here is the scan
Wednesday,25,September,2019,14:15:11:14605
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Address 22: AWD Labels: 02D-900-554.LBL
Control Module Part Number: 02D 900 554 C
Component and/or Version: HALDEX LSC ECC 0010
Software Coding:
Work Shop Code:
VCID: 2019E015D3D073D7EA9-4B00
00532 - Supply Voltage B+
07-00 - Signal too Low
01155 - Clutch
04-10 - Mechanical Malfunction - Intermittent
79-10 - Please Check Fault Codes - Intermittent
vin TRUWT28N031******
the connector was clean and dry.
voltage at teh connector
2-3 11V
the grounding strap to the housing of the Haldex clutch good
infinite resistance from pin 2 to the grounding strap
2-4 0V with the parking brake on or off
2-7 600 ohms
2-8 600 ohms
7-8 60 ohms
Any suggestions?
Software Coding:
Work Shop Code:
01155 - Clutch
2-3 11V
2-7 600 ohms
2-8 600 ohms
7-8 60 ohms
Any suggestions?
