Results 1 to 3 of 3
Thread: 2011 TDI Sportwagen with P0401 and P240F codes
    Sep 2019
    Question 2011 TDI Sportwagen with P0401 and P240F codes
    I have a 2011 TDI Sportwagen with P0401 and P240F codes. The first began intermittently (for several months) but in the last several weeks the MIL seems to stay on all the time. The second code came more recently. When the code was on-again/off-again, I didn't take it too seriously.
    The radio stopped working; an after market radio was installed. The car has not been modified in connection with Dieselgate. We have had the car since it was new in October 2010.
    First, how long can I drive the car before problems get more serious? (There do not seem to be any driveability issues at this time. I haven't noticed any changes in mileage either.)
    Second, how could I go about narrowing the problem?
    The Ross-Tech P0401 page suggests three options: a wiring fault, a clogged/malfunctioning valve, and a clogged system (tube?). Will the second code help locate the fault? I have not been able to locate further information on that code. Would it help to drive around logging the EGR data for a while? And, if it would, what would I be looking for?
    Third, how should I go about fixing the problem once I've narrowed it as much as possible?
    How might I address each of the three options? Would I just wiggle the connectors or is there a specialized test that I have missed. (There is a fault mentioned towards the end of the autoscan "Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb" but this has never shown up as a code before the autoscan. Is this a clue?
    If I do need to clean the EGR system and/or replace the valve, is there any way to know what needs to be done beforehand (so I can order the parts) or is it a matter of finding out once it is disassembled?
    Where would I look for good directions on removal, cleaning, and replacement? I've seen youtubes and posts but, taken together, there isn't much clarity. Specifically, would the intake manifold need to be removed and would components behind the engine need to be dealt with? Looking at some of the forum posts, it seems that sometimes the wrong things get done and the right things don't get done. (If you send me to the resources mentioned elsewhere that is OK.)
    Thank you.
    Thursday,26,September,2019,15:40:08:47515
    VIN: 3VWML7AJ1BM611760   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
    VIN: 3VWML7AJ1BM611760   Mileage: 232660km-144568miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 DA    HW: 03L 906 019 DA
       Component: R4 2,0L EDC G000SG  9971
       Revision: 12H08---    Serial number:
       Coding: 0050072
       Shop #: WSC 00066 000 00000
       VCID: 6D87C940B19A67DF11F-8038
    001025 - EGR System
                   P0401 - 001 - Insufficient Flow - Intermittent - MIL ON
                        Fault Status: 10100001
                        Fault Frequency: 174
                        Mileage: 222661 km
                        Date: 2013.10.05
                        Time: 09:20:25
                        RPM: 2001 /min
                        Speed: 78.0 km/h
                        Voltage: 14.21 V
                        Load: 75.3 %
                        Load: 100.0 %
                        Mass Air / Rev.: 370.0 mg/str
                        Mass Air / Rev.: 390.0 mg/str
    009231 - Exhaust Gas Recirculation System
                   P240F - 000 - Response too Slow - MIL ON
                        Fault Status: 11100000
                        Fault Frequency: 18
                        Mileage: 229978 km
                        Date: 2014.01.12
                        Time: 12:55:29
                        RPM: 1748 /min
                        Speed: 68.0 km/h
                        Load: 57.6 %
                        Mass Air / Rev.: 0.0 mg/str
                        Mass Air / Rev.: 20.0 mg/str
                        Mass Air / Rev.: 250.0 mg/str
                        Mass Air / Rev.: 315.0 mg/str
    Readiness: 1 2 0 0 0
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: 114B600C492300FB881206EA92190042B70000
       VCID: 74B1DC24DEB0B617DE1-8020
    02214 - Tire Pressure Warning
                        Fault Frequency: 9
                        Reset counter: 177
                        Mileage: 222294 km
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 50433
                        Count: 1
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 00066 000 00147
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 75B7E120D54AAF1FE9F-8020
       Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
       Component: BCM PQ35 B    011 0035
       Revision: BG011001
       Coding: 2D380E1F902F3EC400080081600000C401000086535D8560648020000040
       VCID: 34311C249E30F6171E1-8060
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 27071  21  0512
       Coding: 009795
                        Fault Status: 00101010
                        Fault Frequency: 127
                        Reset counter: 189
                        Mileage: 218596 km
                        Date: 2013.07.07
                        Time: 18:46:59
                            Term 15 On
                        Voltage: 13.85 V
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R00P35-
       Coding: 00003044
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 392F2D10B9D20B7FCD7-806C
       Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
       Component: BF-Gewichtss.  007 0001
       Serial number: ---0000R--0005BYQ100
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME7F727354ZZZ0
       Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME32557354ZZZS
       Serial number: 3511HSME061A2C22ZZZG
       Serial number: 3521HSME1A272D22ZZZL
       Serial number: 35527SME36354F20ZZZE
       Serial number: 35627SME1F227721ZZZE
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JFF000VF
       Coding: 108A140000
       Shop #: WSC 00066 000 00187
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 72BDDA3CA424B827CCD-8026
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H05 0010
       Serial number: 0007378
       Coding: 820000
       Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
       Component: KOMBI         H03 0406
       Coding: 270F01
       VCID: 2F3B13487796D5CF633-807A
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530 A    HW: 1K0 907 951
       Component: J533  Gateway   H25 5603
       Revision:   H25       Serial number: 29071001200002
       Coding: E9807F0600160300002002
       VCID: 2E050E4C7C1CDCC7685-807A
    01304 - Radio
                        Reset counter: 133
                        Mileage: 146208 km
                        Date: 2015.12.22
                        Time: 12:30:56
       Revision: 00001000    Serial number: 1225223R999K06
       VCID: 7EA5FE0CECFCEC47B85-802A
       Component: IMMO          H03 0406
       VCID: 6A8DC25C8CF470E774D-803E
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0001234423
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 270BFB685F668D8FAB3-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005011476
       Coding: 000490
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [008] - Electrical Failure
                        Fault Frequency: 9
                        Reset counter: 194
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 313F15306D22C33F757-8064
       Component: EZE_2         H25 5603
       Coding: 050B0500
       VCID: 6FBBD348B79695CF233-803A
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H02 0220
       Component: J394EE20SKB13  H02 0220
    02071 - Local Databus
                        Fault Status: 00101100
                        Fault Frequency: 9
                        Reset counter: 170
                        Mileage: 230058 km
                        Date: 2014.01.13
                        Time: 09:34:36
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0001209770
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW32.rod
       VCID: 2809F854527882F7A29-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005112584
       Coding: 000490
    Address 56: Radio
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668271623
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 323D1A3C64A4F8270CD-8066
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Reset counter: 154
                        Mileage: 146208 km
                        Date: 2015.12.22
                        Time: 16:04:57
    9457171 - Right audio channel for speech/telephone
              B104E 13 [009] - Short to GND
                        Reset counter: 133
                        Mileage: 146208 km
                        Date: 2015.12.22
                        Time: 16:04:55
    0022 - Radio
              U1066 00 [009] - No Communication
              [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                        Reset counter: 133
                        Mileage: 146208 km
                        Date: 2015.12.22
                        Time: 12:30:52
    End----------(Elapsed Time: 01:21, VBatt start/end: 12.5V/12.5V)-----------
    HQ
    https://www.vwdieselinfo.com/
    You might want to see about having the car updated, might be covered under extended warranty once completed.
    Jef
  3. Likes Uwe liked this post
    Sep 2019
    Thank you for the reply. I didn't find the e-mail notice until today. Sorry for the tardy reply. The message raises more questions.
    First, since you didn't say anything about driving, does this mean I can drive the car indefinitely without worry about damage to the engine or exhaust system?
    Second, is locating the problem a random search through the possibilities or does the information generated help locate the problem or do I need to perform further tests? In particular, I'd want to narrow the choices down, if possible, between electrical and mechanical, and between the front of the engine and the back. I've seen both referred to. I've also seen discussions of diesel particulate filters and catalytic converters in connection with the same basic code (including on the Ross-Tech forum). Sometimes the answer from Ross-Tech is to leave that stuff alone before it is damaged.
    Third, wouldn't I want to know exactly what is wrong with the car and whether the problem is covered by warranty before I go anywhere near the dealer? Given that Volkswagen was lying about the engine being a clean diesel and that they decided that I did not qualify for settlement payment, I probably don't want to trust them very much. Given that it is often difficult to get dealers to honor warranties, I probably want to know for certain whether the repair is covered also.
    Thank you.
    Steve
