Results 1 to 10 of 13
Thread: Requesting for coding help - Xenon AFS Headlight retrofit
    Verified VCDS-User
    Oct 2019
    India
    I've just submitted the registration info for my HEX + CAN VCDS interface. Hope that comes through soon.
    My car is a used Skoda Octavia MK2 FL, 2010 , Elegance variant, which I picked up recently, which comes with Halogen projectors.
    I've picked up Xenon AFS headlights from the L&K variant of the same car (used the VIN of my friend's L&K to decode the headlight part numbers), and right now, I'm stuck as the headlight module doesn't seem to accept coding.
    The headlights are coming on though, but AFS is disabled.
    I've tried the same coding from the L&K variant, which isn't accepted at all unfortunately. I also found coding from other similar cars on the web, which I tried, and the module does accept some codes, but always continues to register fault codes that the module isn't coded.
    I'm pasting the autoscan from my Elegance variant with the Xenon AFS headlights retrofitted, and also the autoscan from the L&K variant that came with the same exact Xenon AFS lights from factory.
    Note: I did retrofit the levelling sensor as well.
    Requesting your help to arrive at the right coding for the car.
    Thank you so much for all the great work you guys do here, I appreciate all the knowledge being shared!
    Autoscan from my car
    Autoscan from the L&K
    Wednesday,17,December,2014,19:44:38:38258
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: xxxxxxxxxxxxxxxxx   License Plate:
    Mileage: 52740km-32771mi   Repair Order:
    Chassis Type: 1Z (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 47 52 55 56 62
              72
    VIN: xxxxxxxxxxxxxxxxx   Mileage: 52740km-32771miles
    Address 01: Engine (J623-CLCB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 EH    HW: 03L 906 018 BR
       Component: R4 2,0L EDC   H23 7021
       Revision: 42H23---    Serial number:
       Coding: 001D0012042500080000
       Shop #: WSC 33361 790 00999
       ASAM Dataset: EV_ECM20TDI01103L906018EH 003003
       ROD: EV_ECM20TDI01103L906018EH.rod
       VCID: 74E7620BDF2E5D817B3-8021
    4629 - ECM Power Relay Load Circuit
              P068A 00 [032] - Opens Too Early
                        Time: 00:00:00
       Part No SW: 02E 300 054 J    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2602
       Revision: 05351112    Serial number: 00001102091071
       Shop #: WSC 73430 790 00999
       VCID: 1D3167AFC424BCC964D-8048
       Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 133B401C0A2700FCC80C02EA50190082340000
       VCID: 75E15F0FDC5444894CD-8020
       Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
       Component: Climatronic   H16 0402
       Revision: 00006001
       Coding: 0000001002
       ROD: EV_ClimaAutoBasis_SK12.rod
       VCID: 76E35803C9524F91457-8023
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 48000AB8E80508C04008008011001124417000AE722085605C8440000040
       Shop #: WSC 73430 790 00075
       VCID: 387F963B8BC6F9E197B-806D
       Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
       Component: Wischer 20021  26  0601
       Coding: 00D7B7
       Component: RLS 180111 05  54  0403
       Coding: 0730ED
    Address 10: Park/Steer Assist (J446)       Labels: 1Z0-919-475-V2.clb
       Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0005
       Revision: --H06---    Serial number: 28291103917865
       Coding: 108101
       ASAM Dataset: EV_EPHVA18SKxxx0000 001001
       ROD: EV_EPHVA18SKxxx0000_SK35.rod
       VCID: 4385F1D7CA00AA39329-8016
       Component: Q7 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC242R85
       Coding: 0020791
       VCID: 3D71872F64E4DCC944D-8068
       Subsystem 1 - Serial number: 6332MSME5C032D47H
       Subsystem 2 - Serial number: 6342MSME5C125A63G
       Subsystem 3 - Serial number: 6351HSME24390140X
       Subsystem 4 - Serial number: 6361HSME243B75123
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010040    Serial number: 20110225101381
       Coding: 0882140000
       ROD: EV_SMLSNGVOLWS.rod
       Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
       Component: E221__MFL-URO  H07 0012
       Coding: 800000
       Part No SW: 1Z0 920 843 M    HW: 1Z0 920 843 M
       Component: KOMBI         H20 0420
       Coding: 110E01
       Shop #: WSC 73430 031 00999
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 428BF4D3D51AA33139F-8017
    9453074 - Fuel Level Sensor 1
              B103E 1B [008] - Resistance Too High
                        Reset counter: 152
                        Mileage: 52315 km
                        Date: 2014.12.12
                        Time: 18:22:19
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 080311F2000032
       Coding: 351303
       VCID: 306FAE1B63B621A1DFB-8065
       Component: IMMO          H20 0420
       VCID: 6ADB7C738DEA9B71D1F-803F
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1102
       Revision: 00005000    Serial number: 00000000000000
       VCID: 2F6DAD67BE883E59C61-807A
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
       Component: Tuer-SG         009 2120
       Coding: 0005110
       VCID: 76E3580301524F91457-8023
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 69     3201
       Revision: 00H20000
       VCID: 3467A20B57AE1D81BB3-8061
       Part No SW: 3T0 035 456     HW: 3T0 035 456
       Component: KonzernAmp10K H06 0342
       Revision: --------    Serial number: BP218209158540
       ASAM Dataset: EV_AudioVerst10KanalBNO2 A01003
       ROD: EV_AudioVerst10KanalBNO2.rod
       VCID: 6ED37063B10277518D7-803B
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Component: Tuer-SG         009 2114
       Coding: 0005110
       VCID: 489FE6FB3B268961E7B-801D
       Coding: 1507610
       Subsystem 1 - Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000023
       Subsystem 2 - Part No: 7L6 941 329 B
       Coding: 00000023
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
       Component: BOLERO        010 0054
       Revision: 0A001001    Serial number: SKZ1Z3K8463819
       Coding: 0D0200000000
       VCID: 35619F0F9CD404898CD-8060
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012551
       VCID: 326BA413ADBA13B1A9F-8067
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 3365A11752A01AB9A29-8066
    End-------------------------(Elapsed Time: 03:06)--------------------------
    Nov 2015
    You should update VCDS to the latest version...
    May 2017
    And you probably have wrong headlight module. If I'm not mistaken you should have 357 C and not D what you have.
    Quote Originally Posted by kryptonite View Post
    The system you registered today is not the system you used to scan your car.
    I have very little tolerance for people who play games with pirated systems.
    Post a scan from the system you registered today, or you'll be standing in the Hall of Shame shortly.
  5. Likes downtime liked this post
    Verified VCDS-User
    Oct 2019
    India
    Yikes! Please accept my apologies. The workshop owner and I took multiple scans yesterday in the process of trying to code, and I have uploaded one of the scans he took by mistake. Never realized he wasn't using an original cable either, I will be sure to let him know as well.
    Here's a fresh autoscan from my cable
    Wednesday,02,October,2019,11:48:39:54138
    VCDS Version: 19.6.0.4 (x64)
    Mileage: 67200km-41756mi   Repair Order:
    Chassis Type: 1Z-SK35 (7N0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 42 44 46 52 55 56 62
              72
    VIN: xxxxxxxxxxxxxxxxx   Mileage: 67200km-41756miles
    Address 01: Engine (J623-CLCB)       Labels:. 03L-906-018-CFF.clb
       Component: R4 2,0L EDC   H24 9480
       Revision: 42H24---    Serial number: 00000000000000
       Shop #: WSC 40627 002 104856
       ASAM Dataset: EV_ECM20TDI01103L906018EH 003005
       VCID: 74E7E707DF6855EF83-8020
       Part No SW: 02E 300 052 T    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2115
       Revision:    51112    Serial number: 00001006070752
       VCID: 2541CA43EC327C67C4-8070
       Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
       Revision: 00H46001
       Coding: 133B201C092700FEC81204EC90190081A1095070
       Shop #: WSC 78387 152 45229
       VCID: 0407B7C787C8656FB3-8050
       Component: VWKESSYPQ35GP 092 0902
       Revision: 00092000    Serial number: 0344548020
       Coding: 030C0C
       Shop #: WSC 52104 002 104857
       ASAM Dataset: EV_KESSYPQ35G A02014
       VCID: 346727079FE815EF43-8060
       Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
       Component: Climatronic   H15 0401
       Revision: 00005001
       Coding: 0000001002
       VCID: 0305B4DB8AC662578A-8056
       Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
       Component: BCM PQ35 B    021 0064
       Revision: BA021001
       Coding: 06000A38982D00C040680080040008E803F1000050A081B6E4800004A040
       Shop #: WSC 00046 123 12345
       VCID: 377D100B869EFEF766-8062
       Component: RLS 150610 05  54  0403
       Coding: 0730ED
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 P    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0038
       Revision: --------    Serial number: 56231234803877
       Coding: 349101
       ASAM Dataset: EV_EPHVA2C000000000 002013
       ROD: EV_EPHVA2C000000000.rod
       VCID: 489F63F7F360810F1F-801C
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 07 AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037TR07YKTR
       Coding: 0012343
       VCID: 7DF1C223242214A7FC-8028
       Part No SW: 5K0 953 521 DT    HW: 5K0 953 569 AH
       Revision: FF010041    Serial number: 20161102000180
       Coding: 001A140000
       Shop #: WSC 00078 790 00053
       VCID: 0109BED390DA704798-8054
       Subsystem 1 - Part No SW: 5E0 919 719 G    HW: 5E0 919 719 G
       Component: E221__MFL-PR6  H05 0130
       Coding: 830000
       Part No SW: 1Z0 920 843 S    HW: 1Z0 920 843 S
       Component: KOMBI         H06 0608
       Coding: 110A01
       Shop #: WSC 73430 031 00096
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       Part No SW: 7N0 907 530 AJ    HW: 7N0 907 530 AJ
       Component: J533  Gateway H51 1634
       Revision:   H51       Serial number: 09121300F10684
       Coding: 351303
       VCID: 78FFD337CB00318FAF-802C
       Component: IMMO          H06 0608
       Coding: 000007
       VCID: 6ADBF97F8DAC931F29-803E
       Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
       Component: ELV-PQ35      H22 0240
       Revision: 00000000    Serial number: 18000239041005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 31692E1360FA20C728-8064
       Coding: 0004854
       Shop #: WSC 00046 000 00000
       VCID: 76E3DD0F011447FFBD-8022
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 31692E13A8FA20C728-8064
       Coding: 0004854
       Shop #: WSC 23039 663 88869
       VCID: 489F63F73B60810F1F-801C
       Part No SW: 5M0 907 357 D    HW: 5M0 907 357 D
       Component: AFS-Steuergeraet    0149
       Coding: 7472341
       Shop #: WSC 00078 790 00185
       VCID: 35611A035C920CE774-8060
       Coding: 00000023
       Coding: 00000023
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 64
                            Invalid
                            Invalid
                            Invalid
    02656 - Power Output Stage for Left Headlight (J667); Not Coded
                000 - - - MIL ON
                        Reset counter: 64
                            Invalid
                            Invalid
                            Invalid
    02657 - Power Output Stage for Right Headlight (J668); Not Coded
                000 - - - MIL ON
                        Reset counter: 64
                            Invalid
                            Invalid
                            Invalid
                        Fault Status: 11100101
                        Reset counter: 64
                            Invalid
                            Invalid
                            Invalid
    Address 56: Radio
       Coding: 0000144
       VCID: 326B211FADFC1BDF51-8066
       Coding: 0000144
       Shop #: WSC 33361 790 1012551
       VCID: 3365241B52E612D75A-8066
    End-------------------------(Elapsed Time: 02:44)--------------------------
    Oct 2014
    I'd agree with the above, pretty sure the Octavia only ever got 5M0 907 357 C modules rather than 5M0 907 357 D.
    If you do replace it, try and get one with SW:0148 rather than SW:0142
  8. Likes kryptonite liked this post
    Verified VCDS-User
    Oct 2019
    India
    Hey langers2k, good to see on this forum mate!
    Thanks for the info, but unfortunately, the headlamps were bought from the Skoda dealership directly, part numbers 1z2 941 017s, 1z2 941 018s, and neither will they take it back, nor will they help me code online.
    One thing to note is that only the front leveling sensor is retrofitted on the car, not the rear. I read that this should be enough to get it working. Please correct me if I was wrong.
    Unfortunately though, I'm stuck with the headlights, and would appreciate some guidance to get this working.
    Also by 5M0907357C, I presume you're referring to the control unit for cornering light, right? I seem to have the version D.
    Do you think I can swap this out to version C and retain the headlamps, and will be able to get it to work?
    And from all of the different headlight codings that I tried, the only ones that are accepted are
    1770963
    7472341
    -but the errors come back almost immediately
  10. #8
    Oct 2014
    Your AFS slaves which are connected to the headlights are correct (7L6 941 329 B) so the dealer has sold the correct parts.
    5M0907357C would be the AFS master so isn't attached to the headlights. The standard location would be behind the climate panel/under the headunit but I'm not sure where you've fitted it. Should be super easy to replace it with the correct version
    Plenty on eBay but I'd suggest you grab one running SW:0148. It's the numbers (H04, S0148) on the top right of the sticker for example this one: https://www.ebay.co.uk/itm/123899800508
    The Octavia should require two level sensors. If you only fit one, you'll need a different coding and it should be fitted at the rear not the front...
  11. Likes downtime, kryptonite liked this post
  12. #9
    May 2017
    ^ Exactly as langers2k wrote.
    Your headlamps and AFS slave modules are correct but the master module 55 is not correct for Octavia.
    That is the reason you get the errors with 17xxxx codin. These slaves are not intended for the D module and it fails to code them.
    Swap to C module what langers linked and you should be good to go.
  13. Likes kryptonite liked this post
  14. #10
    OK, I've upgraded your user status here and moved this to Retrofits.
    Please ensure that you don't post data from clone/pirate systems here in the future.
  15. Likes kryptonite liked this post
