Results 1 to 10 of 15
Thread: Cross Reference Schematic Number (like J526) to a component ID (like 4B0 999 999)
    Jul 2019
    Does such a cross reference exist? Is there some key in the lbl file foir instance?
    HQ
    Yes. At the dealer, the parts catalog (ETKA), they can input a car's VIN, then do a "SDC-CODE" search, and find that a J526 is a radio navi unit, part number blah blah blah.
    As best I can tell, PL24 doesn't have this handy function.
    Jef
    Jul 2019
    Hi: Found this in vcds lbl file
    ; VCDS Label File
    ; Copyright 2014+ Ross-Tech, LLC
    ; Audi A6 (4B)
    ; Component: J526 - Telephone/Telematics Control Module (#75)
    ; P/N: 8E0-035-616-???
    So I guess I can search lbn. files for component or part number.
    HQ
    eh... when you first scan any given control module, on the Open Controller screen, the VAG number is the part number that control module.
    So in that example, 4F2 910 115 B is the part number of the control module. Also that info will be in the Auto-Scan as well... may be refered to as the "Part No SW:"
    But most electrical items do not list part number info via the data port. For example, a N276 or a G40. But give ETKA the VIN and then do a SDC-CODE search and it will pull up those items and part numbers.
    Our label files are not always able to be opened for viewing and don't always have part number references in them.
    Jef
  5. Likes Uwe, NitrousOxide, Dana liked this post
    Jul 2019
    Sort of a follow on question:
    scan:
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 981 P
    Component: KOMBI+WEGFAHRS. VDO D12
    Coding: 03283
    Shop #: WSC 02805
    VCID: 3365317F01415AD754-5140
    WAUML64B43N104356 AUZ7Z0C2386232
    01304 - Radio
    Intermittant due to problem with corroded wires - fixed.
    Is this an indication that Telephone Transceiver is installed even though 77 does not show in auto-scan?
    Jul 2019
    I googled EKTA and tested several sites (including Europe): Information on VIN: WAUML64B43N104356 absent in the database. ?????????
    Quote Originally Posted by tultalk View Post
    I would take it as an indication that the Instrument cluster thinks one should be.
    There's a sort of a crude installation list in Adaptation channels 60, 61, and 62 of those clusters. Post the values from those three channels please.
  9. Likes Dana liked this post
  10. #8
    HQ
    PL24 doesn't like WAUML64B43N104356 as well. Please post a full Auto-Scan at this time.
    Jef
  11. Likes Dana liked this post
  12. #9
    Jul 2019
    Tuesday,01,October,2019,12:00:24:29746
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUML64B43N104356   License Plate:
              75 76 77
    Address 01: Engine        Labels: None
       Part No: 4D0 907 560 CL
       Component: 4.2L V8/5V      G   0001
       Coding: 07752
       Shop #: WSC 02325
       VCID: 72EBF47B3EDB13DF9F-5140
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 01L-927-156.lbl
       Part No: 4B0 927 156 FG
       Component: AG5 01L 4.2l5V  USA 1014
       Coding: 01002
       Shop #: WSC 02325
       VCID: 71E9FB773BDD28C766-5140
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 H
       Component: ABS/ESP allrad      3428
       Coding: 06397
       Shop #: WSC 02325
       VCID: 2643D82BC2933F7FC3-5140
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AM
       Component: A6-Klimavollautomat 0105
       Coding: 00010
       Shop #: WSC 02325
       VCID: 65C19F27FF15F4670A-257A
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 Q
       Component: Airbag 8.4EP        2001
       Coding: 0000607
       Shop #: WSC 02325 785 00200
       VCID: 3E73104B6A0387BFAB-5140
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01005
       Shop #: WSC 02325
       VCID: 2F6D3D0FED697E3730-5140
       Coding: 03283
       Shop #: WSC 02805
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D38
       Coding: 15885
       Shop #: WSC 02116
       VCID: 3365317F01415AD754-4F22
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C572A03DC7F052F15-4B00
       Part No: 4Z7 907 357
       Coding: 00050
       Shop #: WSC 02325
       VCID: 0407A2A3146F2D6FBD-4B1A
       Part No: 4B0 035 195 S
       Component: symphony II NP2    0011
       Coding: 00225
       Shop #: WSC 02101
       VCID: 306F3E73F05761CF29-4E96
    00856 - Radio Antenna
                36-00 - Open Circuit
    Address 75: Telematics        Labels: 8E0-035-616.lbl
       Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
       Component: Telematik USA1
       Coding: 0002303
       VCID: 2345C13FE1A1CA57A4-5140
    End-------------------------(Elapsed Time: 05:19)--------------------------
    Tuesday,01,October,2019,12:02:01:29746
    Adaptation Channel 060:
    Stored value 1027
    Powertrain CAN-Databus
      N/A
    Adaptation Channel 061:
    Stored value 0
    Comfort CAN-Databus
      N/A
    Adaptation Channel 062:
    Stored value 3
    Infotainment CAN-Databus
      N/A
  13. Likes Dana liked this post
  14. #10
    I still think they should put the assigned number after the part number in description & to expose this data more clear to parts departments and techs.
  15. Likes Dana liked this post
