Results 1 to 10 of 11
Thread: Tiguan 2010 2.0tdi parking aid, parking asist
    Apr 2019
    hello, I'm new here.
    Not working parking aid and parking asist.
    Any help?
    VIN: WVGZZZ5NZBW002157   License Plate:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 1C 22 25 37 42 44 46 52 53 56 62
              69 72
    VIN: WVGZZZ5NZBW002157   Mileage: 233690km-145208miles
       Part No SW: 03L 906 018 ET    HW: 03L 907 309 R
       Component: R4 2.0l TDI   H21 9977
       Revision: 42H21---    Serial number: 00000000000000
       Coding: 00190012040700080000
       Shop #: WSC 00014 210 12345
       ASAM Dataset: EV_ECM20TDI01103L906018ET 003011
       ROD: EV_ECM20TDI01103L906018ET_VW36.rod
       VCID: 000837599B5CA54FA7-8054
    4714 - Steering Column Control Module
              U0212 00 [039] - No Communications
                        Mileage: 233698 km
                        Date: 2019.10.11
                        Time: 14:33:40
                        Coolant temperature: 70 C
                        Intake air temperature: 26 C
                        Voltage terminal 30: 11.840 V
                        Limitation: accelerator pedal: 126.6 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 4
                        selected gear-Bits 0-7: 0
    Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
       Part No SW: 5N0 614 109 Q    HW: 5N0 614 109 Q
       Component: J104    C4 450 V2D7 0006
       Revision: --H28---    Serial number: 00000002842136
       Coding: 0015660
       Shop #: WSC 01324 020 00200
       VCID: 397E9ABD70063487A0-806C
       Part No SW: 3C8 907 336 AC    HW: 3C8 907 336 AC
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0008000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6ED479E1B1C8A33F45-803A
       Part No SW: 5K0 937 086 F    HW: 5K0 937 086 F
       Component: BCM PQ35 M    011 0035
       Revision: BC011001
       Coding: 40180A388073B5D8000800891500812443613088524D8563DC8020000040
       VCID: 377A9C85861222F756-8062
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 14051  012 0203
       Serial number: N2955119   203!
       Coding: 0097B5
       Subsystem 2 - Part No: 1K8 951 171
    Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
       Part No SW: 1T0 919 475 H    HW: 1T0 919 475
       Component: PARKHILFE PLA H07 0110
       Revision: --------    Serial number: 88591013486863
       Coding: 011002
       VCID: 4088F759D3DC654FE7-8014
                        Reset counter: 215
                        Mileage: 233698 km
                        Date: 2014.03.03
                        Time: 14:27:57
                        Temperature: 15.0C
       Part No SW: 5N0 959 655 N    HW: 5N0 959 655 N
       Component: J234__201 VW10 HI   1916
       Revision: 21014000    Serial number: 003GHP9YEDRT
       Coding: 0012337
       VCID: 4898EF793BEC5D0F2F-801C
       Subsystem 1 - Serial number: 6332MTS615391240
       Subsystem 2 - Serial number: 6342MTS627371240
       Subsystem 3 - Serial number: 6351HTS6S64G89KR
       Subsystem 4 - Serial number: 6361HTS6EIPG89KR
       Part No SW: 5K0 953 521 BM    HW: 5K0 953 569 D
       Component: LENKS.MODUL   009 0135
       Revision: FF010036    Serial number: 20100427200197
       Coding: 100A044000
       ASAM Dataset: EV_SMLSNGVOLWS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 78F85FB9C38CED8F9F-802C
       Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H05 0010
       Coding: 820000
       Part No SW: 5N0 920 972 A    HW: 5N0 920 972 A
       Component: KOMBI         H03 0406
       Coding: 110F01
       VCID: 316EA29D6076FCC718-8064
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 0602
       Revision:   H27       Serial number: 090510F2001463
       Coding: F9A27F4640120200006003
       VCID: 6DD67EED74CE58277C-8038
       Revision: 00001000    Serial number: 1225223R8Z0Y06
       VCID: 7EF449A129A8D3BFD5-802A
       Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
       Component: Haldex 4Motion      0042
       Coding: 0000005
       VCID: 4C90D3692F94B12F0B-8018
       Component: IMMO          H03 0406
       VCID: 6ADC75F18D204F1F19-803E
       Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
       Component: RNS-MID       H50 5274
       Revision: AB001001    Serial number: VWZ6Z7L5072817
       Coding: 000504000000009F000C
       Shop #: WSC 05314 123 12345
       Component: EU West V15  8515
    00856 - Radio Antenna
                        Fault Status: 01101011
                        Reset counter: 215
                        Mileage: 233696 km
       Part No SW: 5N0 959 701 D    HW: 5N0 959 701 D
       Component: Tuer-SG         009 2102
       Coding: 0000700
       VCID: 366491814118DBFF4D-8062
       Part No: 5N0 909 144 J
       Component: EPS_ZFLS Kl. 202    3001
       Revision: 00H17000
       Shop #: WSC 01324 785 00200
       VCID: 38789FB94B0C2D8F5F-806C
       Part No SW: 5N0 959 702 D    HW: 5N0 959 702 D
       Coding: 0000700
       VCID: 377A9C85461222F756-8062
       Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
       Component: J540 EPB4  VW-53083 0006
       Revision:   H18       Serial number: 00000000005283
       Coding: 0023057
       VCID: 326CAD91AD70C7DF61-8066
                        Reset counter: 215
                        Mileage: 233696 km
       Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
       Component: Tuer-SG         007 2102
       Coding: 0000144
       Shop #: WSC 01324 020 1012551
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: Anhaenger     H07 0070
       Revision: 3A001001    Serial number: 00000129822254
       Coding: 410D000100000000
       VCID: 3068A799637CF5CF17-8064
       Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
       Coding: 0000144
    End-------------------------(Elapsed Time: 02:54)--------------------------
    Apr 2019
    maybe problem in that value?
    or how to change-edit it?
    Address 10: Park/Steer Assist (1T0 919 475 H)
    13:30:38 Group 040
    27.00 km/h Sensor Activation Speed
    30.00 km/h Sensor Deactiv. Speed
    30.00 s Standstill Afterrun
    536 cm Parking Space Minimum Lenghth
    Any help?
    HQ
    You've got some codes for the J527 not talking, but there it is in the Auto-Scan, talking away. Is this car bone stock? Has it been modified or altered in any way since it left the factory?
    Jef
  4. Likes Uwe, Jack@European_Parts liked this post
    Apr 2019
    thanks
    yep fit a leather, rns510 with after market cam. everything was ok until full discharge battery.
    now not working parking aid, parking asist.
    i will try today reconnect camera.....
    radio antenna problem is from baster windows tinter, 3 time retint back windows....
    HQ
    ..... a leather what? And what kind of cam cam with your rns510?
    So your Steering Wheel Electronics (J527) is reporting to VCDS, but you've got several modules that says it isn't there. Is the J527 part number 5K0 953 521 BM factory original?
    Do you have an Auto-Scan from BEFORE any modifications where made? If so, please post it.
    https://www.youtube.com/watch?v=Vg6m35YlHjk
    Jump to 2:15 in the video to learn how to find past Auto-Scans.
    Jef
  7. Likes Jack@European_Parts liked this post
    Apr 2019
    it first my scan for that car.
    Tuesday,02,April,2019,11:33:20:24486
    VCDS Version: 18.9.1.0
    Scan: 01 03 08 09 10 15 16 17 19 1C 22 25 42 44 46 52 53 56 62 69
              72
    VIN: WVGZZZ5NZBW002157   Mileage: 224350km-139404miles
       Coding: 00190012041700080000
       Shop #: WSC 00014 210 00000
       ROD: EV_ECM20TDI01103L906018ET.rod
       VCID: 000837599B5CA54ADD-8054
       Component: J104    C4 450 V28B 0006
       Coding: 0015660
       VCID: 397E9ABD70063482DA-806C
       Revision: 00009001
       Coding: 0000000002
       VCID: 6ED479E1B1C8A33A3F-803A
       Revision: BC011001
       Coding: 48180A3B8025F1C0400800801000012443013088524D85605C8000000040
       VCID: 377A9C85861222F22C-8062
       Coding: 009795
       Coding: 111002
       VCID: 4088F759D3DC654A9D-8014
       Coding: 0012337
       VCID: 4898EF793BEC5D0A55-801C
       Coding: 1082040000
       VCID: 78F85FB9C38CED8AE5-802C
       Coding: 820000
       Coding: 410F01
       VCID: 316EA29D6076FCC262-8064
       Coding: F9A27F4600120200006003
       VCID: 6DD67EED74CE582206-8038
       VCID: 7EF449A129A8D3BAAF-802A
       Coding: 0000005
       VCID: 4C90D3692F94B12A71-8018
       VCID: 6ADC75F18D204F1A63-803E
       Coding: 0000700
       VCID: 366491814118DBFA37-8062
       Revision: 00H17000
       VCID: 38789FB94B0C2D8A25-806C
       Coding: 0000700
       VCID: 377A9C85461222F22C-8062
       Coding: 0023057
       VCID: 326CAD91AD70C7DA1B-8066
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: RCD510        H12 5024
       Revision: -----08S    Serial number: VWZ4Z3K1115780
       Coding: 0500040004
       VCID: 65C606CD6C3E60624E-8030
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
       VCID: 3068A799637CF5CA6D-8064
       Coding: 0000144
    End-------------------------(Elapsed Time: 03:14)--------------------------
    May 2017
    ^ Hmmm... something odd with the autoscan. Installation list shows malfunction for 09 Central electronics but actual autoscan of the module shows no errors.
    Is this really unedited autoscan or what am I missing here?
  10. #8
    That happens sometimes; the Gateway gets out of synch with the status of an individual module. It's not something I would consider a "red flag" in a scan.
  11. Likes Jack@European_Parts liked this post
  12. #9
    HQ
    So there has been some coding tweaks going on.
    09: J519
    48180A3B8025F1C0400800801000012443013088524D85605C 8000000040 original coding
    40180A388073B5D8000800891500812443613088524D8563DC8020000040 current coding
    10: J791
    011002 original coding
    111002 new coding
    16: J527
    1082040000 original coding
    100A044000 current coding
    17: J285
    110F01 original coding
    410F01 current coding
    19: J533
    F9A27F4640120200006003 original coding
    F9A27F4600120200006003 current coding
    So if you return the car back to "factory original", do the issues go away?
    Jef
  13. Likes Fredrick Awuor, downtime liked this post
  14. #10
    Apr 2019
    Thanks
    It help me
