Results 1 to 2 of 2
Thread: 2011 VW Jetta 2.5 SE, DOOR CONTROL MODULE/RADIATOR FAN ISSUE
    Sep 2019
    Help needed!
    I have couple issues here, I'v recently replaced a radiator fan assembly, which I ordered form EuropaParts. And now,any time I open a door or a trunk, or unlock/lock the car with key mob, fans will run for 5-10 seconds and then go off, with no engine running or keys in the ignition. I verified that this fan is compatible with my car by calling and providing a vin# to EuropaParts. Also i verified there is no water/damage in the ECM/ECU.
    Second issue, passenger front door window will roll up or down in increments of like 2in at the time, then I need to release the window switch and press again.
    Any thoughts.?
    Thank you
    And here is Auto Scan:
    Monday,23,September,2019,14:23:14:36338
    VCDS Version: 19.6.1.0 (x64)
    VIN: 3VWDZ7AJ6BM04XXXX
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 56
    VIN: 3VWDZ7AJ6BM048736   Mileage: 160120km-99493miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 G    HW: 07K 906 055
       Component: 2,5l R5/4V      G01 8236
       Revision: T4H04---    Serial number:
       Coding: 0000075
       VCID: 326B4402ADA293DF5F-8066
    005386 - Engine Off Timer Performance
                   P150A - 000 -  - Intermittent
                        Mileage: 160122 km
                        Date: 2014.01.30
                        Time: 00:50:52
                        RPM: 1120 /min
                        Load: 23.1 %
                        Temperature: 79.0C
                        Temperature: 53.0C
                        Absolute Pres.: 1020.0 mbar
    Readiness: 1110 0101
       Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
       Component: AQ 250 6F           1741
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 000FDECA538EF14F99-8054
       Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
       Component: ESP MK60EC1   H31 0106
       Revision: 00H31001
       Coding: B14B440C492608028D1222E7921F1061A70000
       VCID: 78FFB62ACB5EB98FA1-802C
       Part No SW: 5C0 820 047 P    HW: 5C0 820 047 P
       Component: J301  Klimaanlage   0103
       Revision: 2000908S    Serial number: 00000000174599
       VCID: 2D51577EB49CCC2702-8078
       Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0226
       Revision: B2066001    Serial number: 03311341100532
       Coding: 7B994B1808AB0B0000302000240884D400C2502E60000000300000000000
       VCID: 2D51577E749CCC2702-8078
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3463
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: -------------  002 3xxx
       Coding: 020000
       Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3463
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3463
       Coding: 800000
    03302 - Response Closing Status of Passenger's Door
                        Reset counter: 67
                        Mileage: 160122 km
                        Date: 2014.02.12
                        Time: 23:06:31
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 67
                        Mileage: 160122 km
                        Date: 2014.01.30
                        Time: 00:42:54
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   013 0807
       Serial number: 003GTD08L6EO
       Coding: 00003932
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3467421A9FB69DEF4D-8060
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1000001ZVB03
       Coding: 303144
       Serial number: 3572MSME77472358ZZZ-
       Serial number: 3582MSME47653259ZZZZ
       Serial number: 3516KSME7000330DZZZF
       Serial number: 3526KSME7F0F330DZZZ3
       Serial number: 3556LSME7542610DZZZW
       Serial number: 3566LSME3E5E7F2FZZZR
    9483264 - Seat Occupied Recognition
              B10B4 00 [137] - Function Restriction due to Undervoltage
                        Reset counter: 67
                        Mileage: 160122 km
                        Date: 2019.09.23
                        Time: 00:21:35
       Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
       Component: KOMBI         H07 0406
       Coding: 270201
       Shop #: WSC 00066 000 00149
       VCID: 2B5559664288C2171C-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 0226
       Coding: 102200
       VCID: 70EF8E0AA32EE1CF69-8024
       Component: IMMO          H07 0406
       VCID: 6ADB9C628DF21B1F27-803E
       Part No SW: 1K0 035 164 A    HW: 1K0 035 164 A
       Component: LOW NAR       H14 0043
       Revision: -----06S    Serial number: VWZ4Z6K3060260
       Coding: 0500040001
       VCID: 204FBE4A334E114FB9-8074
    End-------------------------(Elapsed Time: 02:47)--------------------------
    16.4905 S, 151.7375 W
    The coolant fans will run when there is either a command from the ECM and the 15-power (key on power) is present or there is ONLY one of the following present:
    - 15-power to the J293
    - Fan (PWM) signal from the ECM.
    So in other words, if for some reason, the ECM is waking up and then sending a PWM signal to the J293-Fan Controller and there is NO 15-power, the fans will run. Also if there is somehow 15-power to the J293-Fan Controller and no PWM signal from the ECM, the fans will run.
    So it will be necessary to check and monitor at the J293 which is the case. Are you getting 15-Power to the J293 or are you getting a PWM to the J293 when you open the doors? We recommend to use the wiring diagrams in the Official Factory Repair manuals to identify the powers, ground and signal to the J293.
    The fault code P150A would indicate the ECM maybe powering up for some reason. This fault code will set when the "Difference between engine off time and ECM after run time less than or greater than 8.0 seconds", according to the Official Factory Repair manuals.
    I would have the passenger door controller, wiring, connections, etc. (see link below for the wiki page). This maybe related to your concern too.
    014 - Defective
    By the way, there is an ECM update for fault codes [P0106, P0507, P050A], ref: VW TSB: 2034012
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
