Results 1 to 5 of 5
Thread: Golf MK7 Halogen to FULL LED
    Sketchy
    Mar 2015
    Poland
    Hi friends
    I have golf 2016 with halogen and make retrofit full led, I have some errors in scan, becouse golf have little crash. Have you tutorial ?
    I install module 4B, and connect lamp to this module, have communication with led module and what next ?
    I need change BCM ? or maybe change coding in BCM ?
    Thanks for help
    Tuesday,01,October,2019,17:46:04:16059
    Dealer/Shop Name: ECUDoctor
    VIN: 3VW4T7AUXHM013105   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 29 39 42 44 4B 52 5F 75 A9 D6
              D7
    VIN: 3VW4T7AUXHM013105   Mileage: 14228km-8840miles
    29-Left Light -- Status: Not registered 0011
    39-Right Light -- Status: Not registered 0011
    4B-Multifunc. Module -- Status: Malfunction 0010
    D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
    D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00324424002F0000
       Shop #: WSC 00066 790 00064
       ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
       ROD: EV_ECM20TFS0205G0906259L.rod
       VCID: 372B2B965FCE6F0F3B3-8062
    17178 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:53:05
                        Coolant temperature: 16 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 11.933 V
                        Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                        Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                        Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                        Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                        Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                        Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                        Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                        Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                        Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
    Readiness: 1110 1101
       Part No SW: 0D9 300 042 H    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H54 4902
       Revision: 06354004    Serial number: TFK01607161888
       ROD: EV_TCMDQ250021.rod
       VCID: 1E65DE32D0343E47D85-804A
              P1734 00 [002] - -
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 52046000001597
       Coding: 01FA6BA13421096F8078020081C82980D62C90014081943400430050C00903
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
       VCID: 75B7E19E0542DD1FE9F-8020
    0297 - Steering Angle Sensor
              B1168 F2 [137] - Not Initialized
                        Reset counter: 200
                        Date: 2018.09.25
                        Time: 00:23:05
    16412 - Display for Tire Pressure Monitoring
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:16
    16413 - Display for Tire Pressure Monitoring
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:16
       Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
       Component: AC Manuell    H03 1601
       Revision: 00001K03
       Coding: 00020004200100000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004132
       ROD: EV_ACManueBHBVW37X_004.rod
       VCID: 48C9586A223010F7429-801C
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
                        Outside air temperature: 18.5 °C
                        Engine speed: 0 /min
                        Compressor current: actual value: 0.005 A
                        Temperature after evaporator: 17.3 °C
                        System run time-Terminal 15 on: 255 s
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 865829061602FE
       Coding: 000018464041B04969E44000001407201000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AADF2A22C5CB26784D-802E
       Component: WWS    160819  043 0581
       Serial number:         160827113218
    14 Faults Found:
    568836 - Databus
              [LWR AFS - Kein Signal/Kommunikation]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
    568086 - Databus
              [LCM links - Blinker defekt]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:19
    568342 - Databus
              [LCM rechts - Blinker defekt]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:19
    6666 - Bulb for Low Beam Headlamp Left
              B1217 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:55:27
    7178 - Bulb for High Beam Headlamp Left
              B1219 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:55:23
    5130 - Bulb for Front Left Turn Signal
              B11E8 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:19
    10506 - Bulb for Left Tail Light
              B12BE 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:55:24
    6922 - Bulb for Low Beam Headlamp Right
              B1218 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:20:13
    7434 - Bulb for High Beam Headlamp Right
              B121A 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:55:23
    5386 - Bulb for Front Right Turn Signal
              B11EA 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:19
    17162 - Bulb for Left DRL and Parking Lamp
              B12EA 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:06
    17418 - Bulb for Right DRL and Parking Lamp
              B12EB 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:06
    17674 - Bulb for Front Left Side Marker Lamp
              B12BA 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:55:22
    17930 - Bulb for Front Right Side Marker Lamp
              B12BB 15 [009] - Open or Short to Plus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:55:22
       Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0056
       Revision: --------    Serial number: 39391604900115
       Coding: 0021150011
       VCID: 44D14C5A1E183497AE1-8010
    12658704 - Databus
              [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
    13637426 - Databus
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
       Serial number: 003GCR05BZ4R
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB5B562F2E1F8F4B3-8012
       Occupant Detection:
       Serial number: IBH000000000005N9F8K
       Coding: 30305A
       Subsystem 2 - Part No SW: -----------    HW: 480 000 907 16
       Serial number: 357000000005EC8CDC16
       Subsystem 3 - Part No SW: -----------    HW: 480 000 907 16
       Serial number: 35800000000AF761DC1
       Subsystem 4 - Part No SW: -----------    HW: 480 402 806 16
       Serial number: 3510002AF20FC742115%
       Subsystem 5 - Part No SW: -----------    HW: 480 402 806 16
       Serial number: 3520002B920FC4C4A1AG
       Subsystem 6 - Part No SW: -----------    HW: 480 401 207 16
       Serial number: 3550002C521160D1423M
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 207 16
       Serial number: 3560002C321160D4738X
    9440539 - Driver's Safety Belt Tensioner Igniter 2
              B100D 1B [137] - Resistance Too High
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:07
    9441051 - Front passenger's safety belt tensioner igniter 2
              B100F 1B [137] - Resistance Too High
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:07
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160706400960
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FDB43B677FE574FF33-806A
       Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
       Component: KOMBI         344 8311
       Coding: 0BBD090AA190CF0502086A001000000000000000
       VCID: 2D0709FEAD92D5DF51F-8078
    16776980 - Databus
              [PLA_Status_01 keine Kommunikation]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
    9456433 - Key
              B104B 31 [009] - No Signal
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:56:48
       Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2265
       Revision: --------    Serial number: 24061610801720
       Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 00074
       ROD: EV_GatewConti_013.rod
       VCID: 7BA3F7A623668B6F9FB-802E
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001051270046225
       Coding: 31FFFF
    131734 - No Communications with Undefined Control Module
              U1126 00 [009] - -
              [Timeout Knoten 0x96]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:56:37
                        Terminal 15: On
    131735 - No Communications with Undefined Control Module
              U1126 00 [009] - -
              [Timeout Knoten 0x97]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:56:37
                        Terminal 15: On
    131753 - Multifunction Module
              U1326 00 [008] - No Communication
              [Time_out_node_0xA9_multifunction_module_on_second_bus]
                        Reset counter: 240
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:57:12
                        Terminal 15: OFF
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
    0018 - Data Set Implausible
              B2012 00 [009] - -
              [Implausible dataset]
    0033 - Supply voltage
              U1011 00 [009] - Voltage too Low
              [Supply voltage - lower limit exceeded]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:20:40
    0036 - Terminal 15
              U1405 00 [009] - Implausible signal
              [Clamp 15 implausible signal]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:19:28
       Component: LCM_MLBevoH05 0011
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:54:12
    0608 - LED Turn Signal Lights
              C11BF F0 [009] - Current Coding Electrical Malfunction
                        Reset counter: 102
    0036 - Terminal 15
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:53:05
    0356 - Temperature sensor
              C11C1 01 [009] - Electrical Failure
                        Reset counter: 102
                        Mileage: 10851 km
       Serial number: 170816060501RI
       Coding: 003E03200000020000000000
       VCID: 43D34F461B1633AF97B-8016
       Serial number: 00000000000004027979
       Coding: 011000
       Coding: 8302
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 3A2D32A26CDC7267C4D-806E
    16275 - Steering Angle Sensor
              B1168 F2 [009] - Not Initialized
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
                        Motor status: 00
                        Supply voltage: 12.00 V
                        Temperature: 28.0 °C
                        KFC: 3F
                        KFA: 00 93
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 11.91 V
                        uAdSensI_SwitchedKl30_xdu16: 11.91 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 01 C0
                        RP_VALCNTSAV: activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: activated
                        RP_CNTERR: activated
    23552 - Databus
              [PLA_01 Botschaft - CAN-Timeout]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:05
                        Motor status: 00
                        KFC: 5C
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 12.11 V
                        uAdSensI_SwitchedKl30_xdu16: 12.11 V
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0342
       Serial number: 04101710800808
       Coding: 000000040900196C02202B07020000000000000000000000000000000000
       Shop #: WSC 06745 128 28888
       ASAM Dataset: EV_MultiModulContiVW48X 002004
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 3537219E45C29D1F29F-8060
    7 Faults Found:
    0016 - Databus
              U1121 00 [137] - Missing Message
              [BCM_05 data bus missing message]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:19:28
    12601088 - Extended CAN Bus (SAE Bus C)
              U0047 00 [137] - Performance
              [Databus extended no communication]
                        Reset counter: 149
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:19:27
    0035 - Databus for Front Lighting
              U12EB 00 [009] - Additional Installations Detected
              [CAN_AFS_multiple_plug_LCM_identified]
                        Reset counter: 149
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:19:27
    13706046 - Databus
              U1123 00 [137] - Received Error Message
              [LV_Abblendlicht_li_def received error value]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:20:14
    13706047 - Databus
              [LV_Abblendlicht_re_def received error value]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 01:20:14
    66881 - Databus
              [LED_L_falsch_codiert received error value]
                        Reset counter: 200
    66882 - Databus
              [LED_R_falsch_codiert received error value]
                        Reset counter: 200
       Serial number: 21041606050184
       VCID: 42DD4A42040C3AA79CD-8016
       Serial number: 00000000000004022415
       Coding: 091000
       Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
       Component: MU-S-S-US     710 0751
       Coding: 02730000FF00000051220001001808009F0203D40120010002
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW00YLS
              B1061 13 [009] - Open Circuit
              [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
                        Voltage terminal 30: 11.9 V
    0005 - Antenna Amplifier 1 for Radio
              B126D 13 [009] - Open Circuit
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 1 for radio-Reception level antenna 1: 51 dBµV
    0006 - Antenna Amplifier 2 for Radio
              B126E 13 [009] - Open Circuit
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 51 dBµV
       Component: OCULowMQBUS   007 0568
       ROD: EV_OCULowMQB.rod
    13639680 - Mobile Data Services
              B149A 00 [009] - -
                        Reset counter: 200
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:23:04
       Serial number: 160604200234
       VCID: 6B83C7E653061BEF0FB-803E
       Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
       Component: LED1L         H07 0008
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 0059804A4A80E8B7CA9-8054
    0017 - invalid data record
              B2005 00 [175] - -
              [Invalid Dataset]
                        Reset counter: 0
                        Time: 00:00:00
    0257 - Databus
              U1201 00 [040] - No Communications
              [can data bus - no communication]
                        Reset counter: 0
                        Time: 00:00:00
    0338 - ROD - Unknown Error Code
              - 00 [237]
                        Reset counter: 0
                        Mileage: 14228 km
                        Date: 2018.09.25
                        Time: 00:53:05
    Address D7: Light Ctrl Right 2
    End----(Elapsed Time: 01:25, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    May 2017
              B2005 00 [175] - -
              [Invalid Dataset]
                        Reset counter: 0
                        Time: 00:00:0
    For this you need something else than VCDS unfortunately.
    Also can you please run clear all DTCs and the take a new autoscan so we'll see what errors are valid and whatnot.
    Oct 2017
    Northwest UK
    You need to change the BCM definitely and the Gateway. Have you fitted a level sensor too?
  4. Likes downtime, DV52 liked this post
    ^^^ ...............and if I may add to myounus's advice - you will also need to deal with Component Protection error messages from a variety of modules in the CP constellation because the CP master (i.e. hex19 module) is changed!.
    Officially, this needs a FAZIT connection with a registered VW agent. Regardless of whether you do this the official way, or by a "hack", my advice is to arrange this before you start swapping modules (and incidentally, make admaps of the modules before starting the exercise) - down here in the very deep south, some dealers won't delete CP errors if they don't also do the module swap (and as I understand, independent workshops haven't been able to get a FAZIT license, yet).
    Sketchy
    Mar 2015
    Poland
    hi, have little problem,
    Change gateway, bcm, connection wire etc.. but:
    - left lamp is 29 & D6 ID can driver
    - right lamp is 39 & D7 ID can driver
    D6 & D7 have correct, but on both driver have ID 29 (left lamp) so when I connect both, can't conenction with 29 & 39 driver, when I disconnect (left or right) I connect only 29 (left lamp) can driver. When I connect to phisical right lamp only can connect via 29 ID can driver, how chagne this driver to 39 id can ? Phisical left and right can are connect to the same can to 4B module.
    Thanks for help
