A3 2004 8P1 2.0FSI manual, 192770km-119781mi
What happened:
It was working perfectly until I changed the oil. I forgot to warm the engine before changing the oil, ending up overfilling. Also during servicing I unplugged the throttle body and cleaned it with spray, then re-plugged.
Then when I started it, it would shake badly while idling. Realising I overfilled, I took some oil out and re-balanced the oil level. Waited a day and it would still shake badly. I waited for a couple of more days and when I try starting it would crank but wouldn't start for a while. I connected my VCDS and saw these logs:
I cleaned the error codes and did a throttle retraining. This fixed the issue and I idled for a couple of minutes, reving occasionally up to 3000rpm. Then I parked it next to driveway downhill. Wait a couple of more days and it won't start. VCDS throttle retraining won't change anything this time.
Pulled the car to level driveway again, retrain the throttle but no change. It's not starting. Then the engine gave these errors:
I think I cleared above errors again to do another throttle training, and after that the car won't start at all (but cranks), and VCDS auto-scan gives the error below and nothing else (tried before and after start attempts, now it's always the same):
ross-tech site tells to fix the ECM problem before anything else for this error.
Since I seem to have induced this problem myself, I don't know if I should do a general won't start troubleshooting or not (and I don't know where to start).
What happened:
16716 - Knock Sensor 2 (G66)
P0332 - 002 - Signal too Low - Intermittent
18711 - Leak in Air Intake System
P2279 - 008 - - MIL ON
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
17951 - Angle Sensor 1 for Throttle Actuator (G187)
P1543 - 002 - Signal too Small - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 002 - - Intermittent
17987 - Throttle Actuator (J338)
P1579 - 001 - Adaptation Not Started - Intermittent
