesn't appear to be any metallic particles in the oil. I haven't checked the injectors either, as I haven't pulled the intake.
    Jul 2016
    Australia
    I would not bother to check electrical yet... Do mechanical tests.. Compression and / or timing check. With this engine and known chain issues you're most likely looking @ tensioner failure.
    Have you had the upgraded chain tensioner put in? Not that it really matters TBH. Intake manifold is not your starting issue.
    My money is on tensioner failed, timing out and contact has been made with pistons. Not uncommon for them to be perfectly OK and then next minute no compression, no start. Worst one I've had was 75,000KM MK6 GTI stopped on highway no warnings... All valves hit so hard they bent into cylinder head......
    Compression check and/or timing check will confirm. Goodluck.
  9. Likes dannation, Dana, Uwe liked this post
  10. #7
    Did you know that every once and a while we see a plugged CAT & can cause the car to not run and have the correlation DTC's too?
    Are not firmware updates required for this car that imply a defect resulting in a worthy NHTSA inquiry for safety under the Fast Act or even EPA for failing to comport with CAA as an ADR?
    Did you know that it looks like someone negated their Responsibility's on the OEM and did you know that load requests matter with firmware updates for aforementioned torque requests; that are also MIL related when said updates are not done to compliment the transmission & that a TCU can set or be vicariously responsible for such conditions or setting the MIL inducing mechanical defect in engine or power train?
    Splendid isn't it?
    Pardon me but have you been here?
    https://literature.vw.com/calibration_lookup.asp
    Calibration Data Lookup
    Test Group:
    Module CAL ID CVN Engine Code Test Group
    TCM 09G 927 750 GG 1702 01C6965F 9ADXV02.03UA
    TCM 09G 927 750 KM 1703 7289DEDD 9ADXV02.03UA
    TCM 09G 927 750 KN 1704 2C640E62 9ADXV02.03UA
    TCM 09G 927 750 KM 2191 E5846266 9VWXJ02.0UA
    Or here?
    https://vag-flashinfo.de/index.php?p...927+750+KM&as=
    Are you sure you don't want to demand your MTV or free repair and point out this lack of attention of the OEM's own work steps for a free engine?
    Did you read the entire JPPSG thread?
    Don't you make me get a unilateral conformity application.
    Doesn't this sound like a negated recall or campaign now and safety recalls are 15/150k so don't you have a valid argument to litigate, someone to 187?
    "one-eighty-seven"
    Don't you have a job to do?
  11. Likes dannation liked this post
  12. #8
    Thanks for the suggestion. I don't currently have a compression gauge, but will be getting one at the store this weekend to see if there are any compression issues and will update the thread after that. I guess the path I was taking was, test things that don't require money first, since we are on a single income right now. Trying to budget this as appropriate and take the path of least resistance first. My methodology is likely flawed, however
    Wouldn't a free repair or possible reimbursement with consistent valid documentation compiled, be the right action along with what you aforementioned?
    Did you know campaigns and recalls or useful life expectations are reimbursable, along with the cost of diagnosis?
  13. #9
    Jan 2017
    Quote Originally Posted by The One View Post
    Thanks for the suggestion. I don't currently have a compression gauge, but will be getting one at the store this weekend to see if there are any compression issues and will update the thread after that. I guess the path I was taking was, test things that don't require money first, since we are on a single income right now. Trying to budget this as appropriate and take the path of least resistance first. My methodology is likely flawed, however.
  14. #10
    Jan 2017
    Thank you for the suggestion Jack. I wasn't aware that safety recalls and litigation were valid for vehicles with 15y / 150k. I will definitely do some research on that and see how it goes. To have this fixed on VW's dime would be ideal, as in my eyes its gross negligence with the engineering of the 2.0 tsi. Every class action I have read seems to point to a 10 year 100k limitation, which in today's age seems quite low for such an ever present problem in this engine.
    I truly appreciate the assistance thus far, and all the excellent resources you have been providing, even if I only comprehend 1/2 of the acronyms.
    As for the JPPSG thread, I only read the first page as I was trying to post the reply. I will scour it deeper to see what kind of information I can acquire.
  15. Likes Uwe, Dana liked this post
