Results 1 to 5 of 5
Thread: VW Golf MK5 - 2.0FSi 4WD - fitting a 2.0TFSi engine
    Morning
    We have a customer that has blown the engine in his MK5 golf 2.0FSi BVX engine (2006) 4 wheel drive
    He brought a 2006 2.0TFSI (BWA engine) bodywork damaged VW EOS
    We have removed the engine and done the engine swap (Which was quite straight forward as both were same style FSi engines)
    So the engine, engine loom and ECU all got swapped from the EOS to the Golf
    Checking the wiring diagram showed the car side of the engine ECU (T94 plug) was wired completely different and these have all been rectified
    We have also added the coolant pump wires and boost pressure sensor wires
    The problem is the immobilizer system
    Ive got the pins codes for both the Golf and EOS
    I thought we could just match the EOS ECU the VW Golf but it appears the Golf uses Gen 4A and the EOS uses Gen 4C
    EOS id = VWX
    Golf id = VWZ
    Is there anyway to match a 4A to 4C system???
    If not im guessing im going to need a BWA Golf ECU that uses 4A Immobilizer system?
    EOS scan:
    Saturday,28,September,2019,07:49:47:06091
    Dealer/Shop Name: DG Motor Services
    VIN: WVWZZZ1FZ6V008293   License Plate:
    Chassis Type: 1F (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1FZ6V008293   Mileage: 197480km-122708miles
    26-Auto Roof -- Status: Malfunction 0010
       Part No SW: 1Q0 907 115    HW: 1Q0 907 115
       Component: 2.0l R4/4V TFSI     0030
       Revision: --H14---    Serial number: VWX7Z0F23NL8I3
       Coding: 0403000318030160
       Shop #: WSC 00046 123 12345
       VCID: AD125FB53406752782-80F8
    11 Faults Found:
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage
                        Mileage: 197495 km
                        Time: 00:03:25
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.446 V
                   P1602 - 002 - Voltage too Low
                        Fault Status: 01100010
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    000291 - Throttle Position Sensor (G69)
                   P0123 - 001 - Signal too High
                        Fault Status: 01100001
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    000546 - Angle Sensor 2 for Throttle (G188)
                   P0222 - 002 - Signal Too Low
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    004248 - Intake Manifold Tuning Valve Position Sensor (G336)
                   P1098 - 001 - Open or Short to Plus
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    000568 - Manifold Pressure / Boost Sensor (G31)
                   P0238 - 001 - Signal too High
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    000400 - Fuel Pressure Sensor (G247)
                   P0190 - 001 - Circuit Malfunction
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    009529 - Low Pressure Fuel Sensor (G410)
                   P2539 - 001 - Open Circuit
                        Mileage: 197483 km
                        Time: 00:00:45
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.446 V
    000280 - Engine Coolant Temp. Sensor (G62)
                   P0118 - 002 - Signal too High
                        Mileage: 197483 km
                        Time: 00:00:46
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.319 V
    000275 - Intake Air Temp. Sensor (G42)
                   P0113 - 002 - Signal too High
                        Mileage: 197483 km
                        Time: 00:00:46
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.319 V
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 002 - Signal too High
                        Mileage: 197483 km
                        Time: 00:00:46
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 12.319 V
    Readiness: 0110 0101
       Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
       Revision: 00H13001
       Coding: 0004834
       Shop #: WSC 00020 000 00000
       VCID: F1AA83C5E8BE51C7E6-80A4
                013 - Check DTC Memory
       Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
       Component: ClimatronicPQ35 093 0101
       Revision: 00093002    Serial number: 00000000000000
       VCID: AB1651AD0A127B179C-80FE
                009 - Open or Short to Ground
       Revision: 00H46000    Serial number: 00000005592009
       Coding: E58E8F0700041500470A00000F00000000095D035C0000
       VCID: B73E7DDDC65ACFF7E8-80E2
       Subsystem 1 - Part No: 1K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00063445
       Shop #: WSC 00020
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 00020
    10 Faults Found:
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.35 V
                        Reset counter: 127
                        Voltage: 12.80 V
    01117 - Generator Terminal DF Load Signal
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 13.80 V
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
                        Reset counter: 127
                        Mileage: 197483 km
                        Voltage: 12.30 V
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 3C Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B300089D4
       Coding: 0013123
       VCID: BA3864E9F548D29F17-80EE
       Subsystem 1 - Serial number: 6332SRB4032B100BQ
       Subsystem 2 - Serial number: 6342SRB4031C151CY
       Subsystem 3 - Serial number: 637  RB4        8
       Subsystem 4 - Serial number: 638  RB4        9
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                        Fault Status: 11101010
                        Mileage: 197483 km
                        Time: 00:12:25
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                        Mileage: 197483 km
                        Time: 00:12:25
    01217 - Side Airbag Igniter; Driver Side (N199)
                        Fault Status: 11100001
                        Mileage: 197483 km
                        Time: 00:12:26
                        Mileage: 197483 km
                        Time: 00:12:26
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksulenmodul 634 0070
       Coding: 0000041
       VCID: F6A0B0D981D076FF33-80A2
       Part No: 1Q0 920 962 A
       Component: KOMBIINSTRUMENT VDD 4314
       Coding: 0021403
       Shop #: WSC 00581 067 57207
       VCID: AF2E45BD3E0A0737B0-80FA
       Part No SW: 1K0 907 530 G    HW: 1K0 907 951
       Component: J533__Gateway   H10 0140
       Revision:   H10       Serial number: 30001064038197
       Coding: 3D3F274007005001
       Component: IMMO            VDD 4314
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 A    HW: 1Q0 959 255 A
       Component: Verdecksteuergeraet 0512
       Revision: 0028000J    Serial number: 060870150
       Coding: 0655362
       VCID: B62070D9C15036FFF3-80E2
    00220 - Connection to Sunroof
                        Reset counter: 127
                        Mileage: 197483 km
                        Time: 00:12:24
                        Voltage: 13.70 V
                        Voltage: 13.60 V
                        Voltage: 4.90 V
                        Error Code: 0
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1Q0 959 701 C
       Component: Tuer-SG         024 2740
       Coding: 0000695
       VCID: B4244AD1D72C24EFCD-80E0
       Part No: 1K2 909 144 K
       Component:    KSG PQ35 G2  020 0202
       Coding: 81908A000186285B0804840570085EC690BCA0
       VCID: 8346D90DC202535704-80D6
       Subsystem 2 - Component:       NGS No Answer
       Subsystem 3 - Part No: 1Q0 951 177 A
       Component: Innenraumueberw.158 0502
    00323 - Vehicle Inclination Sensor (G384)
                        Reset counter: 127
                        Mileage: 197483 km
                        Time: 00:12:39
    01134 - Alarm Horn (H12)
                        Reset counter: 127
                        Mileage: 197483 km
                        Time: 00:12:39
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1Q0 959 702 C
       Component: Tuer-SG         023 2740
       Coding: 0000694
       VCID: B52277D5DC563DE7FA-80E0
    00132 - Outside Door Handle Illumination/mirror Light Passenger Side
       Part No: 1K0 035 195 B
       Component: Radio BVX       008 0015
       Coding: 0040400
       VCID: A502A7956CF64D674A-80F0
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
       VCID: F3A689CD92A263D714-80A6
       Part No: 1Q0 959 704
       Component: Tuer-SG         020 2705
       Coding: 0000128
       VCID: F4A48AD197AC64EF0D-80A0
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1Q0 919 283
       Component: 30 Einparkhilfe     0702
       VCID: F2A88CC9EDB86ADF1F-80A6
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.1V)-----------
    VW Golf scan (But has EOS ECU fitted)
    Thursday,26,September,2019,08:26:09:06091
    VIN: WVWZZZ1KZ6W171458   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 56 62 72 76
    VIN: WVWZZZ1KZ6W171458   Mileage: 197490km-122714miles
       Part No SW: 1Q0 907 115 C    HW: 1Q0 907 115
       Component: 2.0l R4/4V TFSI     0040
       Coding: 041C000318070160
       Shop #: WSC 00400 210 83214
       VCID: AC1452B10F1C7C2F95-80F8
                        Mileage: 197495 km
                        Time: 00:01:07
                        Temperature: 18.0C
                        Temperature: 20.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.843 V
                        Mileage: 197495 km
                        Time: 00:01:09
                        Temperature: 18.0C
                        Temperature: 20.0C
                        Voltage: 13.843 V
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
       Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
       Component: ESP 4MOTION MK60    0102
       Revision: 00H13001
       Coding: 0021122
       Shop #: WSC 01279 785 00200
       Part No: 1K0 820 047 DQ
       Component: Climatic PQ35   090 0505
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    00898 - Control Circuit A/C compressor
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000005541050
       Coding: E58F8F2700041500001400001400000000087F075C
       Shop #: WSC 01392 785 00200
       Coding: 00063445
       Shop #: WSC 01392
       Coding: 00208933
       Shop #: WSC 01392
    10 Faults Found:
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Fault Status: 01111100
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Reset counter: 62
                        Mileage: 197495 km
                        Voltage: 13.55 V
                        Fault Status: 00110100
                        Reset counter: 102
                        Mileage: 197495 km
                        Voltage: 13.80 V
                        Reset counter: 102
                        Mileage: 197495 km
                        Voltage: 13.70 V
       Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
       Component: 38 AIRBAG VW8   018 2200
       Revision: 02018000    Serial number: 0038MD0AETER
       Coding: 0013112
       Shop #: WSC 01269 785 00200
       VCID: BB3661EDFA72EB970C-80EE
       Subsystem 1 - Serial number: 6332MSME1009327F8
       Subsystem 2 - Serial number: 6342MSME10690A7FK
       Subsystem 3 - Serial number: 6352QSME09364B13E
       Subsystem 4 - Serial number: 6362QSME09491F65R
       Coding: 0000042
       Shop #: WSC 00873 210 75166
       Part No: 1K0 920 962 F
       Component: KOMBIINSTRUMENT VDD 4312
       Coding: 0007403
       Shop #: WSC 80093 222 69422
       VCID: AE1058B939000E3FBB-80FA
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 2800106322035F
       Coding: BD3F0740070003
       VCID: AA1854A905E8621F67-80FE
                        Reset counter: 102
                        Mileage: 197495 km
                        Time: 00:00:56
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554
       Component: HALDEX 4Motion      0101
       VCID: EA9894A9C568A21FA7-80BE
       Component: IMMO            VDD 4312
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2374
       Coding: 0000692
                        Mileage: 7480 km
                        Temperature: 19.0C
                        Voltage: 13.70 V
                        Voltage: 13.50 V
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AK
       Coding: 01C802087F2D8405485FC69010CC
       Shop #: WSC 00864 210 91859
       VCID: F9BABBE5B0CE19875E-80AC
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 1K0 951 177 A
       Component: Innenraumueberw.005 0202
       Part No: 1K0 959 702 K
       Coding: 0000692
       Coding: 0040400
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2438
       Coding: 0000144
       VCID: B32649CDD22223D7D4-80E6
       Part No: 1K0 959 704 F
       Coding: 0000144
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
    End----------(Elapsed Time: 01:37, VBatt start/end: 13.8V/13.8V)-----------
    Somes pictures so far
    Golf with TFSi engine fitted:
    VW Golf 2.0TFSI 4 motion conversion by DG Motor Services, on Flickr
    Whats left of VW EOS by DG Motor Services, on Flickr
  2. Likes Uwe, NZDubNurd liked this post
  3. #2
    May 2017
    Or contact Spacewalker on this forum. He should have the means to make the adaptation
  4. Likes DGMotors liked this post
  5. #3
    Sent PM, thank you
  6. #4
    Tartu, Estonia
    Cool project...
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  7. Likes DGMotors liked this post
  8. #5
    Just to update,
    I did contact spacewalker but he must have been on holiday (when he got back he did offer to sort this all out )
    but in the meantime I brought a second hand ECU from a golf and this programmed in to the immobilizer system all fine, it now runs and were just sorting the final items out.
    VW Golf 2.0TFSI 4WD 4 motion by DG Motor Services, on Flickr
    almost ready to run by DG Motor Services, on Flickr
  9. Likes downtime, NZDubNurd, m87a, 4WDDSG6, Uwe liked this post
