Results 1 to 2 of 2
Thread: DPF warning light
    Dec 2015
    DPF warning light
    LT3 VW Crafter R5 2008 V5 2.5
    The DPF warning light has come on, I have driven up the motorway for 20 minutes straight away, but the light has not gone out, a few shotr journeys later and the coil light is on, and I suspect the vehicle is in limp mode - what happened to the regenerations ?? as far as I am aware it has not done any regerations since owning (3 months) with mostly short journeys.
    Should I force regen, or get it taken off and cleaned ... I am willing to follow this: http://wiki.ross-tech.com/wiki/index...y_Regeneration
    But do not know the DPF spec, VCDS is measuring:
    26.0 % Particle Filter Load Coefficient
    57.0 Particle Filter Carbon Mass
    0.0 % Carbon Mass Learned Value
    I am worried I might burn the van down, could anyone help with what the above number tell me, and is it say to force regen.
    Log and measuring blocks below:
    I have posted about the previously cleaned DPF here:
    https://forums.ross-tech.com/showthr...ings-with-VCDS
    Tuesday,01,October,2019,11:31:27:43490
    VIN: WV1ZZZ2EZ86033313   License Plate:
    Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
              B0 B1 B2 B3 B4 B5 B6 C1
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 843 D    HW: 906 900 380 3
       Component: IMMO          1423  1322
       Revision: 00423000    Serial number: VWZDZ0Q4002050
       Shop #: WSC 65439 002 1048576
       VCID: 2809F9BA0EF98567A17-807C
    01312 - Powertrain Data Bus
    Address 94: LT3 Airbag
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3331.rod (*)
       VCID: 55F7804E658BC88FCA1-8000
    Address 95: LT3 ESP
       Part No SW: 9064481553    HW: 0004460053
       ASAM Dataset: 3 4099
       ROD: CRFT_ESP_3_36928.rod (*)
       VCID: 0D47A82E8DDBC04FB21-8058
    42A4 - Voltage supply: Lower limit not reached
                MIL ON - Test Complete - Stored
    Address 96: LT3 Instruments
       Part No SW: 9064482021    HW: 0034468021
       ASAM Dataset: 32 776
       ROD: CRFT_KOMBI_32_776.rod
       VCID: 04518D0ADE918107EDF-8050
    Address 99: LT3 Ign. Switch
       Part No HW: 9069003803
       Shop #: WSC 00000 288 01315
       ASAM Dataset: 67 259
       ROD: CRFT_EZS_67_259.rod
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-93.clb
       Component: HF-FFB        1423  1322
       Revision: 00423000    Serial number: 12345678901234
       Shop #: WSC 00082 210 103452
    00171 - Key 1 not learned
    Address 9B: LT3 Driver Door
       Part No HW: 9068203926
       ASAM Dataset: 33 771
       ROD: CRFT_FTUHR_33_771.rod (*)
    Address B0: LT3 Roof Display
       Part No SW: 9064480323    HW: 9068203601
       ASAM Dataset: 21 3
       ROD: CRFT_DBE_21_3.rod (*)
       VCID: 074B9A06EFA7AA1F88D-8052
    909B - Alarm Horn (H12): No communication
                Test Complete - Active/Stored
    909C - Alarm Horn (H12): No or incorrect basic setting
    Address B1: LT3 Upper Console
       Part No HW: 9065454107
       ASAM Dataset: 67 3
       ROD: CRFT1_OBF_67_3.rod (*)
    Address B4: LT3 Central Elec.
       Part No SW: 9064420600    HW: 9065450601
       ROD: CRFT_EZE_33_771.rod (*)
       VCID: 7F5B02E6B777E2DFB0D-802A
    900D - Left High Beam Lamp (L125): Short to Plus
    Address B6: LT3 Steering Wheel
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 06559702E8ADB317F3B-8052
    End----------(Elapsed Time: 01:17, VBatt start/end: 14.1V/14.2V)-----------
    Tuesday,01,October,2019,11:38:56:43490
                    Address 91: LT3 Engine  (074 906 032 AT)
    11:38:53 Group 070: Particle Filter (Regeneration Status II)
      00000100  Status 4 Regeneration
      4393.0 s  Time
      0.0  Failed Regenerations
      0.0  Successful Regenerations
    11:38:53 Group 008
      756 /min  RPM
      0.0 Nm  Torque
      158.6 Nm  Torque
      185.4 Nm  Torque
    11:39:00 Group 069: Particle Filter (Regeneration Status I)
      00000000  Status 1 Regeneration
      00000000  Status 2 Regeneration
      00000000  Status 3 Regeneration
    11:39:00 Group 008
      756 /min  RPM
      0.0 Nm  Torque
      158.6 Nm  Torque
      185.4 Nm  Torque
    11:39:02 Group 069: Particle Filter (Regeneration Status I)
    11:39:02 Group 008
      735 /min  RPM
      0.0 Nm  Torque
      158.6 Nm  Torque
      185.4 Nm  Torque
    11:39:06 Group 068: Particle Filter (Exhaust Gas II)
    11:39:06 Group 008
      756 /min  RPM
      0.0 Nm  Torque
      158.6 Nm  Torque
      185.4 Nm  Torque
    11:39:10 Group 067: Particle Filter (Exhaust Gas I)
      108.0C  Temperature bef. Turbo Charger
      102.0C  Temperatur in Particle Filter
      17.85  Press. Difference Particle Filter
      0.00  Press. Difference Offset
    11:39:10 Group 008
      735 /min  RPM
      0.0 Nm  Torque
      158.6 Nm  Torque
      183.0 Nm  Torque
    Dec 2015
    OK, have followed the instructions under:
    Diesel Particle Filter Emergency Regeneration: http://wiki.ross-tech.com/wiki/index...y_Regeneration
    After 'do-it' I saw no indication on the dash that regen was taking place (I thought some warning light would be flashing). I just received a message in VCDS stating that the code had been accepted (which was in fact 20016, not 21295 for "Enable Regeneration".
    I immediatley drove up the motorway again, temps got up to 500-700, within a few minutes the "Particle Filter Load Coefficient" dropped steadily to zero (from 26%) over about 10 miles, with revs at 2500rpm, the DPF warning light went off a few minutes later.
    Should I presume: "Enable Regeneration" 20016 did what it says it would do, could a regen simply not have started on its own with the motorway drive - confused why it didn't sort itself out on the first motorway drive since seeing the warning light.
    Should I still expect to have the DPF removed and cleaned, or will this have burnt off soot in the DPF properly, my journeys are mostly short urban, and have omitted to do the weekly zip up the motorway.
  3. Likes Uwe liked this post
